Question about Hardware & Accessories
The 64B 240v 50Hz 16A theben timer is not turning lights off
  • 5,245 Answers
Copy following link for analog 24-hour timer:
http://waterheatertimer.org/How-to-set-timers.html
Is this new timer, or older timer with worn-out trippers?
Or is this the theben digital timer.
Add a comment and describe timer in detail for more possible assistance
Posted on Apr 20, 2013
Can I purchase intermatic timer motor 240v 50hz P/N WG 1574 10D in Australia?
The motor will turn faster with higher frequency because the phase changes is faster. No damage to the motor. Just ensure that the voltage is within the operating range. Amperage kills the motor, subjecting high loads on it will eventually burnt it's windings and become expensive to repair.
Jun 10, 2016 | Intermatic EH40 240-Volt Electronic Water...
How to wire a theben 24hr timer
Generally theben timers are wired same as illustrations shown on following pages
Wiring varies slightly by exact model number.
http://waterheatertimer.org/How-to-wire-DTD-1440-timer.html
http://waterheatertimer.org/How-to-program-Hagar-timer.html
http://waterheatertimer.org/Din-rail-timers-and-manuals.html
Most these timers are rated 15 amp.
Safe maximum :: 15 amp x 80% = 12 amp
230V x 12 amp = 2760 watt
For best long-term result, use timer to turn on a contactor (relay) and let the contactor handle switching heavy amp load
Fuse-protect the timer by adding inline fuse to hot wire going to timer.
Gene
Jul 14, 2014 | General Electric GE 24-Hour Timer, 2-Pin...
INSTRUCTION BOOK FOR 16mm TQ3 Projector
http://www.texsales.com/proddetail.php?prod=OM1290
TQ3 (TQIII) Series
Filmosound Specialist See individual models above. Similar to 1592 series, except made in Japan for the UK market. Autoload. 240v 50Hz. Some models have magnetic sound.
Jan 23, 2012 | Cameras
The EES00 voltage is 220-240V 50Hz Our current is 220V 60Hz Can it be used?
usually it will work,but if it has a timer or clock on the unit the time will be fast due to the frequency difference,but all else should work fine
Mar 27, 2011 | Electrolux Cucina Pro 1711 10-Cup Coffee...
Do not know how to use Theben time switch.
I have theben timer sul181h. How to set it for lighting automatically at 6p.m. and stopping at 9p.m.?
Apr 30, 2010 | Hardware & Accessories
Dewalt Radial arm saw switch
try to find someone on craigs list or ebay selling one for spare parts.
Mar 23, 2010 | Saws
Samsung LCD TV series 5 240Vac, 50Hz will it work with 60Hz?
no only the voltage is critical.the only point is you have to select right counrty and tv sound and picture system on setup menu!
Jun 11, 2009 | Samsung LT-P227W 22 in. HD-Ready LCD...
50Hz to 60Hz conversion
Hi, Your idea is basically sound and should work as long as the UPS originally is designed to produce 240V 60Hz and has its own built in timebase. The reason is that the input as long as the voltage matches makes no difference (50 or 60 Hz). By design, the UPS converts the input voltage to DC to charge the internal battery. The battery then powers an electronic circuitry that produces the 240V 60Hz. The input is then isolated from the output in terms of frequency. This is a common design, however, there are some (not many) that uses for its local oscillation sampling from the source and therefore will replicate the input frequency to its output, but very rare; it's better that you know they exist. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards. P.S. The only problem with 50 and 60 Hz is heat buildup which is tolerable and still within safe parameters. The only time the 50/60 HZ makes a big difference is when motors are used, timers such as in the early designs of microwave ovens, washing machines, etc., pumps and other highly inductive consumers. Most electronic devices converts the AC input to DC and therefore the frequency has negligible effect. Of course others may see it differently.
Sep 15, 2007 | Liebert UPStation GXT2700RT-208...
Hardware & Accessories Logo
522 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
