Question about John Deere Garden
John deere x300 wont go forward or backward
Mower will not go forward or backward with the motor running. The free wheeling lever is pushed in.
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
  • 3 Answers
SOURCE: john deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
Posted on May 26, 2009
nova2nv
  • 197 Answers
SOURCE: our john deere sabre 17.542 hs ride on mower will
If traction drive belt is turning you should check the input drive shaft on top of trans to see if it is turning as well,Traction drive belt is suspect but could be a stripped out input shaft pulley.Make sure the machine tow lever is not pulled out,rear of machine by tow hitch.Also pull rubber caps off of both axle ends to see if one the axles is turning free inside of rim,if so remove wheel and replace axle key.
Posted on Nov 15, 2009
6ylucy
  • 742 Answers
SOURCE: manual for john deere sx95
ask manualfox.com - they have it.
Posted on Apr 19, 2010
  • 420 Answers
SOURCE: john deere 300 garden tractor will not go forward or backwards
Make sure the neutral lever (rod) back by the right rear tire is pushed ALL the way in.
Posted on May 27, 2010
Have a John Deere 575 skid steer that the left wheels will creep backwards.
check for problem control valve for that wheel
valve not seating properly allowing pressure through to the drive motor
Jan 10, 2017 | John Deere Garden
The right rear wheel intermittently locks up on my lawnmower when going forward stopping forward movement temporarily, until I move it backwards to "unlock" it. Any ideas?
There is an excellent 3 part video that may help you to fix this problem. Please see the 2nd and 3rd videos:
https://youtu.be/Vk_tpjKlbjM
https://youtu.be/DdiewLxTQDc
Things you can try:
(1) Remove casing over rear wheel drive assembly and perform a test run to assure all parts are moving as expected
(2) Lubricate the shafts with lightweight motor oil where the shaft penetrates into the gear box of each wheel
(3) Remove each rear wheel, inspect gears for damage and free movement. Grease up each drive gear and the shaft.
(4) Inspect gears on each wheel for damage.
(5) If none of the above fixes the problem, try swapping out the front wheels to the rear wheels provided the front wheels can accommodate the gearing on the rear wheels
(6) If this doesn't work try replacing the small gear assembly on the right rear wheel
These steps are illustrated in the videos.
Good luck and hope this helps.
Oct 11, 2016 | John Deere JA65 Self Propelled Mower
John Deere x300 want go forward are backward and the lever is all the way in also when you pull it out it doesn't go into neutral
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
JOHN DEERE X300 SERVICE REPAIR MANUAL
Oct 29, 2015 | John Deere Garden
John deere d140 ont move
there is a small handle on the back of most riders allowing you to free wheel the machine. If you can push your machine freely now then push the handle in and it should drive
Aug 04, 2014 | John Deere Riding Lawn Mower. D140 48 in....
Hello. My x300 john deere ride on mower starts but will not move. The lever at the back is pushed in where it is supposed to be. can you plese help?
There is an adjustment that tightens the drive belt. This is the drive tensioner pulley. If you need a schematic or instructions on how this is done, go to John Deere dot com and they will have repair manuals and parts schematics.
May 10, 2014 | John Deere Garden
John deere x300
The hyro unit has two cylinder blocks, a variable displacment pump and a fixed motor block, you should always mark the top of the pump thrust housing as this can be put back unside down which will result in what you now have.
Dec 15, 2013 | Garden
JD SRX75 - when push lever forward or back, tractor does not move..
check the lever on the rear of the tractor used to puch the unit when not running then check the belt
Mar 31, 2012 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
I have a John Deere LT155. When you let off of either the forward or reverse pedal the tractor comes to an abrupt stop. It will actually lock the wheels.
Hi, most likely the brakes are hanging up. Follow the brake pedal path to the rear of the mower, it is attached to a small arm on the side of the diff that is probably locked forward. This lever and the pins behind it need to be freed up so the lever operates forward and backward freely when the brakes are applied and released. Hope this helps, regards Phil.
Jun 01, 2011 | John Deere 22HP VTwin Hydrostatic 42"...
I have a 2008 John Deer X300 riding mower. I parked it and when I went to use it the next day would not move forward or backwards. It is hydrostatic. What could it be? How do I check fluid for hydrostatic?
Sounds to me like your hydrostatic control lever has became disengaged. If you had a fluid problem yuou would probably find fluid on the ground or within the tractor chasis somewhere. I,d check the linkages for your problem. Also make sure your parking brake is released.
Sep 13, 2010 | John Deere Garden
Garden Logo
388 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
