Question about Ford 555 backhoe
655a ford diesel valve adjustment - Ford 555 backhoe
Drawing of a 655 a ford steering cylinder
google images "ford 655a steering cylinder" may have what you want.
Mar 11, 2015 | Ford Cars & Trucks
WHAT IS THE valve clearance adjustment OF ISUZU 6SD1?
valve clearences of diesels if not hydraulic operated will be .012" inlet hot and .014" exhaust hot
Dec 05, 2014 | Isuzu Cars & Trucks
Valve needs adjustment
Unless it's a diesel, there is no valve adjustment. The gas motors have hydraulic lifters and do not need valve adjustments.
Jan 08, 2011 | 2001 Toyota Corolla
I need the engine valve spec for a 1984 chevy 6.2 diesel. We are adjusting the valves.
VALVE ADJUSTMENTS All gasoline and diesel engines in this guide use hydraulic valve lifters, which require no periodic maintenance or adjustment. However, in the event of cylinder head removal or any operation that requires disturbing or removing the rocker arms, the rocker arms must be adjusted in order to position the pushrods to allow the hydraulic lifters to maintain zero lash. Refer to the valve lash adjustment procedure under Rocker Arms, earlier in this Section.
Aug 21, 2010 | 1984 Chevrolet K1500
Engine oil smoke blowing from exhaust. Renault Laguna Diesel.121,000 mileage.
first thing to check is oil level. some diesels will use some oil. if this is real heavy soot and moisture, it could be the fuel distributor/pump going out. how does it run? if its running poorly, this could be your answer. check the valve adjustment(lash) for proper adjustment also.
Feb 03, 2010 | 2002 Renault Sportwagon
6.9 litre diesel losing power over last few days of driving, changed fuel filter no difference,cannot get enough speed up to allow trany to shift, bogging bad. and blowing blue when reved, not black....
Blue smoke is oil. With blue smoke and no power you should take the truck to a diesel reair shop to have it looked at. It could be that the valves need adjusting or it could be broken rings or a cracked piston, all of which are beyond the scope of online diagnosis. With a diagnosis in hand, you should pick up a copy of Haynes Diesel Engine Repair Manual, part #10330. It can help if you think you want to attempt the repairs yourself. Hope this helps.
Nov 18, 2009 | 1986 Ford F 250
My valves are ticking on my 97 doge 2500 pick up it has the 360 magnum can i adjust them or not .....
Ticking sound is normal from a health diesel engine is normal.
Diesel engine that does a lot of towing or carry large payload can use a head adjustment every 2 years or 24,000 miles.
I would keep tabs on the valve cover for oil leak.
Take it in the shop when the valve cover start to leak.
Do the valve adjustment,the valve cover and oil change at the same time.
Shell ROTELLA T Multigrade SAE 15W-40 is my prefer motor oil.
Nov 06, 2009 | 1997 Dodge Ram 2500 Club Cab
Diesel leak on a 7.3L Power Stroke
you o-rings for you drain valv are leacing the yellow valve on side of fuel filter replace and you will be good ford sells o-ring kit
Oct 10, 2009 | 1999 Ford F350 Regular Cab
Where do i find the egr valve on a ford focus 1.8 petrol and can you describe it
egr valves are normally fitted to diesel spec are you sure its not a diesel?
Sep 25, 2009 | 2000 Ford Focus
There is a ticking/knocking noise coming from engine and the interior of car you can smell the diesel on ford fiesta 1.4dtci on 56 plate.
Have your valve clearance checked for that noise. As well as the diesel smell, fuel lines must be checked for
leaks. If your car is emitting heavy smoke, and it seems to loose power going uphill, your engine must
be due for overhauling. However, if your problem is just
knocking and diesel smell, valve clearance adjustment
and fuel line check up will correct the problem.
Sep 24, 2009 | 2007 Ford F
Garden Logo
82 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
