Question about Cameras
Lens error my lens is stuck in the out position and when the camera comes on and there is a grinding sound followed by the lens error message on the screen help!!!!
  • 423 Answers
Hi Trish,
There are 1 of 2 problems that could be wrong here.
1) There is dirt or sand in the lens mechanism preventing the lens from moving, thus giving you the lens error. The fix for this is easy and 90 percent of the time will fix your problem:
Use an air compressor (or borrow a friends). Put the nozzle up to the space between the lens and the camera body and blow it out real good. You may have to do it a few times to get it to work. When your done, gently tap the lens on a hard surface to remove the obstruction. - I have also had people say that they have had good luck using a hair dryer, then turning it over and tapping the lens on a hard surface. That freed up whatever was in the lens causing it to foul up.
2) The guide pins in the lens have gotten off alingment. This prevents the mechanism from turning to retract your lens.
I will wait on this fix, because it is Dangerous for your camera! If you still have a problem with your lens after trying the above...then let me know, and we'll talk about it. Good luck and let me know.
Rob
Posted on Mar 11, 2009
Lens is stuck in the open position and when i try and turn on the camera, it makes a clicking sound and displays a LENS ERROR message
lens is stuck inthe open position and displays a lens error message and when I try turn on camera ,it makes a clicking sound
Jul 06, 2009 | Casio Exilim EX-S600 Digital Camera
Lens stuck in out position
Replace the camera lens. Or take the camera apart, rebuild and clean the lens, then reinstall the camera lens into your camera. Rebuilding is not as fun as it sounds.
Nov 12, 2008 | HP Photosmart M527 Digital Camera
Lens error,restart camera
My Camera: Canon PowerShot SD770 IS Digital Camera
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god.
Aug 31, 2008 | Canon PowerShot SD600 Digital Camera
Canon SD900
First off, see if Canon can help you. If not, the following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 28, 2007 | Canon Digital SD900 / IXUS 900 Ti Digital...
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Zoom lense stuck
The only solution is to replace the lens module.that module is very costly. hope it help
Aug 09, 2007 | Fuji FinePix F460 Digital Camera
Stuck Camera Lens
You could try the Casio Tech Support team, but if as you suspet it is a matter of dirt- there is nothing to be done except replace the camera- the cost os shippin and examining the camera etc. will come close to its replacement.
Jun 25, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Lens is stuck out
push up on the inner lens housing,
Dec 24, 2006 | Kodak EasyShare LS753 Digital Camera
Problem with my camera
Your lens is jammed, and needs to be repaired or replaced.
Sep 04, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Cameras Logo
116 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
