Question about Apple iPod nano
Frozen ipod ipod stoped out of noware it made a long beaping noice i had to wait until the battery discharged. please answer as fast.
  • rock dude Feb 27, 2008
    my ipod wonn't turn on its frozen
  • 150 Answers
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Posted on Sep 20, 2007
I did all thata but it still hasn't been unfrozen.
Posted on Feb 02, 2008
SOURCE:
How do you restart an Ipod?? I was trying to
IF IPOD ISN'T FROZEN.
  1. Hold the Power button until you see the "Slide To Power Off" slider.
  2. Let go of the Power button, and slide the slider.
  3. Wait until it turns off completely, press the Power button again to turn it back on.
IF IPOD IS FROZEN.
  1. Press and hold the power button and the square home button at the same time.
  2. Wait some time it will reset eventually.
  3. Be patient.
Hope this helps - good luck!
Sep 17, 2009 | Apple iPod touch
Tip
How To Reboot An iPod Touch
If Your iPod Isn't Frozen
If Your iPod Is Frozen
on Jul 12, 2010 | Audio Players & Recorders
My ipod nano 8gb has frozen
Please keep it idle and wait untill all the charge discharge.Once it show"connect to power" , you can charge it and there after it shows all the menu's and functions
Aug 08, 2009 | Apple iPod nano
Its frozen and the buttoms are not working
Please wait for your ipod to discharge all the power it has.it might even take 2-3 days to discharge the power Then after the ipod is completely empty (which means its off and needs to be charged) you can connect it to your computer. Please make sure your computer is scanned from viruses. You can also scan your ipod from viruses. Never unplug your ipod before it completes synchronizing. You dont need to worry! its normal for ipods to behave that ways :)
Jun 02, 2009 | Apple iPod nano MP3 Player
Frozen screen
First, make sure the lock slider is in the proper position.  I know, obvious, but you'd be surprised how often this happens.
Next, slide the lock slider to locked and then back.  Then press and hold the Menu and Select (center) button for 6-8 seconds.  Try a couple times if it doesn't work the first time.  The ipod should reset and work.
If that didn't work, you can reset your ipod.  But first, try connecting the ipod to your computer and see if it goes into sync mode. If so, wait for iTunes to load and then eject your ipod in iTunes and see if it works again.
To reset your ipod, slide the lock slider to locked and then back.  Next hold the Play/Pause Button and the Menu button for 6-8 seconds.  You may have to try this a couple times.  The ipod should reset.
The last thing to do is to let your ipod discharge completely by leaving it at the frozen screen.  Once your ipod is out of battery, reconnect it to you computer or a power adapter and let it charge.  Then try to access it again or repeat the steps above.
Nick
Jan 22, 2009 | Apple iPod nano
Frozen ipod/4bg
Hi! Wait for the iPod to discharge and it will automatically turn off when its battery gets discharged or press the middle button and play button simultaneously. It will reset the ipod
Dec 27, 2008 | Apple iPod nano
My ipod
try shutting off ur ipod for a while by holding the top hold button and the home button. wait a day untill u turn it on a gain
Jul 13, 2008 | Apple iPod touch
Ipod mini screen freezing
How to manually reset a frozen iPod mini:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, which takes about 6 to 8 seconds.
http://docs.info.apple.com/article.html?artnum=61705
Feb 26, 2008 | Apple iPod mini M9160LL/A MP3 Player
Ipod 30G frozen
wait until your ipod is lowbatt
May 10, 2007 | Apple iPod MP3 Player
Apple iPod nano Logo
395 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
