Question about Car Audio & Video
How to put on sony xm 3020s
Hey! i got the power amp sony xm 3020s. but i have no plan or something how to install. what are the coloured cables for? the yellow one, the black one, and the blue und the red one? the speakers are no problem for me ;).
thanks a lot, alonzo76
Dfsd
Posted on May 24, 2013
  • Ian dean kirkham May 24, 2013
    Hi Sorry was just signing up.......incorrect the YELLOW is a direct connection to 12V + normally straight to battery, the BLUE is signal received by your stereo to actually turn your amp one RED is a 12v + Out when amp is on to power another 12V device only when amp is on via BLUE Signal Cable....Thanks
  • 102 Answers
RED is for 12v POS, BLK is for GROUND, BLU is for REMOTE ON. Not sure about the yellow, probably an AUX ON/OFF.
Posted on Mar 11, 2009
How to install a pioneer deh-p8400mp car radio
Here is the wring harness colour code for Pioneer.
Yellow= Constant 12V
Red= Switched 12V
Black=Ground
Blue=Power Antenna
Blue/White stripe= Power Amp Rmote turn-on
White & White/Black stripe= Front Right Speakers
Grey & Grey/Black stripe= Front Left Speakers
Purple & Purple/Black stripe= Rear Right Speakers
Green & Green/Black stripe= Rear Left Speakers
Orange= Illumination
Ajin
Apr 27, 2012 | Pioneer Car Audio & Video
I need to wire my sony cd player into my fiat cinquencento but I have no idea how to wire it in I just spent 23 on a wire for the stereo an it only cost me a tenner for the actual stereo I dont want to...
most car stereos are simple to wire, especially sony!
Main power cable colours are:..
RED = LIVE (+)
BLACK = NEGATIVE (-)
YELLOW = MEMORY/SWITCH LIVE it will be next to the red and black cables
ORANGE AND WHITE = ELECTRIC ARIAL (IF FITTED)
BLUE = REMOTE WIRE (FOR AMP CONTROL IF USING)
You should now be left with a couple of audio out jacks and speaker cables,
the speaker cables are straightforward, most have a twin, ...E.G if you have a grey wire, this should be next to a grey and white (or grey and black, depends on model) wich is classed as its PAIR/TWIN.............
an so forth,...green, purple, white, brown.....ect ect
each colour havin a twin as stated ealier!! (they are twinned, as the solid colour is usually the negative speaker, and the solid colour with a stripe through it is usually the posative speaker connection (eg..single solid colour is (-)...and...solid colour with stripe is posetive (+)...)
Apr 30, 2011 | Car Audio & Video
Amplifier causes subwoofer to emit super high pitched sound
YOU NEED NO CHACK THE GROUND CABLE SOMETIMES WITH THE SAME POWER THAT THE AMP NEED START TO BURN THE CABLES AND IF THE GAUGE OF THE CABLE IS NOT THE CORRECT CAUSES THAT PROBLEM TRY TO PUT 2 GROUND CABLES (GREY) IN DIFERENT PLACES AND IT MUST WORK!
Feb 10, 2010 | Sony XM-475GSX Car Audio Amplifier
Wiring diapgram and color code for clarion drx6475
hey hey,
Dont have a diagram but if you wanna know the colours they are
Red - Accessory Power
Yellow - Battery+
Black - Ground/Chassis
Orange/White - Illumination
Blue - Power Antenna
Blue/White - Amp remote wire
Brown - Celluar phone mute lead
Speakers:
Front Right - +Grey -Grey/Black
Frount Left - +White -White/Black
Rear Right - +Purple -Purple/Black
Rear Left - +Green -Green/Black
Hope this helps you out
Kind Regards
Brad
Jan 01, 2010 | Clarion DRX6475
I'm planning on installing a system in my pick-up and I was hoping I could get a little assistance. I was planning on using a pair of 5'' McIntosh ms486 coaxial speakers (120w max 4 ohm)in the front doors...
First of all use the larger output amp to power the sub. You can tell if its free-to-air if in the middle of the magnet there is a hole for "air" to flow freely. The advantage of free to air is they dont require much of an enclosure or next to none so you can mount it on a single piece of mdf wood and use the cab in the truck as an enclouse itself. I would bridge the amp for the sub to mono but be careful to tune so you dont "distort". Secondly the amp for the mid's shouldn't be bridged any maybe you could run the front and rear speakers off the same amp.. I would get an amp for rear and front speakers each and one for the sub. Your ouput rca's should goto the cross-over first then to the amp (sub) - then wired to your sub (mono) which is bridged. Ensure to tune your cross-over to lowest frequency for sub. Its easy to bridge an amp if its 4 channel.. looking at the speaker terminals it will look like ( + - + -) use the two outer most terminals to bridge to mono.
Sep 13, 2009 | Sony Car Audio & Video
20-Volt DC Power Supply instead of 12-Volt amp
Here's a few things that come to mind. An auto charging system will operate normally from about 11 Volts to about 14.5 Volts, depending on what is operating (lights, blower,etc), and whether the vehicle is at idle or not. Most car amps will operate from about 10.5 to 16.5 Volts, and outside that range, they will probably shut down.
Another consideration is your 20 volt power supply. You didn't mention if it is a DC power supply, but it needs to be. The other factor is its output, meaning its amperage rating. I'm figuring it will need to put about 5 amps, at the least, for the Sony to put out some watts. I think the line fuses of the Sony are rated @ 25 amps each.
I don't like this type of situation, because I want to say 'try it and see what happens" and I want to say 'don't do it, something may blow".
If you decide to try the 20Volt power supply, maybe if you put smaller rated fuses (say 10 amp) in the Sony amp, they will act as a fail safe. Good luck!
Jul 26, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Need wiring diagram for Sony XM-E70 Equalizer/Amp
You need 1 thick ground cable ( usually brown)
you need 1 thick power cable ( same thickness and wire as ground usually red )
you should have 1 rem wire ( thin blue )
RCAs, 2 for sub, extra 2 for 2 speakers.
The rest I have no idea what they are.
You need speaker cables to sub or amp.
Some products use different colouring. Maybe the 9 pin connector is for head deck to speakers.
Jun 30, 2009 | Sony XM-SD61X Car Audio Amplifier
Problems with my sony xm-2100 gtx amp
check your wires and your ground wire it might be touching something causing it to spark and your amp to go on protect mode also check your fuses..also sometimes this works put your db and all your settings on your amp low as it can go sometimes its just to much power n hits like an impact.
Jun 09, 2009 | Sony XM-2100GTX Car Audio Amplifier
Car Audio & Video Logo
531 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
