Question about Unitech MSR 206-33 (msr206-33) Magnetic Card Reader
Usb serial controller d - Unitech MSR 206-33 (msr206-33) Magnetic Card Reader
Ethernet controller and Universal Serial Bus (USB) Controller - The drivers for this device are not installed. (Code 28) What do I need this for, what can't I do or what goes wrong by not having these...
An Ethernet controller is a computer processing device used to handle network communications, and Universal Serial Bus (USB)
It can be used to connect keyboards, mice, game controllers, printers, scanners, digital cameras, and removable media drives, just to name, so i think you need booth device...install the 2 device? nothing it is goon to happen to your computer..
Sep 15, 2013 | Microsoft Windows 7 Home Premium Operating...
Can't read micro usb drive
error 43 is a usb universal serial bus controller problem
click start control panel administrive tools ,computer management ,device manager scroll down
universal serial bus controllers you should see a yellow question / exclamation mark? ! or a red X
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
for windows 7 you might try
First, please disconnect all USB devices. Then, go through the following steps:
1. Press "Ctrl + Esc" to open the "Start" menu.
2. Type "devmgmt.msc" in the Search bar and press "Enter". Click "Continue" if necessary.
3. In Device Manger, press Tab and use "Up" and "Down" to move the highlight to "Universal Serial Bus Controllers".
4. Press "Right" and expand it.
5. Press "Down" to move to the first item and press "Delete" to remove it.
6. Repeat the step 5 and uninstall all items under "Universal Serial Bus Controllers".
Then, restart your computer and Windows 7 will reinstall all controllers automatically.
hope this helps
Oct 14, 2012 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
TS4GJF300 USB not recognised error 43 occurs
universal serial bus controllers you should see a yellow question mark?
hope this helps
Aug 28, 2012 | Transcend TS4GJF300 4GB JetFlash 300...
My usb port do not work. It did not recognize any devise.
hello
Use Device Manager to disable and re-enable all the USB controllers. This lets the controllers recover the USB port from its unresponsive condition. The USB controllers represent the USB ports in Device Manager. If you are not comfortable with advanced troubleshooting, try the steps in the "Workaround" section.
To disable and re-enable the USB controllers, follow these steps: Click Start, and then click Run.
Note If you are running Windows Vista, click Start, and then use the Start Search box. Type devmgmt.msc, and then click OK. Device Manager opens. Expand Universal Serial Bus controllers.
Note You might have to scroll down the list to find this item. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled. Check the USB device to see whether it is working.
hope this helps
Jan 27, 2011 | HP Pavilion dv7-1240us Notebook
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Will not work in usb 2.0 but will work in usb 1.0
Connect the Player to the USB 2.0 port on the Comptuer then open the Device Manager and expand the "universal serial bus controllers" category.
Under the serial bus controller category, check if there is any exclamation mark visible. If there is any then right click on it and select Uninstall. Restart the Computer after uninstalling the device with exclamation mark. Restarting the Computer with the player connected will make the Computer recognize the connected player.
Furthermore, check whether there is any universal serial host controllers prefixed with "Enhanced".
If there is no Enhanced universal serial host controller listed under the "serial bus controller" category then it's required to install the USB 2.0 driver.
In this case, uninstall all the devices listed under the universal serial controllers category then restart the Computer to reload them automatically.
Sep 17, 2009 | Audio Players & Recorders
CANNOT DETECT THUMB AND USB MOUSE
Some times the USB controller are located in the Chipset, Look at you model of computer and see what you can find to download and install and/or provide a bit more info. computer manu, model, ect
You might try this work around:
  1. Click Start, and then click Run.
    Start, and then use the Start Search box. I know you are running XP however this may prove useful for all.
  2. Type devmgmt.msc, and then click OK. Device Manager opens.
  3. Expand Universal Serial Bus controllers.
  4. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it.
  5. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers.
  6. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled.
  7. Check the USB device to see whether it is working.
If the USB port recognizes the device and if you can use the device, you are finished
Good luck...please leave rating, thank you kindly
Apr 29, 2009 | Computers & Internet
Usb ports not working
  1. Checking USB device status in Device Manager
  1. Right-click My Computer on the Windows desktop and then click Properties.
  2. Click the Device Manager tab to display the Device Manager window as shown at the right. (For Windows 2000 systems, click the Hardware tab and then the Device Manager button.
  3. In the Device Manager list, click the + sign next to Universal serial bus controller.
  4. Verify that a USB host controller and a USB root hub are listed below Universal serial bus. image002.jpg
  5. If Universal serial bus controller, USB host controller or USB root hub are not listed, close the Device Manager and go to USB port incorrectly configured in BIOS
  6. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a yellow exclamation point, go to USB controller IRQ conflict
  7. If you have Windows XP, right-click the Host Controller and select Properties from the drop-down menu. If you see this status message in the Properties window: The drivers for this device are not installed (code 28), go to Windows XP USB 2.0 driver not installed .
  8. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a red X, go to USB controller or root hub disabled in Windows Device Manager.
USB port incorrectly configured in BIOS NOTE: The procedure in this section is intended for advanced users only. Incorrect BIOS settings could prevent your computer from starting or operating normally. If you are not experienced in making changes to your computer BIOS, consult your computer instructions or contact your computer manufacturer for assistance before attempting the steps below.
  1. Follow the instructions of your computer to view the BIOS settings. These settings are sometimes called CMOS settings or system setup.
  2. To view the BIOS settings, press a key, such as F2 or Delete, just after you turn on the computer. Instructions often appear on the screen briefly when you turn on the computer. Also check the instructions and manuals provided with your computer.
  3. Look for USB Interface or a similar setting in the Advanced Setup, Peripheral Configuration or another section of your computer BIOS settings.
  4. Follow the onscreen instructions or read the computer documentation to enable the USB port.
  5. Follow the onscreen instructions to save the new settings and restart the computer.
  1. USB controller or root hub disabled in Windows Device Manager
  2. Click the Device Manager tab. (On Windows 2000 and XP systems, click the Hardware tab and then the Device Manager button.)
  4. Click the line in the Device Manager containing the red X.
  5. Click the Properties button. (On Windows 2000 and XP systems, click Properties on the Action menu.)
  6. In the Communications Port Properties box, click the Resources tab.
  7. Re-enable the USB device by clicking the Enable Device button and follow the onscreen instructions.
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Via Vectro VT6212 adaptor not recognized by WindowsXP SP2
is the usb 2.0 card driver properly installed?,is there any conflict?
Feb 24, 2007 | VIA Vectro VT6212 (A62124) Serial Adapter
Unitech MSR 206-33 (msr206-33) Magnetic Card Reader Logo
Top Unitech Televison & Video Experts
Michael Galve
Michael Galve
Are you an Unitech Televison and Video Expert? Answer questions, earn points and help others
