Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Vacuum cleaner leaves behind black spots on carpet. Is it leaking fluid?
reddevil6
  • 1673 Answers
SOURCE: dust blowing out of my vaccuum cleaner
Usually when dust is blowing out it is caused by a clog, either the hose, or the dirt inlet down by the brush roll is clogged. Check them and clean them out and you should be ok.
Posted on Jan 09, 2008
SOURCE: Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Posted on Jan 14, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
  • 136 Answers
SOURCE: bissel carpet shampooer is not dispensing water
put it on the curb
Posted on Aug 26, 2009
Vac Belts
  • 701 Answers
SOURCE: my carpet cleaner (bissell proheat plus) is not
You need to replace the pump belt. Here is the belt you need:
Bissell ProHeat Belt
Posted on Mar 10, 2010
How can you clean spots off carpet
Office pros cleaning service is expert in carpet cleaning.They categorize our cleaning program depending upon carpet condition. Offer three types of carpet cleaning programs.
Steam clean/ Hot water extraction
Bonnet clean
Very low moisture encapsulation clean.
Office pros cleaning staff expert in spot and stain remove from carpets,use the green certified product for cleaning.So finnally I suggest for Office pros cleaning for remove the spot and stain from carpet.
Commercial Office Carpet Cleaning
Dec 30, 2013 | Vacuums
How to clean spots off carpet
It depends on what the spots. They may actually be stains. Spots will come out if you use the correct cleaning process and cleaners but stains are permanent unless bleached or dyed. If you are not sure it may be less expensive to call a professional carpet cleaner that knows what they are doing (not all of them do)
Kirby ultimate g vacuum cleaner (not the shampooer) leaving white marks/trails all over brown carpet
This is not a normal occurence...maybe something the previous owner did or used the vacuum on?? A KIRBY will not normally leave any marks on Your carpet..
Lee in Australia
Oct 14, 2012 | Kirby Ultimate G Bagged Upright Vacuum
How to fix Bissell ProHeat 2X 8300 carpet cleaner? It leaks cleaner fluid and has no suction.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
gkjkgj
Jun 01, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My Hoover SteamVac carpet cleaner leaks water
i have a hoover carpet cleaner and when it is not in motion it leaks water
May 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
The bissell proheat turbo carpet cleaner is not sucking up water.
heatman101
jer
Jun 08, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7920 Problem
heatman101
fghj
Jan 08, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Shampooer leaves spots
If the spots are NOT at the center of the unit - you may have washed the brush roll. Older style shampooer brush rolls could retain a lot of water and it is all dirty in there. NEVER wash the brush. Just after you are done - raise the nozzle and let it spin freely for 10-15 seconds. It will be clean most of the time.
If you already did or if you will absolutely have to do it in the future - do not soak it. Set it vertically somewhere so water could drain and leave it to dry.
Do not make sudden moves while shampooing so the water does not spill from the tray.
If you oiled Kirby some time or sprayed WD40 somewhere - maybe it is coming out now (do not oil Kirby - it does not need that type of maintenance)
Hope this helps
Nov 24, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
