Question about Linksys Wireless-G WPS54GU2 Print Server
Wireless franctic i purchased a lexmark x5470 and would like to go wireless will a linsky printserver work i do have all linsky modem and router or do i have to purchase a lexmark print server?
  • 12,061 Answers
Generally speaking any compatable wifi unit should work with any other unit.. In saying that yes it is "Better" to get all the same make if one can.. but not essential.
Posted on Aug 03, 2007
SOURCE:
Adding a desktop in bedroom that will NOT connect
PERHAPS DYNEX,AND LINSKYS ARE NOT COMPATIBLE,I WOULD GO FOR LINSKYS ANY DAY SO EASY TO CONNECT,TRY USING A WIRELESS ROUTER,INSTALL SOFTWARFE 1ST,NEVER HAD A PROBLEM WITH LINSKYS
Nov 29, 2009 | E-Machines eMachines Desktop PC
Print server for vista, D-link DI-704p
I can recomend to your network setup is WPS54GU2
Wireless-G PrintServer for USB 2.0
******************************** Before configuring the wireless settings of the printserver, make sure to know the following settings on your D-link router: SSID, and wireless security.
Configuring the Wireless Settings on the Printserver
The wireless settings of the printserver can be configured using its web-based utility. Make sure the printserver is set to a static IP on the network.
NOTE: Make sure the printserver is already working when hardwired to the Dlink router before attempting to use it wirelessly on your network.
Step 1:
Access the printserver’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the printserver's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the printserver setup page appears, click Wireless.
Aug 01, 2009 | D-Link DI-704P Router
My linksys srx200 doesnt seem to be responding to my laptop when
Try to reconfigure the printserver using the setup CD that came with it. Normally that will fix the problem. Make sure the driver of your Printer is installed first before running the printserver setup.
Jun 13, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Connect Lexmark X5470 via wireless router
I would like to inform you that Lexmark X5470 is not a wireless printer. However, if you want it to use wireless then you should have a Lexmark N4050e 802.11g Wireless Print Server.
Apr 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
XBOX 360 not connected to wireless connection on Linskys WAG54G2
You should enter the "Wireless MAC Address" of the XBOX and not just the "MAC Address". You can see it on the system info of the XBOX settings.
Jan 06, 2009 | Computers & Internet
Inability to connect to Internet
The easiest solution would be to use an ethernet connection. A second problem is probably on most cable modems you can either use a USB connection OR an ethernet connection you cannoot use both at the same time.
Dec 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Going wireless with Lexmark X5470
NO you cannot go wireless with the the Linksys wireless-G broadband Router WRT54GS for this printer, to check the wireless print sever you need to click on this link and then click hide/show additional results and it will cost you $149,
http://search.lexmark.com/printer/US/en/22N0000
instead you can buy a wireless printer from Lexmark X6570 which is also $149.
May 18, 2008 | Lexmark X5470 All-In-One InkJet Printer
MY WIRELESS LINSKYS HOOKED UP NOT FINDING MODEM/CANNOT CONNECT
You don't use a modem to connect with a wireless router. Connect an ethernet cable between the laptop and the router to ensure that both are working. If this gives you an internet connection then the commonest problem is an incorrect wireless key. Reset the key on the router then cut and paste it into the wireless network setup in the Control Panel. Wireless drivers are frequently updated and you should check for a newer driver.
Feb 02, 2008 | HP Compaq Presario C304NR Notebook
Wireless Printing
This model does not come with network printing as far as I know... you would probably have to buy a printserver
Nov 17, 2007 | Lexmark X4270 All-In-One InkJet Printer
Linksys Wireless-G WPS54GU2 Print Server Logo
85 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
