Question about Epson Office Equipment & Supplies
My epson wf- 2540 encoder strip is damaged what to do
Where can i find an encoder and how much will it cost me
aomcopier
  • 22 Answers
SOURCE: Lexmark 5150 All in One Printer - Encoder Strip
I hope this helps. There is usually a spring that holds the encoder strip on either or both ends. The have a hole that the spring is inserted in. The hole brakes and the encoder strip comes off. If you have all the parts including the spring you can modify the encoder strip by cutting a piece of strong tape to fit over where the strip was broken. I use packing tape. Poke a hole in it and reinstall encoder strip. You should also be able to buy a new strip but I am not sure. I also would go to an electronic store and find a tool to help. Buy a spring hook. It is designed to help push on and pull off springs and they only should cost a couple bucks USA. I hope this helps, Bill
Posted on Apr 01, 2007
  • 4 Answers
SOURCE: encoder strip part c8941-80005
an encoder strip is seriously easy to replace! the strip rides thru a sensor on the ink cartridge carriage. one end hooks on to a small "hook"" on the left side of the plotter. the other end connects to a small "hook" on the encoder strip spring which connects to the right side of the plotter. Most manufacturers consider anything inside the case to be "not user replaceable". but really, its harder to keep the pictbridge bezel (cover) from falling out than it is to replace the encoder strip.
in response to jktyler.. my 2 year old did the same. if the small slots on the ends of the encoder strip are broken, then the strip is definitely damaged.
Posted on Dec 10, 2008
  • 3 Answers
I tried for hours to reattach my encoder strip, and finally figured out the way to do it after reading many web postings, and my own trial and error.
The key is to use a "dental mirror" that you can pick up at a pharmacy or hardware store for about $5. (Perhaps a small compact mirror may also work.) And you need to focus light back there. (I used a head lamp.)
The problem is you just can not see the small slot through which the encoder strip must be threaded from the front of the printer. It sits in back of the ink cartridges. This thin slot "tunnel" goes though a rectangular piece of plastic. You can feel the rectangular piece of plastic in back of the ink cartridges, and looking with the dental mirror you can see how small the slots are on the right and left side, through which the encoder strip must be threaded. After "seeing" these small slots using the dental mirror, you then can feel them with the tip of a fingernail, and know exactly what you are aiming for as you then feed the encoder strip through. (It doesn't make any difference of you feed the strip from the left or the right, but the down arrow end of the encoder stip must end up on the right when you later attach it to the wire tab.) I fed the strip "blind" after I had formed a strong mental image of exacly what I was trying to do, and now being able to feel the small slot I was aiming for with the tip of a fingernail. (It is tough working in the small space in back of the ink cartridges, and if you have really big hands and fingers it may be impossible. I did not want to use forceps or tweezers because of a fear of damaging the encoder strip.)
The encoder strip then must be attached with the down arrow end on the right attaching to a flimsy looking wire on the right side of the printer. The left end of the encoder strip must be attached to a metal tab on the left side of the printer. You will need to hold tension on the encoder strip, and manually push the sliding ink cartridge back and forth out of the way as you attatch both ends.
(It's probably a good idea to gently clean the encoder stip of all your fingerprints and any smudged ink with a tissue after you get it back in place. Also be sure to clean the metal bar the ink cartridges slide back and forth on, so you don't get error message 0502.)
Be prepared for this to be a very frustating experience!
You will be maddened by how many times it will take to thread the encoder strip though the slot, how difficult it will be to catch the end of the encoder strip on the wire and metal tabs, and how you will have to figure out how to hold tension on the encoder strip so one end won't fall off as you attach the other end.
But once you use the dental mirror to see where you have to thread the encoder strip, and once you see the wire and metal tabs to which the ends of the encoder strip must be attached, then YOU CAN DO IT! It just takes persistance.
Posted on Jan 08, 2009
  • 3 Answers
SOURCE: Encoder Strip
freetek
  • 5568 Answers
SOURCE: I displaced the encoder strip on an hp Photosmart
Typically, HPs have one fixed hook for the hole at the end and for the other end, a spring steel piece with a hook. Take a good look at the carriage; it will have a vertical slot, located toward the innermost part of it through which he strip needs to pass. Either take the strip (clean it gently while it's out), push it through the carriage while it is centered and look along its possible path for the hook arrangements. I don't know your particular printer but some of them require removal of the case to access those points. If you have a longish tweezer, you may be able to fish it into place (using a flashlight) anyhow. Be sure to fasten the spring-end first since the fixed end will not give and you risk tearing the mounting hole otherwise.
Posted on Apr 22, 2009
My 4wd selector switch indicates neutral and wont switch out of it
I replaced the switch assembly. Approx cost $65.00. cured my problem.
Jul 13, 2014 | 1999 Chevrolet Tahoe
Tip
Faster Encoding on TMPG Product with their SpursEngine Plugin
I have been using TMPG Products by Pegasys for years now and I have just starting using their SpursEngine Plugin from Toshiba on v4.0 Xpress Encoding now super speed the process
You will need to buy the Pegasys Spurs Plugin costs around $50 (£33) and one of the following two cards
Leadtek WinFast Card
this is a bit costly at around $180 (£120)
Canopus Firecoder Card this is expensive costs around $480 (£320)
OR treat yourself to PC upgrade buy Toshiba Qosimo Laptop that has the SpursEngine included this way you don't have to buy one the add-on cards mentioned above.
Check out Pixmania Shop on e-bay for the best deals one the Leadtek WinFast cards or Innovative Solutions Shop for the Firecoder Bluray Cards at more that twice the price I don't really think that it warrants the purchase unless you intent to do this professionally.
on May 02, 2010 | Global Star Software TMPGEnc DVD Author...
Epson Stylus T13 Color Printer Time-Belt Problem
the problem you have is most likely to do with the encoder ( the part which tell the brain where the carriage position currently is-) this looks like a 5mm high strip of what looks like clear plastic tape running the length of the print platen and will pass 'through' the print head carriage.
if the carriage is unable to count its position it will repeatedly crash into the left most side at power up. try a damp ( with plain water) cloth and gently clean this 'Tape' - encoder being careful not to apply so much pressure as to clean the imprinted lines off the tape ( the encoding part of the encoder) if this does not cure your problem then you may need to blast the encoder sensor ( on the carriage) with compressed air to release any dust or foreign particles from the sensors vision. if that fails- suggest you scrap the machine as even the cost of the cheaper parts can cost more than an entire new machine- good luck
Jan 16, 2014 | Epson Stylus Office Equipment & Supplies
Brother mfc 240 unable to print error 50
This error is usually caused by the Carriage Encoder Strip being dislodged from
the sensor mounted on the Print Head/Carriage Assembly. The upper case assembly will need to be opened, and the encoder strip will need to be put back into place. Its also possible that the error can also be caused by grease or fingerprints on the Encoder Strip, even if
it is still in place.
I recommend you take it to a service center. Cost of repair should be no more than $65.00
Dec 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
1999 BRAVADA IS STUCK IN 4 LOW HOW CAN I FIX PROBLEM
Probably bad encoder motor on transfer case. Also, make sure GM Auto-TracII "blue" fluid only is in the transfer case. Many encoder motor get stuck in engaged position when they fail. Try "thepartsladi" store on eBay for lowest cost OEM motor, BEWARE AFTERMARKET!
Oct 19, 2009 | 1999 Oldsmobile Bravada
My poor olds!!
Possibly different tires sizes or bad speed sensors combined with a bad transfer case encoder motor? Try "thepartsladi" eBay store if you have to buy the encoder motor, beware aftermarket parts on Bravada!
Oct 04, 2009 | 2000 Oldsmobile Bravada
Encoder motor intermittent
The best solution for this problem is to replace your servo motor. In manufacturing operations, downtime
matters a lot since it reduces production. You may be
able to repair it, but there's always a chance that it will
bog down. It's already a 14 year old encoder motor.
Besides, it may cost you a lot to have this repaired.
Aug 06, 2009 | Plumbing
2003 Suburban with Red Neutral Light 4WD Indicator
8/19/2009 I had this problem and it cost me 2700.00 to repair the truck. The problem is the "encoder Modual" that controls the 2/4 system. Unfortunately I did not know and my rear end needed to be repaired. The encoder cost about 388.00 at the dealer, good luck
Jul 22, 2009 | 2003 Chevrolet Suburban 1500
Encoder strip
If you can access to the encoder strip, try to clean it by damp cloth or detergent liquid. Wipe it with holding the stripe along the way.
Apr 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
JVC GR-AXM17U
In the case the encoder position is not shifted
to the next point though the loading motor has
rotated in the unloading direction for 4 seconds
or more. This error is defined as [E02].
1. The mechanism is locked during mode shift.
2. The mechanism is locked at the mechanism loading
end, because the encoder position is skipped during
mechanism mode shif
Dec 13, 2007 | JVC GR-AXM17U Camcorder
32 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
