Question about Drive Medical pacifica elite nebulizer 18070 - 1 ea
How to put together a drive pacifica elite nebulizer 18070
I need a manual for my Respironics Inspiration Elite HS456 nebulizer. The motor doesn't sound right anymore and the Albuterol "foams." ???
I found an owner's guide for the Inspiration Elite here: http://justnebulizers.com/inspiration-elite.html . Look under the Additional Information tab. The direct link to the manual is http://justhomemedical.com/skin/frontend/v4/default/images/pdf/Inspiration%20Elite%20(J-REHS456).pdf . Under the Specifications tab, the model is listed as the HS456.
I hope this helps.
Apr 08, 2013 | Respironics HS456 Inspiration Elite...
There is no vapor coming out from the machine when we turn it on
check the medicine chamber for leakage or breakage if possible replace it
Jun 20, 2011 | Respironics Inspiration Elite Compressor...
No medicine coming out of nebulizer
Replacement of neb kit the most common cause. Try this first. Then get back with me.
May 31, 2010 | Respironics HS800 Disposable Nebulizer Kit...
Spider nebulizer 2.how to piece together
The long tubing should have a green end and a blue end. (If both ends are the same it does'nt matter) Now the little cup that holds the medication...look at the bottom of the cup. It should have a male connector (blue or green) take the end of the tubing that matches the color of the male connection and firmly plug them together. Hold the chamber/cup upright. If your unit has a little plastic diffusor, drop that inside the chamber. now locate the top af the chamber and screw it on. You should have a large whole the size of a nickle on top. This is where you squeeze the medication in. After putting in the medication put the mask(or mouthpeice) Firmly into the place where you put the medication into....and your peices should be assembled. Last thing is to plug the other end of the tubing into the machine itself and then turn on the power.
Nov 17, 2008 | Health & Beauty
Drive Medical pacifica elite nebulizer 18070 - 1 ea Logo
107 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
