Question about Panasonic VIERA Televison & Video
3 tv' s in my home stopped powering on on the same day. I have a 46" and 60" plasma' both less than a year old and a 27" LED. I checked the breakers. I unplugged and plugged them in again. Al
  • Freddie Kirkland
    Freddie Kirkland Apr 20, 2013
    2 were plugged into surge protectors
  • 4 Answers
Your tvs sensitive ic chips on the power boards have been subjected to an undetected voltage spike and are fried. I'm guessing that none were plugged in to a surge protector?
Posted on Apr 20, 2013
  • Freddie Kirkland
  • 36 Answers
SOURCE: Power Up Problem
You have a 8.6v supply error according to the 7 error code being displayed, what you can try is when the set goes to blinking disconnect the Y sustain board (if looking at the tv from the back the board on the left) from the upper left side of the power supply, if the error code stops then you know your Y sustain board is pulling down your power supply and causing the error, if the error code continues you have a probelm with your Logic Board (located under your Small Signal Board) disconnect this from the Y sustain board and see if the error code stops if it does you know that the Logic board is bad, if the error code is still blinking then the 8.6v supply line from the Power supply is faulty and the Power Supply needs to be replaced
Posted on Aug 13, 2008
SOURCE: panasonic th-42px60u plasma tv not turning on
Power LED on front panel blinks several times, there is a delay, then repeats. After fiddling and fuming (mostly fuming) I found that changing the input signal source allowed the TV to be turned on. When I changed the input signal source back everything was ok.
In other words...
My TV is connected to my PC's video card via an HDMI connector. My card has 2 HDMI connectors. I moved the connector (the part that comes from my computer) from one HDMI out to the other. The screen powered up. When I changed the connector back to the original HDMI out I got my display back.
So yeah, try changing your input signal source. If you're using cable try switching to your Xbox/PS3/whatever, or vice versa. If you only have one possible signal source then I have no clue.
It's almost like the TV doesn't get any signal from the current cable then goes into sleep mode until it gets another signal. My problem had to do with me changing a bunch of sleep/timeout/screensaver settings on my TV/comp.
Hope this helps someone.
Posted on Mar 06, 2009
ginko
  • 19396 Answers
SOURCE: Panasonic TH-42PD25 power problem
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
ginko
  • 19396 Answers
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
When the TV goes on protection there are only two possible reasons.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Posted on May 21, 2009
  • 10 Answers
SOURCE: Sceptre LCD TV power come on, but there is no picture or sound.
There are two easy fixes you can try. Both require you to take the back panel off. If you are not comfortable doing this, take it to a repair shop.
UNPLUG IT.
Place the TV face down on a soft/solid surface.
After you get the back panel off, there are three silver boxes. There are white and black wires leading from the off switch to the top silver box. Take the cover off that box.
Inside is a ceramic fuse. Test that fuse. If it is blown, your local electronics shop can find a replacement.
If not, disconnect the white and black wires from the PC board. Remove the 6 screws holding it in place.
Look for scorch marks under the board.
Cut a thick piece of plastic and tape id down over the scorch marks.
Re-attach the board with the six screws and re-connect the black and white wires.
Turn the power switch to the OFF position and plug in the TV.
Turn on the power switch while WATCHING the board you just removed.
If you hear a sizzle, turn off the switch and get a thicker piece of plasic.
If not, the TV should come back on.
Re-assemble the silver box and put the back on.
Hope this helps.
Posted on Aug 09, 2009
I have pioneer plasma tv about 6 years old. I turned the power on, sound but no picture. Do you think it is worth fixing?
no
plasma tv units consume considerable power and the latest led units don't so for the extra cost of a new unit , there will be a power saving over the years
Jan 08, 2017 | Pioneer Televison & Video
Tip
Plasma -vs- LCD? Pros and Cons
If you're looking into a new TV purchase these days, you have only a few options… Plasma and LCD are major hitters. What follows is this professional’s opinion; you must ultimately do the research yourself.
Plasma TVs
Pros: Exceptional color reproduction. Our eyes have become accustom to viewing TVs with Phosphorus displays. As with TVs of old, Plasma TVs also use Phosphorus to create the beautiful colors our eyes crave. The viewing angle (side to side) and refresh rate (rate at which the image is refreshed) of a Plasma product shines above most other product types. Plasma TVs also have a glass protection screen in front of the panel which can help protect the panel from impact. Prices have fallen recently and have made the Plasma TV a very affordable purchase.
Cons: Energy usage. Using a Plasma TV has been likened to 'leaving the refrigerator door open'. Reliability and longevity are also a factor to consider. Over time, the Plasma panel becomes more sensitive; “Sparkles” or misfiring pixels are common. The Plasma uses many high power components; which, due to failure, have given it a less than reliable stigma. Image retention and image burn are quick to occur. Realistically, 5-7 years of life.
LCD TVs
Pros: Light weight and bright picture. Color reproduction has improved by leaps and bounds over the recent years. Some products available do rival the Plasma products in picture quality and reproduction. Cost cuts have also brought the LCD into the price range of many. Energy usage is typically less than that of the Plasma. Image retention is not a major concern for this product. Less parts than a Plasma = Less failure. LCD panel life is estimated to be about 10 years.
Cons: LCD panels use back-lighting systems. Because the 'color' of the light does not change, the color reproduction of the LCD product is not as natural to the eye as the Plasma product.
LCD-LED TVs
(Same as LCD TV, with the following exceptions)
Pros: LED back-lighting produces a more Plasma like color response.
Cons: Panel life is about 70% that of the standard LCD products.
on Apr 12, 2010 | Televison & Video
My lg plasma really flickers but it does this randomly. Sometimes it will happen all the time other days not at all. I have tried sorting the cables and unplugged etc. it is 10 years old but just wanted...
I suspect its a component (Capacitor) aging and eventually would need to be replaced. How do you have it connected? Is there a cable box or Direct TV receiver that you use to display TV Channels? If 10 years old does it even have an HDMI input? Should be very happy you got 10 years of life out of this Plasma. My thoughts is that it would take more to repair this than to purchase a new LCD or LCD/LED thinner TV. Plasma does have the best color but the LCD and LED TV's are much lighter/take less energy and are much brighter. Good luck.
Dec 10, 2014 | LG 42PX4DR 42 in. Plasma TV
Why does my Panasonic Viera VT50 have no picture and red led blinks 3 times
First thing, check the HDMI input and make sure it is firmly connected, same for the power cable, obviously. My Samsung goes similarly nuts if it detects no signal from the currently selected input but after 1-2 minutes it eventually stops and I can change the input source.
Aug 13, 2014 | Panasonic Smart VIERA TC-P55VT50 55" Class...
Panasonic 50" Plasma. Model: TH-50PE8U purchased in November of 2008 Recently has stopped working. Powers up but just has a black screen. Nothing comes up. Any suggestions as to what is wrong or how t
Do the power LED at the front panel light up, when you switch ON the set. If yes, the main board & sustain boards need to be checked. If NO; the main power regulator board should be replaced. In both the cases, it will be better to contact the authorized service center; especially to Plasma Displays.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 30, 2014 | Panasonic VIERA Televison & Video
What's better lcd or plasma TV?
Plasma TV's has a really rich, warm colors and deep blacks. It provides you with comfortable viewing angles that allow you to seat almost everywhere around the TV.
LCD TV'S are preferred in sizes less than 42 inches, and for users with lots of daylight viewing. If you're looking for ways to save energy. LCD TVs often consume less power than plasma models of the same size.
For more information visit http://www.crutchfield.com/Learn/learningcenter/home/tv_flatpanel.html
Jul 29, 2012 | Furniture
Sound but no picture; little red light showing instead of green led power indicator. less than two years old. original owner
Tv LED light indication"LAMP" is flashing or staying on?Yes 2 years old projection lamp and watches tv daily 4 or 5 hours a day?Yes,it is time to replaced the tv projection lamp.
Feb 18, 2011 | Mitsubishi WD 65837 65 in. HDTV
Tv turns it self off after only 2-3 seconds and makes crack noise
Since the set is less than 1 year old, it should still be under warranty. Request warranty service.
The noise you are hearing is probably arcing inside the set on the power supply board. Continuing to attempt to turn on the set will only make things worse. Please request warranty service as this is unusual for a TV that new.
Dan
Jan 16, 2009 | LG 50PB4D 50 in. Plasma HDTV
Haier 27 inch Flat screen Model: HFT27R11 Blank screen power led flashing with thump sound
seriously its a difficult problem, well sometimes the system control needs a heat-up by resoldering it. or caused by the flyback and the horizontal transistor. reply me if the problem persist. ^.^
Jan 22, 2008 | Haier HTF27R11 27" TV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
