Question about Dishwashers
My maytag dishwasher model PDB2600AWX wont start and wont latch properly unless you push hard on the door I cant tell if the latch over the tub is bad or the latch in the door is bad or both
  • 1 more comment
  • ourspotdog Mar 12, 2009
    Please tell me the exact parts I need and how to disassemble the door
    Mr Socket gave me a ridiculous generic answer to my problem--Please tell me the exact parts i need and how to disassemble the door
    The warranty is not in effect
  • 478 Answers
The latch on the door is held by two screws loosen these adjust and then tighten, until you get it right, good luck.
Posted on Mar 12, 2009
    Novelist:
  • 166 Answers
first i will suggest you to check why the door is'nt closing properly, so pls check the following:
Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.just let know for nay updates....
  • 294 Answers
IT SOUNDS LIKE YOUR LATCH ON YOUR DOOR IS BAD OFTEN WHEN YOUR DISH WASHER IS DEAD THAT'S YOUR PROBLEM ITS INTEGRATED WITH YOUR DOOR SWITCH SO I'LD SAY THE FIRST THING TO CHECK IS LATCH TO YOUR DOOR
  • JEFFrey BAKER
    JEFFrey BAKER Mar 12, 2009
    The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
  • JEFFrey BAKER
    HERES WERE YOU CAN BUY A NEW DOOR LATCH IF NEEDING TO BE REPLACED
    http://www.repairclinic.com/Appliance-Pa...
  • 6,784 Answers
Hi, if the warranty is still good, i recommend returning this unit. this is a manufacturing flaw. bad design. this unit will not run unless it is securely closed. with this manufacturing flaw present, you will not be able to use correctly.
    Novelist:
  • 117 Answers
  • Dan Barton
    Dan Barton Mar 12, 2009
    Sorry above solution is incorrect since I first thought you were talking about a washer. As for your dishwasher:
  • Check for a blown fuse or tripped circuit breaker
  • Check that the dishwasher is plugged in securely
    or
  • Inspect the wiring connection to the dishwasher for burns or breaks.
  • Check the door latch
  • Test the door switch
  • Test the timer motor
  • Test the selector switch
  • Test the motor start relay
  • Test the motor
  • 15,935 Answers
CLICK HERE for a parts listing of your machine.
You will need to replace the door latch.
Disassemble and verify your broken mechanism.
Posted on Mar 11, 2009
My Samsung Dishwasher, model DMR78AH5 will not run. The heavy, delicate, quick and smart lights are permanently on. I cut off the breaker for one minute but that did nothing.
How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
www.partselect.com/Repair/Dishwasher/Will-Not-Start/
If your dishwasher won't start the problem could be the door latch or door latch ... On manual timer models the timer is used to supply power to the pump motor, ...Missing: samsung ‎dmr78ah5
Samsung Dishwasher Won't Start - Model DMR57LFS ...
www.repairclinic.com/...Dishwasher/...-/Samsung-Dishwasher-won-t-start...
The door latch ensures that the dishwasher door latches shut. If the door does notlatch properly, the door switch might prevent the dishwasher from running.
What to Do When the Dishwasher Won't Start - YouTube
? 5:43
https://www.youtube.com/watch?v=L-bMqVb9kX0
Aug 15, 2013 - Uploaded by doityourselfstan
The problem could simply be a blown thermal fuse inside the control panel. ... Maytag Dishwasher Repair ...
Dec 16, 2015 | Samsung Dishwashers
Latch isn't catching properly
Is the little switch that is in the door worn out. If the tip that pushes in is worn or broken the switch won't go in far enough to work properly. Also see if you have loose screws that will need tightening up.
Mar 14, 2015 | Maytag Dishwashers
Older model (unknown) Whirlpool Dishwasher. Door latch failure. Dishes trapped inside.
You may have to break the little handle off to open it and order a new door latch mechanism. Just be careful. This is a lip latch so it wont be hard if you can get to where the latch connects. Use the internet and model to order new one.
Jan 23, 2012 | Whirlpool Dishwashers
No lights present on a panel, doesn't start doesn't respond
make sure the breaker isn't tripped. If thats good it is possible the door latch isnt latching properly and the washer wont start when the door isnt closed
Jan 11, 2010 | Maytag MDB8601AWS Built-in Dishwasher
Maytag Model # MDB7600AWW door will not latch
double check door latch make sure connections are proper if right and still not working probably main board and panel
Apr 23, 2009 | Maytag MDB7100AWB Dishwasher
Maytag dishwasher MDB7600AWW handle
Welcome
At the site below is the diagram for the door latch and assembly.
You can order there too!
W10130694 HANDLE, LATCH (WHT) (Series: 10) In-Stock $ 16.75 99003347 LATCH ASSEMBLY (Series: 10) In-Stock $ 21.80
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 25, 2008 | Maytag MDB7100AWB Dishwasher
Maytag quiet series 200 won't start
Does it help to push it more tightly shut...or fiddle with the latch.
Mine is not running consistently unless we push the door shut tightly. Others here also report problem with the safety latch causing this washer to quit. May have to replace the part.
Oct 18, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Door Interlock switch Maytag MDB4100 dishwasher
If the door is not latching well enough try adjusting the spring on the tub it's the male part that goes into the door latch. If that doesn't help you need to replace the latch. It's inside the door. The switch is mounted to the latch in the door so to get to it you have to remove all the screws around the outside edge of the inner door panel. Unhook power before replaceing latch or switch!
Apr 23, 2008 | Dishwashers
Whirlpool g2p dwi
either the latch thats on the door is bad,,or the catch on the tub is out of line,,,now if the dishwasher door drops hard and wont stay up ..you need new door spring and the weight makes it pop[ open..
Feb 17, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Open Questions:
Dishwashers Logo
257 people viewed this question
Top Dishwashers Experts
