Question about FreeMotion HealthRider Stride Trainer 900 Elliptical Trainer
Squeak noise it made loud noise when the wheel spining
I n the spine cycle the washer makes a loud noise and shakes.I found a dime under the tube between the rim and door gasket.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 22, 2010 | LG WM2016C
WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on appliancepartspro.com
type in your model number.....
look for motor coupler
Oct 13, 2009 | Washing Machines
Washer makes loud humming noise when aggitatingand spining and shuts down
something is stuck in you water pump if removing object not stop noise then replace the pump
Aug 23, 2009 | Washing Machines
My camry is making a loud whining noise. I took it to a mechanic and he said it was probably the front bearings. The noise only happens when the wheels are spining. My question is how do I replace these....
Hi there. Most, if not all front wheel bearings these days are pressed into the front wheel hub assembly and to replace these is not normally a DIY job. Because new bearings need to be pressed into the hub assembly, a machine shop press ought to be used and the job undertaken by competent individuals. My advice if you do intend undertaking the work yourself is to remove the hub assembly and then have a machine shop operative remove the old bearings and have the new bearings pressed-in for you. Hope this helps, Scottech.
Jul 02, 2009 | 1996 Toyota Camry
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
When spining it makes very loud noise , like aeroplane when start
Hi.
It definately sounds like the drum bearings have failed.
It is a DIY job, but not easy, as it entails stripping the m/c down,
If it is under 5 years old, then it should be covered by a 5year warranty., you will just have to pay for the labour, certainly the cheapest option.
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
TV turned off and wont come back
looks like the color wheel its bad in the set,color wheel its not spining at its proper speed( one of the segments may be broken)
thats the vibration you are hearing.. and the set its trying to turn on..until you replace the wheel you will be able to watch tv again.
hdtvman
Jul 03, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung DLP HL-R5667W
Your set has a defective color wheel. This is the noise you hear and why the set wont even come on now. The colors were bleeding because the color wheel was getting stuck and when you hit the set you unstuck it. You need to call a tech to put in a color wheel the part is about 100 dollars plus labor.
Feb 05, 2008 | Televison & Video
Pav2300aww spinning very slow,and not draining
In all these Cases it sounds like a faulty lip seal. These special seals have Sealed bearings inside. Water gets through the seal and into the bearing which causes it to thump (like a helicopter) or squeal very loudly. As far as draining, the machine has to reach a curtain speed before the pump can turn fast enough to work.
Nov 02, 2007 | Maytag Performa PAV2200
FreeMotion HealthRider Stride Trainer 900 Elliptical Trainer Logo
23 people viewed this question
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
