Question about Rival VS107 Seal A Meal Vacuum Food Sealer
Sealer does not vacuum out the air from the bags,
My rival seal a meal does not vacumn the air out when it is sealing. what is the problem and how do I fix it
There is air leaking in somewhere. Make sure there are no wrinkles in the bag at the sealer location. Also, make sure the seal on the bottom of the bag is complete or the machine will simply suck air from the bottom and out the top. Make sure there are no food particles stuck in or to the sealer mechanism.
I don't have a Rival but have a Foodsaver vacuum sealer. If I have trouble getting the air to vacuum out, I remove the black foam seal from the machine, run it under water for a minute, shake off the excess, and reseat the seal. For some reason, the water helps create a seal. It also helps remove food that may have leaked onto the foam seal.
If the wire that heats and melts the bag is damaged, it may not be sealing the bag completely.
Jun 06, 2016 | Rival Kitchen Appliances - Others
Cannot get it to vacuum.
Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
Mar 07, 2016 | FoodSaver Food Saver Vacuum Sealer...
It won't vacuum. Why?
vacuum sealer won't pull vacuum - GardenWeb
forums.gardenweb.com > Garden Forums > Harvest
Nov 9, 2008 - I know many of you use vacuum sealers, so hope you might be able to help. I have a FoodSaver Pro Sport, it's probably about three years old.
How to fix Food Saver - Vacuum Sealer? - Instructables
www.instructables.com/.../How-to-fix-Food-Saver-Vacuum-...
InstructablesMar 2, 2012 - I have a Food Saver brand Vacuum Sealer, that all of a sudden stopped ... If it won't heat up to seal the bag, then you probably have a break in
vacuum sealers - Frequently Asked Questions
Feb 03, 2016 | Kitchen Appliances - Others
Foodsaver V3460 vacuum runs and sounds like it has reached the end of the cycle then seals bag.
then you do not have the bag in proper place in the sealer , mine has never failed .
Aug 05, 2015 | FoodSaver V3460 Vertical Vacuum Sealer,...
Why is my Foodsaver V2440 motor noisy while vacuuming bags?
This is normal it means that its just pumping air out of the bag but if it gets too loud and its not pumping air out of the bag then you might need it looked at soon
Jul 12, 2014 | FoodSaver V2440 Advanced Design Vacuum...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
When vacuuming out air, the liquid is vacuumed, inside of the bag where it seals is wet, and it won't seal.
Try placing a folded paper towel in the bag between the item and the area of the seal
The towel will absorb the liquid allowing the bag to seal but keeping the liquid in the bag
Feb 05, 2011 | Rival VS230 Seal A Meal Vacuum Food Sealer
How to operate a Salton vacuum bag sealer?
HOW TO MAKE A BAG
1. Place the BAG SEALER on a firm level surface adjacent to a power supply socket. We suggest the bag sealer be positioned away from the edge of the work surface allowing plenty of clear space for making the bags.
2. Take the polythene roll and insert it in the trough in the sealer, positioning it so that the film is pulled of the roll from the underneath.
3.Polythene roll supplied by Salton (Cat No. 1121) is a high grade film suitablefor use in a microwave oven, boil-in-the-bag cooking and for storing in the freezer. Replacement rolls are obtainable from stockists, or in the case of difficulty, from Pifco Servive Department.
4. Plug in to mains supply socket and switch on.
5. To make the first seal on a new roll of polythene, lift up the cover and pull out enough film to project an inch (2.5 - 3 cm) or so outside the casing.
6.Now press the lid down firmly so that both the red and green indicator lights come on. In a short time - approximately 6 seconds - the green seal light will go out. AS soon as this happens lift the lid and peel of the film.DO NOT ATTEMPT TO PEEL THE FILM AWAY BEFORE THE GREEN SEAL LIGHT GOES OUT.
7.NOTE - when closing the lid and applying pressure two distinct clicks will be heard.
theses are the switches which operate the two functions of the BAG SEALER.
First click - Operates the air extraction motor. Vacuum light (RED) ON.
Second click - The sealing wire is energised. Seal (GREEN) and vacuum light (RED) both on.
8. We suggest that you famillarise yourself with the pressure mechanism before you begin using your BAG SEALER. It is perfectly safe to operate either the seal or vacuum functions with out using any polythene roll.
9. After several uses deposits of polythene on the sealing wire can reduce the effectiveness of the seal. Theses deposits of polythene can be removed by operating the seal mechanism without any polythene across the wire.
10. Having sealed one side of the bag, pull out the film to the desired bag width (MAXIMUM WIDTH is 2.9 cm / 11 1/4 inches) and seal again by closing the lid and pressing down hard.
11. As soon as the Green seal light goes out, lift the lid and peel the bag away. Ensure no film adheres to the sealing wire.
12. This seal creates your first bag and at the same time the first seal for the next bag.
SEALING A FILLED BAG (WITHOUT AIR EXTRACTION)
1.Make sure that no food or liquid remains in the top portion of the bag close to where the seal will be made as this may effect the effectiveness of the seal.
2. Place the open end of the of the bag over the sealing wire making sure that the film is flat WITH NO FOLDS OR CREASES ALONG THE LINE OF THE SEAL.
3.Close the lid and press down firmly to make the seal.
EXTRACTING AIR FROM A FILLED BAG.
REMEMBER: Do not extract air from bags containing liquid !!!
1. After filling the bag and making sure that the sealing area is free from food particles, place the open end of the bag over the sealing wire and place the black air extraction nozzle well inside the bag. It is important to ensure the the two edges of the bag under and over the nozzle are straight and not creased in any way to ensure an air tight seal !
2.Depress the lid gently until the red light comes on and hold this position to operate the air extractor. (DO NOT press so hard as to activate the the green light and therefore the sealing wire).
3. As the air is being extracted it is sometimes of help to hold the bag with your hand and gently move the contents around to help channels of air to form, so aiding extraction. Depending on the the nature of the porosity of the food some unavoidable air pockets may form but moving the contents around these can be minimised.
4.Once all the air has been extracted increase the pressure on the lid until the green light comes on. This must be done in one continuous movement, otherwise the air might seep back into the bag. Once again the bag should not be pulled away from the bag sealer until the green light goes out. Pressure on the lid should be released, the lid lifted and the bag peeled away.
LAMSBREAD :)
Sep 27, 2009 | Kitchen Appliances - Others
How do I work a Salton vacuum bag sealer (Model BS-20)? I can not figure out how to get the air out of the bag.
This style of vacuum sealer has to use a special bag with a " dimpled " surface to let the air escape through the pinch jaws of the vacuum sealer.
The folowing web site has bags and rolls that can be cut ro make any size of bag you require. You can buy on line direct from the manufacturer as well as purchase more industrial vacuum packers
http://www.foodmc.co.uk/Category/113-textured-bags-for-external-bag-machines.aspx
Jun 14, 2009 | Vacuums
Rival VS107 Seal A Meal Vacuum Food Sealer Logo
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ed Mac
Ric Shull
Ric Shull
Level 1 Expert
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
