Question about Magic Chef Refrigerators
Install pan drain on magic chef model rc24la-3aw
How to install new pan drain
3 Suggested Answers
miket756
  • 2702 Answers
SOURCE: Magic Chef Top Freezer. Drain water from freezer
the best way to clear the tube is push a lenth of curten wire up the tube from the pan end,,, or blow through it with comprest air
Posted on Nov 17, 2009
oldTech2332
  • 2341 Answers
SOURCE: magic chef model number CSB2323AR
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the lower right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Posted on Aug 07, 2011
How do I clean the condensate drain on a Magic Chef fridge mod #ctb1521grw
if not mechanically inclined, call service tech. you could clear by blowing condensed air from drain line outlet, or attempt to disassemble and clear drain from evaporator drain pan
Apr 01, 2015 | Magic Chef Refrigerators
Is the drain pan located above the compressor supposed to come out?
it can come out,,, normally does not. sure water is not leaking from door??
Sep 01, 2014 | Magic Chef Refrigerators
Where can I find out where the drain hose is located on my Magic Chef refrigerator?
It should be under the fridge. If you remove the lower acess panel on the back you should see a little tray wich is your drain pan. Mike
Mar 19, 2013 | Magic Chef Refrigerators
Magic chef model number CSB2323AR seems to be a defrost problem. Water accumulates at bottom of freezer then ices up. Is there a drain pan on this model?
Gene
Aug 07, 2011 | Magic Chef Refrigerators
Removing drain pan
Most Maytag unit have non-removable evaporator drain pans. And if they are removable, they are very difficult.
The model # you stated shows a part # 61004095 (est 70.00 - 95.00). Is there a issue with the pan, they usually dont need servicing. see attached
Ric
Mar 08, 2010 | Magic Chef CTF2125 Top Freezer...
Magic Chef DISHWASHER - mODEL du4k, STOPPED DURING drain cycle
I am assuming that the pump motor is bad, and since the unit is at least 15 years old (just guessing), we decided to wash the dishes by hand till after the holidays!!
Merry Christmas
Dec 09, 2009 | Magic Chef Dishwashers
Magic Chef Top Freezer. Drain water from freezer not flowing thru drain tube into pan. How do I get to the drain tube.
Nov 17, 2009 | Refrigerators
We have a Magic Chef CTB177GR refrigerator (no ice maker hooked up) that leaks...from where I don't know. I took off the lower back cover, it is dusty but no water present there. I pulled out the crispers...
Good day.
Water can only come from one place, where the frost is melted off the coil in the freezer during it's normal defrost cycles that occur daily.
Two styles. One style allows this condensed water to run down the back wall of the inside of the refrigerator, under the crispers and thru a hole in the bottom of the cabinet into a drain pan positioned
under the hole.
Possible missing pan, not positioned properly, or crack in the drain pan itself.
The other style drains the water to a hose mounted on the back of the machine, down and then into the pan.
Possible hose blocked, not connected properly, or the other items as described in first style.
It's a look-see type of repair.
Nov 17, 2009 | Magic Chef CTB1722 Top Freezer...
Need a site to order a new bread pan for model 310 magic chef I have looked everywhere and find nothing.
You can order through this sears web link.
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
Aug 04, 2009 | Magic Chef CBM310 Bread Maker
Magic Chef Side bye Side freezer started leaking
the drain line may be the problem. check to see if theres water in the bottom of the drain pan in the freezer compartment.
Mar 30, 2009 | Refrigerators
Refrigerators Logo
14 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
