Question about Compaq (162857-001) Motherboard
K2-gl6e motherboard layout - Compaq (162857-001) Motherboard
Cant log in
If you can't log into your gmail, due to incorrect password, or username, got here: Having trouble signing in. This will allow you the recover and reset the password.
Feb 04, 2015 | HP 5188-1749 Compaq Motherboard Gamilla2...
Need motherboard compaq SR1630NX
This is a ASUS A8AE-LE, HP/Compaq ref: AmberineM-GL6E, HP part number 5188-2526
Jan 24, 2013 | HP Compaq Presario SR1630NX PC Desktop
I am having trouble with the hard drive hanging while booting up Ubuntu 10.10 from a Maxtor DiamondMax 16 hard drive (4R160L0) attached to the primary IDE port on a K2-GL6E Compaq mother board. The drive...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 11, 2011 | Compaq (203966-001) Motherboard
Cuantos es maximo de memoria para una compac presario300+
Debes checar ud. el modelo de motherboard. Si es Salmon-GL6E, el maximo es 2GB.
Mire aqui.
Suerte
Jan 18, 2011 | Compaq Presario SR1475CL Athlon64 3400+...
Hello respected person, i need free download VGA driver for K2-GL6E. this is a compaq presario 5056 desktop motherboard. Pls. help me.
Compaq Presario 5056 Drivers
Please visit the above link from Official HP Compaq Support and download the drivers.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 17, 2011 | Computers & Internet
Need the pin assignments for the mother board
On most motherboards the front panel connections are printed in the connectors on the motherboard. When you connect the various LED indicators and when you power up and they do not light up then just switch the connectors around, because they are are polarized.
You can go to the motherboard WEB site (ASUS) to download a manual, the manufacturer and model number is printed on the motherboard.
Jun 28, 2009 | HP Compaq Presario SR1420nx...
Motherboard
Try adding and removing hardware from the HP website:
Or look up the mother board on ther ASUS  website: ASUS CUW-AM
HP/Compaq name: Amberine-GL6E
http://support.asus.com/download/download.aspx?SLanguage=en-us
http://h10025.www1.hp.com/ewfrf/wc/product?product=81921&lc=en&cc=us&dlc=en&submit.y=3&submit.x=4〈=en&cc=us
Jan 24, 2009 | HP Refurbished MOTHERBOARD (SYSTEM BOARD)...
I was adding a 512MB card to a Compaq Presario that has an ASUS K8S-LA (or Compaq motherboard: Salmon-GL6E) and discovered what looks like a heat sync loose inside the case. I can see where is was...
The ASUS K8S-LA main board has a variety of chips on it, however only the CPU is large enough to justify a dedicated heat sink.
The most likely location that your rogue heat sink is came from is your video card's processor. I'm lead to believe this for 2 reasons- 1) you say that the CPU heat sink is still in place, and it is the only heat sink on the main board, and 2) the location you described as to where you found the heat sink would be consistant with it falling off the video card (located in the AGP slot, directly below the cpu with the external ports facing left).
Below is a link on the HP website to the layout / photos of your main board which were referenced in this solution
Click Here
This is actually very serious if it is the case as it could lead to rapid failure of your video card (or whatever card it goes to if that is the not the location). There are several guides available on the internet for "cleaning" heat sinks which will serve your purpose of reinstalling yours once you find the location.
Hope this information was helpful, please don't forget to rate my solution.
Jul 07, 2008 | Computers & Internet
Installing a k2-gl6e, or trying..
K2GL6E SUPORT AUDIO DRIVER NAME
Jan 27, 2008 | Computers & Internet
Compaq (162857-001) Motherboard Logo
67 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
