Question about Fisher and Paykel Dishwashers
Fisher & paykel dd603 wiring diagram - Fisher and Paykel Dishwashers
SOURCE: Fisher& Paykel
Hi Guys,
Our dishwasher was bone dry underneath yet we had F1 error on the top drawer only. Found the "flood switch" was dry, but the terminals for one of the drawers were a little dodgy; probably due to the mouse living in our dishdrawer - found plenty of it's evidence left behind. Removed the terminals, cleaned the contacts, re-fitted the terminals - all working OK
Cheers, Kiwi
Posted on Jul 26, 2008
RescueTech
  • 145 Answers
SOURCE: FP DD603 draining problem
This device will solve the issue of cross-draining between drawers on Fisher paykel double dish drawers.
http://fisherpaykelparts.net/index.php?categoryid=1&productid=7
Posted on Dec 14, 2008
  • 125 Answers
SOURCE: fisher and paykel leak
most likely the actuators are bad. with the unit off push and hold the lock and start buttons, lock first then start, after about 6 seconds the display will flash 188. press the power button, ho will be displayed. push the start button until Ld is displayed. open the drawer in question and push the lock button and watch the lid both sides should go down evenly, push the lock key to move it up and down as needed. push the power button to exit diagnostics. if you notice that the lid doesn't go down evenly or if one side stays up replace the actuators, they come as a pair. call a dealer/servicer to order actuators. make sure to specify top or bottom as there is a difference. hope this helps
Posted on Mar 03, 2009
SOURCE: Fisher and Paykel DD603 top drawer jammed and will
Hey, I had this problem before!!!! Just unplug the unit off and wait about 10sec and plug it back on.....that usually does the trick.
Posted on Nov 26, 2009
jyackle5
  • 8197 Answers
SOURCE: Fisher and Paykel dishwasher DD603 manual
You can get the manual below for free..
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
Good Luck and please rate 4 thumbs for the free answer
Posted on May 15, 2010
MY FISHER /PAYKEL DISHWASHER DD603 DOES NOT HAVE A POWER CORD
Not sure why the power chord would have gone missing. I am assuming you may have an integrated model.
In any case you will have to take the bottom drawer out to gain access to the power filter board which is located at the base of the cabinet under the drawer.
To take out the bottom drawer follow instructions on page 7 of this installation manual.
http://www.fisherpaykel.com/vault/pdfs//pdf_installations/526609O_DDinstall_NZGBw.pdf
Make sure the drawer is not pulled too much out to avoid damage to wires and hoses underneath. Leave it on soft material on the floor. Next locate the power filter board at the base. It looks like the pcb in the attached parts diagram. The power cable is meant to go to the block connector on this pcb. Make sure you check connections carefully as mains voltages are involved. Put everything back.
http://www.searspartsdirect.com/partsdirect/part-number/Fisherpaykel-Parts/Dishwasher-Parts/525959P/0022/426/Model-DD60388445B/3068/0130000?keySuffixId=&pathTaken=partSearch&pathRender=modelComponent&documentCompId=50042566&diagramPageId=00003&productTypeId=&searchModelNumber=DD60388445B&subCompDesc=Cabinet&brandDesc=FISHERPAYKEL&modelDesc=DISHWASHER&blt=11&shdMod=&keyId=15
Aug 05, 2014 | Fisher and Paykel Dishwashers
I have a Fisher & Paykel dish drawer model number DD603 and it is not draining. Any tricks?
Hi
Dishwasher not pumping issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please check the parts manual for your dishwasher, check the drain pump & drain filter's location from the link---
Fisher and Paykel Dishwasher DD603 Parts Manual
Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat. Please post back for any further assistance.
Daniel
Aug 07, 2010 | Fisher and Paykel Dishwashers
Fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
Nov 25, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel DD603
The top drawer on our DD603 top lid doesn't seal allowing water to spray out and down the sides.
Aug 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
99 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
