Question about Toshiba Satellite L305-S5933 Notebook
Wireless problem i have a wireless router setup at home. currently 3 out of my 4 computers are connected but my laptop (win Vista) is not connecting. it says connected but shows local only. i have a clear wire usb modem and it doesnt work" says connecting, authenticating, then freezes on "obtaining IP Addy" and just gives up after like 5 min. so i thought that i could just connect to wifi at my house. but that doesnt work either. i dont even know where to start to try and fix this. HELP!!
Just purchased a WGR614 wireless router for my dell laptop. the instruction manual only mentions connecting to external modem, what if you have a laptop with an internal modem, how do you connect? My...
Thank you for using FixYa
Wireless connections have a lot in common so here is a link that will give you the general configurations for a wireless Router to PC. Keep in mind that you will need to configure both the computer and the router in two separate steps. That is why it is best to use the setup disk that normally comes with a new piece of equipment and the cables.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Also keep in mind that the equipment should be matched or designed to work with the other equipment. You will have some kind of a modem either a cable modem or internal modem or external modem that the router will have to connect to.
It is best to allow your own Internet Service Provider to set up the connections. They may not be able to support the configuration if you do not purchase it from them and then you will need to do-it-yourself.
Here are the links for configuring the computer with the different operating systems
Win XP http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Win Vista
http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Win7
http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this was useful and please comment if this was helpful to you.
Mar 23, 2011 | NetGear WGR614 Wireless Router
Setup didn't work, "details" section on network
Win7 will connect without any problems, but win vista will not get connected to the network...
You can update the drivers for wireless adapter in vista laptop, it will get connected...
If it still not getting connected then change the security settings on your router to 64bit WEP... (Initially it will be in WPA)
disabled the WPS (wifi protected setup) in the router...
change the ssid in the router...
Now try to connect to the new wireless network...It will work perfectly....
click here to configure the wireless part of your belkin router...
Any issues call 18002235546 ( 24/7 )
Feb 06, 2011 | Belkin Play N600 Wireless Dual Band Router...
Laptop running 0n win 7 wont connect to router
1. you will have to designate the laptop or allow it to connect by entering it into the 3com router.
2. try connecting to the router via ethernet cord (that is connecting with a physical straight through cord) that came with the router.
If connected with this then you will have to go into the router via the IP set 192.168..0.1 depending on the router ip for loging in.
2. Go to the "wireless setup" and enter your MAC address for the laptop in the permissions list in the router. Instructions on how to do this is at the manufacturers site. Step by step.
3. Do the following step if instructions not found.
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP adresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jun 19, 2010 | 3Com OfficeConnect Router
My printers that are on my wireless network won't print
Did you define the printers and printer ports to the laptops?
On the XP laptop go to network connections in the control panel and use the network setup wizard.
Jan 01, 2010 | NetGear WGR614 Wireless Router
I got a Netbook, I have been using wireless internet in my home for years but cannot connect to internet with new computer.
In order to connect with the wireless router u need to scan for the available wireless networks in the range .
So if u r using Win XP ,
1. Rightclick on the wireless network connection.
2. U will see view available wireless networks..
3. u will see ur network name
4. enter ur security key
5. Connect
Or if u r using win vista :
1. click on start
2. Connect to wireless network.
5. Connect
In case u need further help , feel free to get in touch .
Nov 24, 2009 | Computers & Internet
Problem connecting to WNR2000 on laptop running vista
Perform the task below on the wireless VISTA computer:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 26, 2009 | NetGear WNR2000 Wireless Router
Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Jun 12, 2009 | Belkin (F5D8231-4) Wireless Router...
Cannot connect a second pc
Are you connecting the machine that doesnt work wired or wireless??
Do you know what wireless card you have if it is wireless?
Dec 26, 2007 | Linksys Wireless-G WRT54GS Router...
Toshiba Satellite L305-S5933 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
