Question about HP Mini 1000 Netbook
Bios application error 501 hp note 210-3000 - HP Mini 1000 Netbook
Bios 501
Please describe the error.
Jan 11, 2014 | HP Computers & Internet
Not so much a problem but got message printed out while trying to print a document. Unsupported Personality: UNKNOWN. Does this mean something I should be concerned with ??
An error page will print with the words "Unsupported Personality: PCL " in the upper left hand corner. The printers are host-based and do not support PCL printing; therefore, installing an alternate PCL5e or PCL6 printer driver will frequently generate this error condition. NOTE: This error condition occurs by design when an attempt to print with a PCL5e or PCL6 printer driver occurs and is NOT a bug within the product software. SOLUTION: Install the correct HP LaserJet Host-Based Printer Driver or the HP LaserJet printing system software for the product. These drivers are available for download from the HP web site. Click here to go to the HP web site drivers and downloads page. NOTE: There are several programs (such as accounting, invoicing, court documentation applications) that are 16 bit (DOS) programs with a 32 bit (Windows) overlay. Due to the nature of these applications and the associated Windows overlay, the errors may continue with the correct printer drivers. These applications do not typically support a host-based output device, and as such would not be supported in these environments.
Feb 24, 2010 | HP LaserJet M1522n MultiFunction Printer
Isass.exe application error
Try this do this when the bios is booting up before the windows.. press F8 then start windows in safemode with command and pronpt then after that on the blackscreen if command and prompt type this
chkdsk /f or chkdsk /r
then press enter
then press Y and enter and reboot the computer and wait for it to repair the errors
plese let me know it this work.
Feb 21, 2010 | HP Hewlett Packard Pavilion dv6000z PC...
Bios ROM checksum error (Compaq SR5237CL with M2N68-LA MB)
A BIOS checksum error can be caused by a nearly flat BIOS battery.
I would replace the BIOS battery first before attempting to upgrading the BIOS.
Some motherboard BIOS firmware is upgraded by running a program that has been copy to a DOS boot disk or the upgrage maybe done from within the BIOS setup. These firmware upgrage and instructions are on the motherboard WEB site, in your case the Compaq/HP WEB site. Make sure you select the upgrade for your model motherboard.
NOTE it is possible that if you make a mistake you could ruin your motherboard, if you are not sure seek help from a computer savy friend.
Use this link :-
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Sep 17, 2009 | HP Computers & Internet
HP DJ 1050C Error 08B003007A0462
System Error: 080001 (Non-Continuable)
Problem
Description:
PostScript Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you
Mar 12, 2009 | HP DesignJet 1050c InkJet Printer
HP Mini 1000 Netbook Logo
117 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
