Question about Plumbing
Kludi mixer tap leaking - Plumbing
Methven beta shower mixer rose is leaking
the problem will be at the tap washer
replace it and the water will stop from the rose
Sep 23, 2016 | Home
How do I repair a leaking mixer tap?
take the set screw out and repair the plastic washers inside it
Aug 31, 2014 | Delta Bathroom Basin Single Handle Chrome...
How do I fix a leaking mixer tap?
This is a food mixer forum, not a plumbing forum so you may not get many helpful answers here. Try again.
Aug 31, 2014 | Food Mixers
Leaking sink tap base
If I understand this correctly, you will need to remove the tap handle, the surround which sits against the sink, then the tap body, then unscrew the spindle till it comes free, and replace the o-ring on the spindle.
If the leak is under the sink, or if it is a mixer tap, please clarify that.
Jan 10, 2014 | Home
Oliveri mixer taps
turn off the hot and cold water supply, place a container under the sink where the hose meets the Sink mixer.
release the pressure from the tap by opening the tap to let the water out.
use a suitable tool to undo the flexible hose from the underside of the tap, there should be a small "O" ring on it which you will have to replace as the "O" ring is possibly the cause of the leak.
Oct 01, 2013 | Home
Keeps dripping
HI, if you have changed the tap washers and they still leak, then the taps need reseating (which can be done by a plumber who has reseating tool). All the best.
Sep 04, 2012 | Home
Dripping from mixer tap in kitchen
This is a failure of the washer in the valve of the mixer tap. You can remove most of these to change the washer that is worn out. However even if the valve is faulty with a worn out thread the tap can leak.
Use the correct tool to remove , model not mentioned .
Jan 24, 2011 | Garden
I have mixer taps fitted to my kitchen sink which leak from under the mounting seal when the taps are turned on.when the taps are turned off the leak gradualy stops and the actual tap never leaks,do the...
It appears that the seal at the base of the tap is worn or the screw collar is loose - try hand-tightening it. It may cure your problem. Plumbers tape is a white tape that helps seal water pipe joints!
Oct 08, 2009 | Plumbing
Mixer tap makes a noise like a fog horn when cold water turned on
Usually happens when the stops and not ballanced(hot and cold pressures going to the faucet). Try ajusting the stops; open more on the hot or close more on the cold.
Feb 04, 2009 | American Standard Plumbing
Kitchen aid mixer leaking yellow oil is it repairable it still tu
It can be. This may require replaing the plate that the shaft comes through, since there is now enough play to allow the grease that is in the nead to leak through. You can find the parts online, but be ware, it involves tapping out pins and undoing many screws. Manuals are available online at Kitchenaid.com
Jan 24, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Plumbing Logo
54 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
