Question about Sony Playstation 3 (PS3) Console
The power comes on but the HDMI is not responding?
Same problem ? but with PS3 just out of warranty.
Disk would go in alright and eject but nothing else. Seemed the hard drive was faulty or something else seriously wrong? Wouldnt turn off either.
My fix was check all connections.
Turn off at back leave a moment, turn back on
and hold down on/ start button till beeps twice (about 3 secs)
Menu came up
Select 2 on menu and reset default.
Everything works again . PHEW.
Hope this helps.
Posted on Mar 13, 2009
    Novelist:
  • Sony Expert
  • 172 Answers
Did you have try to reset all the video settings ?? ok let's try that my name is Juan and I am here to help you and see if we can solve this with the unit off turn the main switch off on the back of the unit connect the HdmI cable to the unit and to the tv now place your finger on the front on/off switch and keep it there now turn the main switch on the back of the ps3 keep your finger on the on/off switch for about 4 seconds or until you heard one bip (but not the first bip when the playstation turns on ) ok so once you heard the bip after few seconds remove your finger from the on/off switch and this should make your hdmI to work again just wait few seconds for the signal to show up on your tv sometimes it takes about 30 seconds once you see the browser the system will ask you if you want to switch to hdmi click yes hope this can fix your problem and if it does please rate my help thanks
I have plugged my fire stick to the hdmi and power outlet, turned on the tv, but nothingness has appeared on tv and is not responding when I use the home button on voice remote? What shall I do?
Typically you need to be in video feed for the HDMI port. On the remote, the button is usually called video or input. Press that button to get to your HDMI port. Then you should should see the Amazon fire stick feed.
Oct 27, 2017 | Televison & Video
Vizio E470VLE HDMI inputs not working
its the antanna don't go on your roof you probs bumped it
Aug 31, 2016 | Vizio E470VL 47 in. HD-Ready LCD TV
HDMI input not working - TV is 4 months old
Unplug TV from mains power and leave for a few minutes before plugging back in. Then try the HDMI again.
Feb 03, 2016 | Televison & Video
Panasonic tc p50s2
It sounds like the HDMI receiver chip on your Main board is fried, probably from a power surge. You will need to find an exact replacement board on Ebay or Shopjimmy.
Mar 22, 2014 | Televison & Video
My dog chewed the power cord on my ps3 while it was on and it triped the breaker in my house ,i got a new power cord but now the ps3 powers up but cant get the hdmi cable to work to tv
It may be possible that he has caused a power outage that disabled your HDMI output. It is a common problem, both HDMI and AV outputs will go out.
Can you get a display with AV cords (if you haven't tried, get them ready)
You may be faced with a problem that will cause you to use AV or Component cables. (recommended if HDMI output is out)
Try to reset your settings.
Plug in both AV and HDMI cables.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go. Make sure that you are switching your TV from HDMI to AV and vice versa.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options.
Try 1.
If you are able to get the AV cables to work with this method, try setting your HDMI up as you did before.
If you cannot get HDMI to work, then your output has gone out. You must use the AV/Component cables.
If you get no display at all but the system appears to be responding normally (outside of the display) then:
You have what is commonly known as the "Green light of Death."
It is when your system powers on and acts normally but no display. Your GPU (graphics chip) has cracked or become damaged and will need to be sent in to SONY. You can try a 3rd party technician, but this repair has a very very low success rate.
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
Brand New. Plugged in, first of all buttons don't seem to respond to touch or anything. Issue: runs a "test" as far as i can tell (Analog, then Digital, then HDMI, then repeats again), then goes...
It is not seeing a good signal from your computer (that is what it is doing looking at analog, the digital, the hdmi) Could be a bad cable, or plugged into the wrong connector on the computer. Computer is on right?
Try turning off computer plug in monitor then turn on computer see if you get any reaction.
Another suggestion if your are using the digital cable, try the analog (or visa versa)
Let me know if that doesn't help.
Dec 03, 2010 | Samsung B2330H LCD Monitor
Sony connectivity
OK, here are info...
first unplug TV and dvd recorder from AC outlet and put hdmi cable as follows...
at rear side of TV, you have 2 hdmi inputs, hook hdmi cable in any one of them and other end of hdmi cable will be hooked in hdmi out of dvd recorder rear side.
Now, plug both units in AC outlet and power up, go to TV menu > hdmi setup > and perform device list update.
TV will recognize dvd recorder and you will see dvd recorder logo screen.
Let me know if you need further info / help.
Dec 23, 2008 | Televison & Video
I have a TH-42PD25 TV. It turned off by itself. The red light on the front control panel is blinking. The TV is not responding to the power button on the remote or the front of the TV.
Here is a link to your users manual
http://service.us.panasonic.com/opermanpdf/TH37PD25.pdf
If youre using a PC or HDMI, the manual suggests this :
Rarely, the TV will not display video in
HDMI input from devices with HDMI or DVI
output due to bad communication between the
TV and the devices. Should this happens, unplug
the HDMI/DVI device and plug it back on.
May 16, 2008 | Panasonic Televison & Video
Sony Playstation 3 (PS3) Console Logo
85 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
