Question about Briggs & Stratton Garden
Need the wiring diagram for a Diamond I/C 20 hp lawnmower motor
Need to know how to wire the coil up
5 Suggested Answers
AUTODOC01
  • 216 Answers
SOURCE: Wiring diagram for 10 hp tecumseh motor.
no worries go to searsparts.com type in your model # and follow the prompts you can then print it out for free ?
Posted on Aug 28, 2009
Testimonial: "You made everything simple greeeeat.A++++++.Thanks Alot"
harlan301
  • 205 Answers
SOURCE: Need wiring diagram for Simplicity lawnmower
simplicity is owen by B&S power corp. there my not be a down load, your my have to contact a dealer or call magneto power or log on to there web
Posted on Oct 12, 2009
intower18
  • 957 Answers
SOURCE: need to wire 5 wire
Please try this link, this may help you. Just click_here so that you will be directed to the exact site. Thanks.
Posted on Sep 13, 2011
  • 6468 Answers
SOURCE: need wiring diagram for snapper mower model 260612t without electric star
don't have a diagram but i find the safety switch relay goes bad just disconnect it go right from the key switch to the engine just to test it of course also check the switch on the shifter handle
Posted on Apr 24, 2012
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
Need to know how to wire a coil on a Diamond I/C 20 hp briggs & stratton motor
Black wire should be an earth for the stop switch. needs to be attached to the switch but not directly to earth
Apr 20, 2013 | Briggs & Stratton Garden
Wiring diagram
the wires you have are a ground wire a charging wire if you have a charger and the coil plug wire on a short blocked motor you might have a secondary stop wire to
Mar 23, 2013 | Briggs & Stratton Briggs Stratton...
I need wiring diagram for Gould Century Pump motor 1081 Part # 8-142776-20 1HP 230v/120v
www.bestbuypoolsupply.com/media/motormanual.pdf
This manual has the wiring diagrams both hi and lo voltage for
part # 8- 142776 -20 gould century 1081m 1 hp , pool pump motor 230/115 volts.... plus several similar motors
May 25, 2012 | Plumbing
I need a three phase wiring diagram for 8145-20 model timer.
8145-20 240Volt Paragon timer is not 3-phase.
Clock motor is 240V.
You need a transformer to convert 3-phase to single phase 240V to operate timer.
Then timer outputs can control 3-phase power using 3-phase contactors
Contactor below is 3 phase with 240V coil
http://www.grainger.com/Grainger/DAYTON-Contactor-2UTP7?Pid=search
Defrost timer wiring diagrams show below:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
I have a gould century 1 hp motor i need it to run on 115 and it had previously been tried at 230,i had it running for a sec but it isnt right ......i need to know the proper wiring ....also it has 6 posts...
There should be a wiring diagram on the motor name plate. If it isn't there, there isn't much anyone can do, there are literally hundreds of different wiring methods for single phase motors.
Jun 11, 2010 | Air Tools & Compressors
Aug 27, 2009 | Garden
Garden Logo
21 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
