Question about Emerson Microwave Ovens
No power stoped workin last night whe i enter time and push start two light come on [red] microwave indicator and high cook indicator
  • 10,865 Answers
To enter the time you must push the clock button once before you enter the time and again after you enter the numbers. Try that and you should be all set.
Please mark this as a fixya! thanks.
Posted on Mar 12, 2009
How do I change the power level?
Usually, power level is selectable using the keypad.
Jan 03, 2016 | Samsung 1.8 Cu. Ft. Over-the-Range...
We have a Frigidaire FMV156DCC that is about 3+ years old. as of last night when the door is closed and the time is selected one of 3 things happen (or doesnt happen) 1. is nothing, just a dark...
I would replace the door switches and set up the door gap to 1/8" just enough to alow for a little play.
Setting the door square is acheived by slackening the lower door hinge and re tightening it when the door is square.
Hope that helps.
Jan 03, 2011 | Frigidaire FMV156DC Microwave Oven
While cooking the microwave stoped workin. no
There is probably a fuse inside that you can replace (unplug before opening case). If after replacing it blows again, you'll need to test for a short (control, magnatron, diode, capacitor, among other possibilities).
Oct 21, 2009 | Microwave Ovens
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
Howm do I reduce power down to 50%
First enter the cooking time just like normal, but then you hit the power button and then hit the digit indicating the power level you want. THEN hit start and it will start cooking.
Mar 08, 2009 | Danby DMW119 Microwave Oven
Old Quasar (Panasonic) Microwave won't work
I believe you need to set the clock on that before it will take cook programing. So Push the clear pad then push clock, Maybe clock twice. Been a while sorry!! set the time and I think you have to puch clock again, for it ro start the clock or start. As long as you do not puch cook then any time pushing start should only start the clock. That should do the trick. Good Luck!
Oct 19, 2017 | Microwave Ovens
Not heating up
Typically, no heating of food, indicates a bad Magnetron (tube) or associated components. The oven can be repaired. Magnetrons are not hard to replace and can be ordered online through MCM electronics www.mcmelectronics .
However, due to the dangers of high-voltage within the unit, I would recommend taking the unit to a repair center.
Please let me know if I can be of further assistance to you.
Good Luck,
- Jim
Mar 03, 2008 | Emerson MW8985W Microwave Oven
Power level
Press Cook, enter the numbers for time, press Power, enter 1-9 for percentage power, then press Start.
Nov 22, 2007 | Emerson MW8107WA Microwave Oven
Microwave Ovens Logo
119 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
