1996 Audi A6 Logo
Posted on Mar 11, 2009
1994 audi 100s transmission problem, cumputer, no reverse AUDI VW
1994 audi 100s front wheel drive non quattro automatic transmission, drives but has no reverse and 4th gear. FAILSAFE MODE? or coumputer malfunction? whats wrong here.
audi4me
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Sep 03, 2009
audi4me
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
7198
Points
26
Hi I also have an Audi Auto 2.8 non quottro had a simler problom and it turneed out to be one of the gear relays that are under the stering wheel on a left ****** that is.
2answers
2004 Audi A4 Cabrio - the PRNDS flashes intermittently - sometimes staying on - then stops. Thank you, Scott.
IIf the vehicle is front wheel drive and now Quattro than then the transmission range sensor is located inside the transmission and is part of the mechatronics unit (valve body). If the vehicle isn't Quattro then the transmission range sensor is bolted to the drivers side of the transmission where the cable connectors to the shift lever. When these range sensors go bad that will cause the flashing or solid PRND light on the cluster.
My car shifts into gear then revs really high with no acceleration i have a 2001 audi a6 quattro... what does this mean? It reversed fine.
Likely the transmission has bands or clutch packs failing. Reverse is often unaffected. Have vehicle scanned and read the codes. You will likely have drive train codes in the P1700 and up range.
2001 Audi A4 Quattro, Reverse slips
Perhaps it is in severe pain, because you failed to identify it it by make and model!
Servo or band worn out, o.ring gone hard or clutch pack burnt out.
I want to buy an audi a4 2.0 front wheel drive not the quattro version,all the car experts told me that the car has a problem with its transmission and specifically the transmission control unit and it...
by far the biggest expense is the front suspension,as ALL bushes WILL need replacing at 80k.cost £2400(yes pounds sterling)then the transmission,if car is hammered.£2100.BUT this is common TO ALL VW PRODUCT NOT JUST AUDI.but same could be said of MOST cars,as they all have major faults waiting to happen.(why would they build a car to last ?????
My car doesnt go in reverse after it was towed its a 1994 audi a-4
did they tow it from the fron or from the back? and is it a front wheel drive or a rear wheel drive?
2helpful
1996 Audi A4 Automatic transmission wont shift when cold
Silly question: Have you checked the transmission fluid level, and is it to manufacturer's spec?
2helpful
how too check transmission fluid on audi 100s 1994
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
