Question about Nokia C3 Cell Phone
Class Not Found...Java/lang/class not found Exception
5 Suggested Answers
shevng
  • 175 Answers
SOURCE: Aim Problem?
its your program must go to your nearest service center to reprogram your phone.
peace!
Posted on Dec 15, 2007
  • 317 Answers
SOURCE: my caculator is disappeared after
This problem can only be solved by formatting the mobile completely.
below is link given for formatting the mobile
http://www.fixya.com/support/r5875102-format_nokia_mobile_phones_3110c_2700c
Posted on Mar 01, 2011
  • 943 Answers
SOURCE: Array index out of bounds
it is an error in java which arises when ur request is out of the applications reach ....
Posted on Sep 26, 2011
  • 154 Answers
SOURCE: null pointer java/lang/nullpointer exception error in nokia 5130 in calculator
Calculator program in your mobile is affectedso Update the mobile softwareor else FLASH it
Posted on Nov 13, 2011
What is Java/lang/IllegalAccessError: Cannot Access class com/nokia/mid/impl/jms/core/MIDletRegistry from class napi/bf?
No Mobile Phone user wants to see error messages like this.
This is for programmers,
As Microsoft now own Nokia, perhaps they can assist with this Java Language problem. Lucky Microsoft....!
Some phones are just not user friendly or "smart"
Thats why Nokia are no longer Mobile Phone leaders.
Jul 22, 2014 | Nokia Asha 200 Mobile Phone - Unlocked/No...
Jul 16, 2013 | Nokia X Cell Phones
What is strings in java?
Handling character strings in Java is supported through two final
classes: Java String and StringBuffer. The String class implements immutable character strings, which are read-only once the string has been created and initialized, whereas the StringBuffer class implements dynamic character strings. All string literals in Java programs, are implemented as instances of String class. Strings in Java are 16-bit Unicode.
Nov 21, 2012 | Sun Java Programming Language (cdj-275)
Can't check missed calls shows Uncaught Exception:java.lang.null
When attempting to access a corrupted call list database on the BlackBerry smartphone, the Uncaught exception:java.lang.NullPointerException error message appears:
Isolate the corrupt data by turning on advanced logging for Intellisync.
  1. Turn on advanced logging for Intellisync.
  2. Once the corrupt data entry has been isolated, delete it from the desktop email client and the BlackBerry smartphone.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 10, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Java is not working
Hello there :
first you are going to want to ensure that your your current version of java is installed correctly and is not corrupted and if it needs to be reinstalled
download the latest java version and reinstall this . www.java.com
this should be able to take care of the problem that you are having ok?
best regards michael
Aug 23, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
How to write jdbc connections
http://www.jdbc-tutorial.com/
window.google_render_ad();
welcome_title_image.gif Java JDBC Tutorial Java JDBC Tutorial
The JDBC ( Java Database Connectivity) API defines interfaces and classes for writing database applications in Java by making database connections. Using JDBC you can send SQL, PL/SQL statements to almost any relational database. JDBC is a Java API for executing SQL statements and supports basic SQL functionality. It provides RDBMS access by allowing you to embed SQL inside Java code. Because Java can run on a thin client, applets embedded in Web pages can contain downloadable JDBC code to enable remote database access. You will learn how to create a table, insert values into it, query the table, retrieve results, and update the table with the help of a JDBC Program example.
Although JDBC was designed specifically to provide a Java interface to relational databases, you may find that you need to write Java code to access non-relational databases as well.
JDBC Architecture jdbc.jpg Java application calls the JDBC library. JDBC loads a driver which talks to the database. We can change database engines without changing database code.
JDBC Basics - Java Database Connectivity Steps Before you can create a java jdbc connection to the database, you must first import the
java.sql package.
import java.sql.*; The star ( * ) indicates that all of the classes in the package java.sql are to be imported.
1. Loading a database driver,
In this step of the jdbc connection process, we load the driver class by calling Class.forName() with the Driver class name as an argument. Once loaded, the Driver class creates an instance of itself. A client can connect to Database Server through JDBC Driver. Since most of the Database servers support ODBC driver therefore JDBC-ODBC Bridge driver is commonly used.
The return type of the Class.forName (String ClassName) method is “Class”. Class is a class in
java.lang package.
try { Class.forName(”sun.jdbc.odbc.JdbcOdbcDriver”); //Or any other driver } catch(Exception x){ System.out.println( “Unable to load the driver class!” ); } 2. Creating a oracle jdbc Connection
The JDBC DriverManager class defines objects which can connect Java applications to a JDBC driver. DriverManager is considered the backbone of JDBC architecture. DriverManager class manages the JDBC drivers that are installed on the system. Its getConnection() method is used to establish a connection to a database. It uses a username, password, and a jdbc url to establish a connection to the database and returns a connection object. A jdbc Connection represents a session/connection with a specific database. Within the context of a Connection, SQL, PL/SQL statements are executed and results are returned. An application can have one or more connections with a single database, or it can have many connections with different databases. A Connection object provides metadata i.e. information about the database, tables, and fields. It also contains methods to deal with transactions.
JDBC URL Syntax:: jdbc: <subprotocol>: <subname> JDBC URL Example:: jdbc: <subprotocol>: <subname>•Each driver
Feb 01, 2009 | Microsoft Windows XP Home Edition
Unable to View Java Applet
"load: class JFI.class not found."
Based on the console output, it means that it cannot find the java applet class. In other words, the applet is missing on the server side. There is nothing that you can do about it, unless you know the person who created the applet. Good luck :)
Dec 23, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
StartActivity fails to launch class called
This example is working try it.
Forwarding.java
package com.example.android.apis.graphics;
import android.app.Activity;
import android.content.ActivityNotFoundException;
import android.content.Intent;
import android.os.Bundle;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
public class Forwarding extends Activity
@Override
protected void onCreate(Bundle savedInstanceState)
super.onCreate(savedInstanceState);
setContentView(R.layout.forwarding);
Button goButton = (Button)findViewById(R.id.go);
goButton.setOnClickListener(new View.OnClickListener() {
public void onClick(View v) {
try {
Intent intent = new Intent();
intent.setClass(Forwarding.this, ForwardTarget.class);
startActivity(intent);
finish();
} catch(Exception e) {
System.out.println(e.getMessage());
ForwardTarget
public class ForwardTarget extends Activity
@Override
setContentView(R.layout.forward_target);
AndroidManifest.xml
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
package="com.example.android.apis.graphics"
android:versionCode="1"
android:versionName="1.0.0">
<application android:icon="@drawable/icon" android:label="@string/app_name">
<activity android:name=".Forwarding"
<intent-filter>
<action android:name="android.intent.action.MAIN" />
<category android:name="android.intent.category.LAUNCHER" />
</intent-filter>
</activity>
<activity android:name=".ForwardTarget"/>
</application>
</manifest>
forwarding.xml
<?xml version="1.0" encoding="utf-8" ?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical" android:padding="4dip"
android:gravity="center_horizontal" android:layout_width="fill_parent"
android:layout_height="fill_parent">
<TextView android:layout_width="fill_parent"
android:layout_height="wrap_content" android:layout_weight="0"
android:paddingBottom="4dip" android:text="forwarding" />
<Button android:id="@+id/go" android:layout_width="wrap_content"
android:layout_height="wrap_content" android:text="go">
<requestFocus />
</Button>
</LinearLayout>
forward_target.xml
android:text="forward_target" />
</LinearLayout>
Nov 03, 2008 | Google Android
I closed my Eclipse editor after usual work; and i came on next day to office,try to open it ,but not getting opened by saying "An error has occured .see the log file"
Start by looking at the last line:
MESSAGE Missing required bundle org.eclipse.gef_0.0.0.
Looks like it can't find the GEF (graphical editing framework) libraries. They should be in your eclipse/plugins directory - if not, download a fresh copy from http://www.eclipse.org/gef/downloads/ and extract into the plugins directory.
Can you post the output after doing this, so we can see if the Quantum / OSGI libs are missing too?
Sep 18, 2007 | Eclipse 5443
Nokia C3 Cell Phone Logo
107 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
