Question about Ricoh Office Equipment & Supplies
Error code E5 41 on Ricoh copier model 4527, or FT 4527
The copier won't work now that the error code E541 has appeared. The copier worked fine until it was moved and then started getting this error.
It is a fuser error (low warm up temp), often caused by fluctuating voltage.You have a blown fuse, lamp, or thermistor. Can only be reset in service mode after the problem is solved.
Posted on Mar 12, 2009
How do I clear error code sc542 on model 3510sf
go to maintenance mode. press clear/stop press 1 0 7 and start key(hold) until maintenance mode is displayed. look for fuser SC reset.
Sep 18, 2014 | Ricoh Aficio SP 3510SF
Error code E541
Ricoh Copier Error Code SC 541 is Fusing thermistor open problem
1. This is Open Thermistor problem
2. Thermistor connector is bad.
3. Thermistor is broken, or out of place
4. Fusing temperature -15% less than the regular input voltage
Might be a one time failure you can reset. Access service mode and reset the code then power copier off & on again. If problem goes away your good. If not.....time to replace the fuser.
Jul 27, 2012 | Ricoh Office Equipment & Supplies
How do i clean a ricoh ft 4527 copy machine
start with the optics, corona wires, use the vacume cleaner, alcohol, water,...
Jan 05, 2010 | Ricoh CL4000DN Laser Printer
My b/w copier suddenly stop working when an error code sc545 appears on the screen and since then it has refuse to work. The moment you turn it on the functional problem error code sc545 appears on the...
You need to check 3 cause for that error:
- hot roller thermistor out of position
- fusing lamp broken (can you see the lamp going on at startup?)
- thermostat broken
If you are just a user, without any technical knowledge, i advise you to call a Ricoh Support Service.
Aug 03, 2009 | Ricoh Aficio AP410N Laser Printer
Error sc 547
Found this from:
http://slayo.com/ricoh-cl4000dn-error-code-sc542.html
Ricoh CL4000DN Error Code SC542
Turns out error SC542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won’t come ready until the prior error condition is cleared.
A few phone calls with our local Ricoh service rep, and he admitted that the printer might trip this error in a power brownout.
The printer was less than 30 days old and the error was caused by the brownout or the fuser failed. I kept calling the Ricoh rep, and they finally gave me the magic keystrokes over the phone.
I did the magic keystrokes, cleared the error code, and the printer worked fine. It’s been working great for a year now.
I hope someone else who has this problem finds this page and is able to fix the problem also. I didn’t find any help on the net when I searched.
The Fix In order to clear error SC542, you must perform procedure 5810.
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
The error code is now cleared.
Hope this helps!
WizardRepair
Jul 17, 2009 | Ricoh CL4000DN Laser Printer
When i on the machine e-5 error appear and machie not working
What model? AND you need to press the "." key to get the complete code?
However... "E 5xx' " is a fuser code and will not go away until it is fixed and reset in service mode.
"E 1xx" is a scanner code, which means it is either a lamp, fuse , home position sensor...etc.
Mar 19, 2009 | Ricoh Office Equipment & Supplies
Ricoh FT-4527, E541 error. I know that the hardware relating to this problem is the fuser, lamp, fuse or fluctuating voltage, but I don't know the key strokes to remove the error code after the part has...
....Nor do you have the parts. I answered you earlier today. If it were a simple fix/ adjustment I'd be happy to provide it. You need a trained technician, and only technicians will have the codes. You can find yourself in even bigger difficulty messing with service procedures that you know nothing about...cut your losses.
Mar 12, 2009 | Ricoh Office Equipment & Supplies
What is the sulution for e541 copier machine ricoh 5832
SC 541 indicates a problem with the heating unit thermistor in the machine.
This type of inquiry requires service support from your local authorized dealer or original point of purchase. This type of service code can not be reset by the user for safety reasons.
Feb 23, 2009 | Ricoh Office Equipment & Supplies
On a Ricoh FT 4415 copier, what does error ''E2'' mean?
Hello,Check out this site and see if any of these error codes can help you: http://www.copier-help.com/copier-help/
Have you checked the power fuse? Or have you looked at the incoming power circuit board. Could there be any burnt resistors, blown capacitors, or bad voltage transformers?
Check things out because many times when a machine doesn't even power on (no lights, no life) - it's usually a sign of something blown - fuses, circuit board, lamps, etc. Hope this helps.
Dec 11, 2008 | Office Equipment & Supplies
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
679 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
