Question about Sharp AL 1631 Copier
Copy quality always light
Every copy on this machine is too light. I have replaced the toner with no change. It is practically new. It is also the fourth replacement. I suspect the machine needs to be cleaned but i can't find instructions on how to do it. I am capable of cleaning it without damaging the mirrors, etc. but would like to have a procedure. Second problem, which I have been living with, is that after a few hours of not being used, the first copy I make causes a paper jam. after the first copy, it feeds fine. ???
  • 328 Answers
Are you using a genuine OEM Sharp toner and drum? The paper pick-up rollers could use a good cleaning. Try a little WD 40 on a cotton cloth and clean the d shaped rollers. Also the feed clutch could be sticking. You have to take the back covers off to see the clutch. Clean and put some light grease on it. Easy parts to order and not expensive.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 03, 2007
SOURCE:
Light copies
If parts are unavailable because you have an old machine, the practical answer may be to replace the whole machine.
Sep 15, 2014 | Office Equipment & Supplies
Copier quality
Most fax machines would have a resolution selector to vary clarity of transmitted documents. The same would also hold true for scanning jobs. I would discount the possibility of the power supply since everything works except for the quality of the copy/fax. If the printer still works OK (quality of print out) then it is the scanner's availability to copy that is the issue. With current prices of all in one printers (fax/scanner), purchase of a new unit might be more practical not only in terms of cost but in downtime.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Our Sharp AL 1631 copier has served us well for about 5 of the last 7 years or so. The last two years, copies are very very light - no matter what the settings, and there is always lots of loose toner...
As long as it is dirty inside the nachine, you will continue to have problems with copy quality' The light copies are from dust in your optics.
Basically, the machine needs aGOOD Cleaning, inside and out..Yes, it will cost you a service call, but that should clear up your issues. Be careful, and ask the tech/company what a good cleaning consists. Be srecific with describing your problems, like you did here.
Good Luck
P.S. if you have in house tech, let me know. I can tell them how to get into everything on the machine.
Jan 11, 2011 | Sharp AL 1631 Copier
Poor copy quality - smudgy copies - changed toner - still the same.
check your OPC drum life, if you have a poor quality with a new cartridge installed (light copy, dirty copy) the opc drum must be replaced, check you machine counter if you have reach 100k copies you need to replace the drum, if you are using a new OPC DRUM, you need to clean the machine, you have to call for service because there is many parts that muat removed to clean properly.
Dec 27, 2010 | Canon NP 7130 Black and White Copier
Canon ir5000 copies have horizonal bands of light copy quality. How do I get even, good quality down the entire page?
The machine probably needs a service paying attention to the development and the cleaning areas. Also, clean or replace the corona wires and check that there is no flat spots on the fuser roller.
Jun 18, 2010 | Canon Office Equipment & Supplies
Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 18, 2009 | Konica Minolta Office Equipment & Supplies
The add toner light stays on with a new toner cartridge
Yes, the machine will only make single copies if the toner light is on. Was the toner cart genuine Copystar? Or perhaps Kyocera cart? The machine is made by Kyocera and marketed under both name brands, however, the toner carts are different for both machines. I have seen many times that aftermarket carts will not always work properly.
Jan 06, 2009 | Copystar CS-1510 Copier
Poor quality of copies
If it is a real genuine Brother toner. Not a reman. You may also need to change the drum. If you have a user manual, it will show you where the drum life setting is in the menu structure. Make sure the little glass window inside on the right is clean so it can read the toner level. Make sure the toner save feature is turned off.
Aug 14, 2008 | Brother IntelliFAX 4100 Laser Fax
Poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Sharp AL 1631 Copier Logo
82 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
