Question about Briggs & Stratton Garden
Need to know how to wire a coil on a Diamond I/C 20 hp briggs & stratton motor
Where do you attach the black electrical wire coming from the coil?
    Problem Solver:
  • 11 Answers
Black wire should be an earth for the stop switch. needs to be attached to the switch but not directly to earth
Posted on Jan 13, 2014
panilling9
  • 284 Answers
SOURCE: hard to start 18 hp briggs &stratton
cold engine
loose .002 exhaust
loose .004 intake
be sure both valves are closed and you are on top dead center TDC of the compression stroke when setting
Posted on Jun 21, 2009
  • 3 Answers
SOURCE: Huskee 25 hp lawn tractor with briggs & stratton motor wont start
Most all manufacturers have the Users Manuel available on line you will need the Make and Model to pick the correct one. Have you replaced the battery. It can show the correct voltage but have no cranking amps. I believe if the solenoid is trying to engage the Dead Man switches are closed. With the starter disconnected from all power sources do the teeth on the starter turn or are they locked up? If they refuse to move do you have an Auto Zone around or another parts store or electrical engine repair store that can test the starter. Make sure the mowing deck is not engaged while you are trying to start the engine. I hope these rudimentary suggestions help.
Posted on Jul 18, 2009
  • 130 Answers
SOURCE: briggs & stratton 190707 wiring diagram
make sure your coil has not move ajust to 010. gap check magent on flywheel.see if strong.if all is ok yes coil is bad
Posted on Jul 22, 2009
  • 61 Answers
SOURCE: 5hp briggs & Stratton lawnmower
ck fuel pump its on the side of the carb
3or4 screws hold cover on .
Posted on Sep 06, 2009
miket756
  • 2702 Answers
SOURCE: My Briggs & Stratton Diamond I/C 13.5 HP has
it could be worn out piston rings letting unburnt fule past into the sump oil
Posted on Jun 20, 2010
Testimonial: "Thank you for theinformation. I did suspect it may be the Piston Rings but I always thought you would get heavy smoke from the exhaust if the rings were going??"
Engine wont fire....
There should be 1 black wire that grounds the coil(s) for kill. Be sure this black wire is not grounded when switch is in on or start position. It will be connected to the coil(s) at the flywheel.
Feb 10, 2013 | Snapper 21 hp* Briggs & Stratton...
I have a 20 hp briggs and stratton that wont get any fire
Check the diodes in the wires to the coils. Trace the wires from the coils, and they should join together into a single wire. In the junction of the wires, there is diodes. There is a possibility the diodes burnt out which will not allow power to the coils. My experience was when one burnt out and only one cylinder would run. I replaced the wiring and both cylinders worked fine.
Jan 30, 2013 | Briggs & Stratton Briggs Stratton Intek V...
18 hp briggs and stratton no spark
unplug oil senso still no spark un \plug shutoff wire to coil still no spark replace coil
Nov 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Jun 20, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
B&S 17 hp single it only turns over til it hits compression.. good battery,starter turns over another motor ,ground wire,whats up!
The connections on the starter solenoid coil are poor. this is the two smaller wires on the solenoid but all of the wires should be removed and cleaned well at least once a year or more often if conditions warrant.
Jun 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton wiring, can it handle an electric clutch?
You might have a capacitor in line with the clutch motor that requires feed from the engine to allow the clutch to engage. I think the red lead is charging current to the battery plus post. Get yourself a 270962 repair manual and it will show you how to wire these things.
Apr 13, 2010 | Garden
Garden Logo
57 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
