My Grundig GUVP4200 plasma will not turn on
When i turn the tv on it clicks and the screen lights up (slightly) as if the power is getting to it but the standby light does not light up and i am unable to turn it on. The fuses in the back have been tested and they both work.
  • kellyw11 Apr 04, 2009
    worked out the PSU board had gone, managed to buy the part online for £85
  • 790 Answers
did you hear the sounds? or maybe you have defective power source in hot side..
Posted on Oct 02, 2007
  • 106 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Posted on Jan 01, 2008
  • 11 Answers
SOURCE: Non working TV, can someone help???
Replace Q8023 (top224y) which you will find is blown apart or it's shorted, and the Q1 (2sk2662) which would check to be shorted inside the heat shrinked wrapped board next to the blue relay and the smd zener diode ZD8018 (shorted) along with the ceramic fuse F8001.
I don't remember the value for the zener diode but there's lots of them with the same color code. You will have to take one of the others off to test on a resistor jig to get it's value.
The 2SK2662 is a cross for the original.
Posted on Apr 29, 2008
  • 1689 Answers
SOURCE: grundig plasma
There is probably a fault in the video processor, or there is a setting for the user colour temperature that is not properly set. Call the authorized service for advice on how to proceed.
Jerry G.
Posted on May 14, 2008
  • 135 Answers
SOURCE: Lg 42pc1da plasma tv wont turn on
will be a fault with either power or y-sus x-sus board is the tv still under warrenty if so request repair
Posted on Jan 18, 2009
My LG Plasma 50PK550 doesn't show a picture when I push the power button. It will also shut off when I push either the Input or channel buttons.
Main digital board fault. Check and replace the main digital board. Contact any service technician. If you wish to get more details visit the site linked here.
Jan 27, 2017 | LG 50PK550 50 HDTV Plasma TV
Blank screen panasonic plasma tv
Plasma screen expired how old is it how many hours function does it have ?
Nov 17, 2017 | Televison & Video
Grundig Xephia 42 in.stuck on stand by
Probably the internal power supply has failed.
Nov 22, 2013 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
Grunding TV not starting
Problems start from the power board.For easy fix, replace the board with the same type.Or if you didn't know what to do, call the Grundig Service Center for further assistant
Aug 23, 2011 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
Hi, Please somebody help me. I repair a faulty grundig plasma tv. At first it has no picture because the STK795-820 (YPPD) IC and the fuse was broken. I changed these and now it works, but the picture is...
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 30, 2017 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
Grundig Cinemo TV will not start
The power supply could be failing.
Jun 02, 2017 | Grundig Televison & Video
Grundig GU22 DVDP LCD TV. No image on screen.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 17, 2009 | Grundig GU22DVDPX 22 in. LCD TV
My Grundig tv turns itself off
Its Probably overheated.
happened to me before then i took to fixers and they changed some part and now its fine or if u have a warrenty call the manafactuarer
Dec 13, 2008 | Proton MM2701VT 27" TV
Power light for tv turns on but no picture and no sound comes on tv i have a 50 inch phillips plasma
Check your cables and TV input settings.  Can you get to the on screen menu?  Does anything appear on the screen when the tv is on?
Dec 06, 2008 | Televison & Video
Black screen
This denotes a power supply issue. I would venture to say that it is the part of the supply that controls the plasma ignitor if this is a plasma TV or if this is an LCD screen it is called the back-light and inverter circuit. The power supply board would be the chief culprit in this case.
I hope this helps,
Thank you,
Aug 21, 2008 | Philips 50PFP5332D 50 in. Plasma...
Televison & Video Logo
234 people viewed this question
Top Televison & Video Experts
