Question about LG LRTN22310 Top Freezer Refrigerator
My lg icebeam cooling fridge keeps freezing up
2 Suggested Answers
SOURCE: LG Fridge Icebeam Door Cooling
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Posted on Feb 12, 2011
I have an LG freezer/refridgerator model # LMX28988ST-00 it does not freeze and the fridge compartment doe not get very cool. the compressor seems to be working. as I can feel it blowing cool air
Wellp.... that air you are feeling should be somewhat warm from the compressor 'compression action'...
Please don't discount a possible bad compressor from your list!
You should find the LINK below VERY helpful!
Anthony
LG Help Library Not Cooling Refrigerator LG
Dec 02, 2017 | LG Refrigerators
Hi there I have an LG Icebeam Door Cooling fridge that doesnt seem to be working correctly. The fridge is not that cold and the freezer is defrosting on the top section. The light is on and it seems
Find your model # and put it in the search box here: http://www.lg.com/us/support . Once your fridge is showing, there is great troubleshooting info available. Also, armed with the model #, we can actually give you pertinent advice!
Nov 24, 2014 | LG Refrigerators
Could be your thermostat is defect, but even more likely the compressor is not working correct. Perhaps you even lost the cooling fluid. To be sure, please move everything as quick as you can to another fridge and ask a technician to have a look.
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
I have A LG SXS Fridge. The Freezer is fine the fridge is not cold. I have read that the damper door might be closed. How do I find the damper door?
The damper is between the fridge and freezer section.
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
Myfreezer keeps freezing up and everything defrosts, and now my fridge is not cold also model no LG GRB227STS
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 28, 2011 | Refrigerators
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Hello I have a LG GRF 459BSCA Fridge Freezer. The fridge has stopped cooling, We were told to turn it off for a while, then back on again. Now the Fridge freezes!. Could you help with this please and...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | LG Refrigerators
LG ICEBEAM GRS512GC. Freezer cooling but fridge not cooling. Just had tech replacee fridge pcb with no sucess... any suggestions? thanks in advance :)
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 23, 2009 | Refrigerators
LG icebeam door cooling
Normally the fans get turned off when you open the door so it does not blow all the cold air out. The fans should only run when the doors are closed. Push in the door switch and see if the fan works then (of course it has to be in the middle of a cooling cycle or the fans still won't run).
Dec 01, 2007 | Refrigerators
LG LRTN22310 Top Freezer Refrigerator Logo
24 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
