My epson wf- 2540 encoder strip is damaged what to do
aomcopier
  • 22 Answers
SOURCE: Lexmark 5150 All in One Printer - Encoder Strip
I hope this helps. There is usually a spring that holds the encoder strip on either or both ends. The have a hole that the spring is inserted in. The hole brakes and the encoder strip comes off. If you have all the parts including the spring you can modify the encoder strip by cutting a piece of strong tape to fit over where the strip was broken. I use packing tape. Poke a hole in it and reinstall encoder strip. You should also be able to buy a new strip but I am not sure. I also would go to an electronic store and find a tool to help. Buy a spring hook. It is designed to help push on and pull off springs and they only should cost a couple bucks USA. I hope this helps, Bill
Posted on Apr 01, 2007
  • 4 Answers
SOURCE: encoder strip part c8941-80005
an encoder strip is seriously easy to replace! the strip rides thru a sensor on the ink cartridge carriage. one end hooks on to a small "hook"" on the left side of the plotter. the other end connects to a small "hook" on the encoder strip spring which connects to the right side of the plotter. Most manufacturers consider anything inside the case to be "not user replaceable". but really, its harder to keep the pictbridge bezel (cover) from falling out than it is to replace the encoder strip.
in response to jktyler.. my 2 year old did the same. if the small slots on the ends of the encoder strip are broken, then the strip is definitely damaged.
Posted on Dec 10, 2008
  • 3 Answers
I tried for hours to reattach my encoder strip, and finally figured out the way to do it after reading many web postings, and my own trial and error.
The key is to use a "dental mirror" that you can pick up at a pharmacy or hardware store for about $5. (Perhaps a small compact mirror may also work.) And you need to focus light back there. (I used a head lamp.)
The problem is you just can not see the small slot through which the encoder strip must be threaded from the front of the printer. It sits in back of the ink cartridges. This thin slot "tunnel" goes though a rectangular piece of plastic. You can feel the rectangular piece of plastic in back of the ink cartridges, and looking with the dental mirror you can see how small the slots are on the right and left side, through which the encoder strip must be threaded. After "seeing" these small slots using the dental mirror, you then can feel them with the tip of a fingernail, and know exactly what you are aiming for as you then feed the encoder strip through. (It doesn't make any difference of you feed the strip from the left or the right, but the down arrow end of the encoder stip must end up on the right when you later attach it to the wire tab.) I fed the strip "blind" after I had formed a strong mental image of exacly what I was trying to do, and now being able to feel the small slot I was aiming for with the tip of a fingernail. (It is tough working in the small space in back of the ink cartridges, and if you have really big hands and fingers it may be impossible. I did not want to use forceps or tweezers because of a fear of damaging the encoder strip.)
The encoder strip then must be attached with the down arrow end on the right attaching to a flimsy looking wire on the right side of the printer. The left end of the encoder strip must be attached to a metal tab on the left side of the printer. You will need to hold tension on the encoder strip, and manually push the sliding ink cartridge back and forth out of the way as you attatch both ends.
(It's probably a good idea to gently clean the encoder stip of all your fingerprints and any smudged ink with a tissue after you get it back in place. Also be sure to clean the metal bar the ink cartridges slide back and forth on, so you don't get error message 0502.)
Be prepared for this to be a very frustating experience!
You will be maddened by how many times it will take to thread the encoder strip though the slot, how difficult it will be to catch the end of the encoder strip on the wire and metal tabs, and how you will have to figure out how to hold tension on the encoder strip so one end won't fall off as you attach the other end.
But once you use the dental mirror to see where you have to thread the encoder strip, and once you see the wire and metal tabs to which the ends of the encoder strip must be attached, then YOU CAN DO IT! It just takes persistance.
Posted on Jan 08, 2009
  • 3 Answers
SOURCE: Encoder Strip
freetek
  • 5568 Answers
SOURCE: I displaced the encoder strip on an hp Photosmart
Typically, HPs have one fixed hook for the hole at the end and for the other end, a spring steel piece with a hook. Take a good look at the carriage; it will have a vertical slot, located toward the innermost part of it through which he strip needs to pass. Either take the strip (clean it gently while it's out), push it through the carriage while it is centered and look along its possible path for the hook arrangements. I don't know your particular printer but some of them require removal of the case to access those points. If you have a longish tweezer, you may be able to fish it into place (using a flashlight) anyhow. Be sure to fasten the spring-end first since the fixed end will not give and you risk tearing the mounting hole otherwise.
Posted on Apr 22, 2009
Epson 2540 won't print,just cycles on start-up between scanning and shut off.I've unplugged it and restarted but same problem.
Someone at SuperUser contacted Epson and was told to turn off the WiFi router (break connection), then disable Google Cloud Printing. That had mixed results.
Others found it easier to disable WiFi on the printer, then disable GCP.
Dec 06, 2016 | Epson WorkForce WF-2540 All-in-One Inkjet...
How do I clean my Epson WF-2540 so that the paper is not pulled in crooked?
It sounds like your paper drive rollers are getting hard and losing their grip. I believe that the only thing you can do is replace the rollers. Not a job for the light of heart. I would probably just get another printer. Ebay - Craigslist - Letgo - Wallapop, just a few sites to check for printers.
Feb 02, 2016 | Epson WorkForce WF-2540 All-in-One Inkjet...
I have an Epson WF-2540 printer and there seems to be a problem with the print head-for example when printing an address it prints everything but the city and state line is smeared
Epson printers have a "maintenance" screen, part of the printer properties. Do a "head cleaning", and then a "nozzle check". The nozzle check should look like the sample you will see on the screen. this isn't uncommon, and that's why you can do the head cleaning.
Nov 15, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
How do I print 1 page out of several. Cannot find print preview
You can perform this function from the software program you are using. Place the page you want to print on the screen, then go to the print function. Look for something like 'Print current page", or if you have the page number, you can enter it in a 'print pages' box.
The printer will then print what you sent to it.
Feb 23, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
Epson wf-2540 cant scan forms
It simply means that the font is not on your computer - I have to assume (as you did not mention) you are using some form of text recognition software as the message would not appear if you were simply scanning anything as an image of the page.
Just use this link to download and install the Cambria font:
http://font.downloadatoz.com/font,58593,cambria.html
Note it gives instructions on how to do the installation!
Oct 01, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
Epson WF-2540 giving me a printer error and ADF light flashing
I would love to know how you reset the printer. My problem actually began after installing an ink cartridge.
Jul 20, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
Epson wf-2540 Scanner error
Hi Richard,
I suggest You Go to Official Epson Printer trouble Page For You Epson Printer Problem On Below Epson forum URL Link:
Epson WorkForce WF 2540 All in One Printer
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Epson Printer Support
Feb 11, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
jasbo
jasbo
