Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon MP830 Scanner
I can't get my scanner to work and I didn't get an instruction manual or CD in the box. What can I do to make it work?
  • Anonymous Jan 30, 2009
    cannot communicate with scanner
    President:
  • 1,114 Answers
On the following link you can get manuals & software: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=12804
Posted on Aug 02, 2007
  • Greg Cann
    Greg Cann Aug 15, 2007
    Please provide some feedback so I can help you solve the problem.
    Were you unable to get the manual from the link I provided or is there some other issue?
    Best regards,
    Informatica.
SOURCE:
Hi is it possible to change the scanner lamp on a CANON MP830 ? TKS
Alas you cannot get the lamp on its own. The scanner comes as a complete assy under the part number QK1-2222-000.
Once you have the covers off its just a case of swopping the scanners over. there is no setup of the scanner. Its just works. Well hopefully...
Aug 19, 2011 | Canon PIXMA MP830 All-In-One InkJet...
The error message- Release the scanner lock- came on with the scanner UNLOCKED in the first place. I've troubleshooted and (flipped switch) unlocked scanner- several times- and turned MP830 off and...
I am not 100% sure on this but I do know that most printers and scanners when straight out of the box sometimes have tape or some foam that they use to keep the bits that move around from moving. I would check your manual from end to end and if you dont find anything in it then I would contact tech support for Canon as it may be that this is a bug of some sort that they may already have a fix for.
Jun 19, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Scanner not working
You need to check the operator's manual. For the messages it gives, there is usually a solution for it.
Nov 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
What canon printers/scanner/copiers are compatible with imac 10.5.5. MP830 is certainly not!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=12804#DownloadDetailAct
File Name and Description
MP780 Scanner Driver Ver. 12.13.0 (Mac OS X)
mp780osxsd12130ej7.dmg
MP780 Printer Driver Ver. 4.8.3 (Mac OS X)
mp780osxpd483ej7.dmg
PIXMA MP750/780 ScanGearStarter Ver. 1.0 for Mac OS X
MP750780SGS10MX_EN.dmg
Drivers
MP830 Scanner Driver Ver. 12.13.0 (Mac OS X)
mp830osxsd12130ej7.dmg
MP830 Printer Driver Ver. 4.8.3 (Mac OS X)
mp830osxpd483ej7.dmg
Software
Easy-PhotoPrint EX Ver. 2.0.1 (Mac OS X)
eppexosx201ea8-2.dmg
08/27/2008
MP Navigator Ver. 2.2.3 (Mac OS X)
mpnosx223ej7.dmg
Easy-PhotoPrint Ver. 3.7.0 (Mac OS X)
epposx370en.dmg
Firmware
File Name and Description Version File Size Date Posted
MP830 Firmware Upgrade Utility Ver. 1.13 (Mac OS X)
fump830osx113en.dmg
Guides and Manuals
On-screen Manual for Macintosh
mp830osmosx100us.dmg
User's Guide
mp830_ug_us_v4.pdf
Easy Setup Instructions
mp830_esi_us_v1.pdf
Nov 20, 2008 | Canon PIXMA MP780 All-In-One InkJet...
CANON PIXMA MP830 Error Msg: Scanner not working correctly.
the error message: "Scanner is not operating correctly." The scanner is definitely unlocked.
Nov 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp 830 getting error 5000
Canon site if the link does not work just go to canon.com -> support-> select Multifinction --> Inkjet --> Pixma MP830
Then type in - error code 5000 - (Leave off the " - "
Select #3 - ERROR LCD: Error code (5xxx through 9xxx) appears on the display -
1. Press ON/OFF switch to reset the multifunction device
2. Press Stop/Reset and ON/OFF to reset the printer
3. Removing paper jams MP800R / MP830 / MP530
4. The MP830 may require repair
5. Unlock the scanner lock switch (MP800R / MP830)
The links above detail each instruction. If they do not work here then got directly to the Canon Site.
Basically at one point there was a paper jam so clear it and then reset the machine.
Worked for me. Good luck to you :)
Oct 24, 2008 | Office Equipment & Supplies
Instruction manual
Open the top cover to the scanner, the lock switch is on the left hand side of the glass. It is about 1 1/2 inches oblong and SLIDES back and forth. The switch is black with 3 lines across it. Are you able to see it now? And your answer is ????
Brenda
May 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 wont scan
you have to use other programs such as photoshop to use the scanner
Mar 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanner lock is on
Do you not have a manual or 'get you started sheet?' It is the first thing you do when unpacking a scanner is to unlock the shipping lock. In all probability it is under the scanner base so if it is a lifting item[to access the printer] check there,or on the backplate of the scanner where all the sockets are. Failing that get onto the Tech support site at Canon.
May 16, 2007 | Canon MP830 All-In-One Printer
Scanner lock is on
the luck for a scanner is usually located under the device near whenr the head is parked. Have you looked. Check the manual Go to canon for Tech Help Take a look through this lot http://www.fixya.com/support/p466666-canon_printer_mp830_all_in_one/solutions
Canon PIXMA MP830 All-In-One InkJet Printer Logo
311 people viewed this question
Clive
Clive
old marine
old marine
