Question about Xerox Phaser 6600dn Color Laser Printer
Error 092-672 power off/on C error, check toner C & IU
Konica minolta bizhub 350 error c2557 setelah ganti toner. Help me, please....
Code
C2557
Description
ATDC Sensor Failure
- The scanning value of the ATDC Sensor is less than 7 % while the IU Motor is turning.
- The scanning value of the ATDC Sensor is more than 19 % while the IU Motor is turning.
Remedy
1 Check the UN2 connector for proper connection and correct as necessary. 2 Remove the Developing Unit from the IU, and then replace UN2. 3 Run F8. 4 Change PWB-A. 5 Change PU1N.
Jul 27, 2017 | Konica Minolta Office Equipment & Supplies
How do we properly shake the image unit of the Konica Minolta bizhub c203 to clear error message C-2558?
ugh sorry replace the toner hopper and all of the componets if a new iu dosnt fix the problem
Aug 18, 2014 | Konica Minolta Bizhub c203 Copier
F2-40 ERROR
I am assuming your copier is a mono copier only & not full colour, if this is so then the error code refers to a toner supply fault. If you remove the toner cartridge & gently shake it side to side, turn the machine off & then on, refit the toner cartridge & check to see if the machine has reset. If the error is displayed again you may have to replace the toner cartridge with a new one. Again, powering the machine off & on should reset the error message.
Hope this helps.
Aug 13, 2014 | Sharp Office Equipment & Supplies
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica minolta bizhub c450 error code c-2555
Yellow Imaging Unit Failure.
Take out IU-Y, shake it, check the toner layer, Re install it.
and see if improvement, else remove IU-Yellow
May 06, 2013 | Konica Minolta bizhub C450P Laser Printer
C2558
Error code relates to an out of range ATDC sensor level detected on the black I.U
It normally happens when customer does not replace the toner when prompted.
It can usually be cleared by opening and closing the front or right side covers thus allowing the machine to cycle and add toner until it reaches an acceptable level.
If not cleared after four or five attempts go into service mode and run tcr toner supply for black.(In Image Adjustment)
This will clear down the error
Or you may need to replace the black IU if that doesnt work.
Jul 24, 2012 | Konica Minolta bizhub C450P Laser Printer
Error code c0f30
SOLUTION: Check the amount of toner in the affected unit and if empty, check the alignment of the toner sensor actuator arm. It is possible that the arms may have been jarred out of alignment during shipment and fail to sense the low/empty toner condition. This in turn, causes the IU to drop below the proper toner-to-developer ratio resulting in C-0F3x codes. Once the actuator has been properly positioned, run ATDC toner supply until the T/D ratio comes back into the specified range.
hope that help
or try to reset the machine.........
Aug 06, 2008 | Minolta CF2001 Copier
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
Getting a error code C0F37 on a Minolta Dialta CF1501. What's the solution to solve this problem. Is it a Black Imaging Unit or ? Marino
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Nov 17, 2007 | Konica Minolta DiALTA CF910 Copier
Xerox Phaser 6600dn Color Laser Printer Logo
1,331 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
