Question about HP JetDirect EX Plus Print Server
Open door sensor indicator light won't go off
  • 611 Answers
Reset it the device
Posted on Mar 14, 2009
How do I get my remote to close the door? It will only open it.
Light sensor at bottom of door may be broken or something in the path of the light or the sensor and light source need to be realigned.
garage door won close YouTube
Aug 25, 2014 | Building Materials
Door light ajar won't come off
if the seat belt was ever closed in the door at one time open all doors look on the moldin for the little button on the car to see if its broke off
Nov 12, 2012 | 2008 Nissan Altima
Car doors won't lock because of an error message. What could the problem be?
Whenever this warning light or any other stays on in the dash it is indicating that the systems control module (or the system sensor in the case of lights like low oil pressure, door open indicators etc.) has detected a fault, it then disables the system (this applies to ABS,TCS, TCM, SRS, TPMS and BCM faults and others) as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Legend of Abbreviations. ABS Anti-lock brake system. TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module. TPMS Tire Pressure Monitor System
Nov 06, 2012 | Ford Fiesta Cars & Trucks
Fiat doblo door open light stays on and doors won't lock
this is the door open light indicator on your instrument panel correct? it thinks the door is open. do interior courtesy lights work? i.e. turn on off when opening doors? check for "normally open" circuit faults in the door switches
Aug 27, 2012 | Fiat Doblo Cars & Trucks
My liftmaster garage door opener will open the garage door but won't close it from the wireless remote in my car. what could be the problem
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering ever so slightly. Tweak them a bit. If you cannot get both lights to light you have bad sensors.
Sep 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hotpoint wm64s indicating door not shut program will not function cus door light flashing...however door iis shut n wont open
You have a mildly confused machine, probably the result of the fact that there is a moment where the door lock can activate, but the sensor that tells if it's shut cant because the door isn't QUITE pushed home hard enough.
First try, just give the door a whack with the heel of your hand in line with where the door catch is. It may be that simple to relocate the door and the sensor properly
Failing that, unplug at the wall and wait 20 minutes. This will, without doubt reset the machine and allow you to open it (While it is still powered off!). Open the door and shut it firmly.... I hesitate to say SLAM the door.... But slam-ish won't hurt, just don't be stupid about it!
All should be OK going forward
Jul 04, 2011 | Hotpoint WMA64 Front Load Washer
We have a older craftsman door opener and we now need to hold the button to close the door and the car remote dose not work.
Clear any obstruction from between the safety sensors. Loose leaves, trash, and dirt on the lens of the sensor itself are all examples of things that can obstruct the sensor's signal.
  1. Check each sensor for a steady glowing indicator light. If both indicator lights are on, or if one indicator light is flickering, the sensors may be slightly misaligned. To check for misalignment; obstruct the beam of the sensors so that they cannot see each other. When the beam is blocked, the indicator light on one of the two sensors will temporarily go out. This is the receiving sensor. Remove the obstruction and loosen the wing nut on the back of the receiving sensor. Adjust the receiving sensor until the green indicator light goes out, if not already out, then realign until the green light is bright and steady, then retighten the wing nut. This usually takes a couple of attempts before it is back in alignment.
  2. If an indicator light is out on one or both sensors, check for a possible loose or shorted wire. Sensor wires are attached to the white and black terminals on the back or side panel of the overhead motor unit. Check that they are securely connected to each terminal. Also check the wires for any breaks, especially anywhere they are spliced together.
Jan 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman will open and close with wall mount switch but will not work with the remote door opener
Jan 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door will open, but will not close
My Wayne Dalton garage door will open with remote but not close. The only way it will close is to hold down the wall mounted garage door button. Then the light goes on and off while clicking. I have...
your infrared sensor is either misaligned, faulty, or you have a broken wire from your sensor to your door opener. (Flashing light indicates infrared light path is broken). both sensors should indicate green led. door wil not come down is safty feature to prevent door from closing when light path is broken.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
HP JetDirect EX Plus Print Server Logo
267 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
