Payne gas heater blower is making a thumping noise
The blower is making a thumpering noise when it is rotating. The problem started on it's own. Sounds like the blower needs some oiling but is says that it doesn't need any oiling ever. Help?
  • 252 Answers
TURN OFF ALL POWER TO FURNACE!
CHECK THAT POWER IS TURNED OFF!
Check inside blower for any foreign item/trash/animal.
If this does not solve the problem get it fixed NOW before it cost you a LOT more!
Please rate my answer!
Posted on Mar 12, 2009
I have a payne airhandler blower motor want come on blower model 5sme390x
Many air handlers have a safety switch on the filter access cover panel, our on the electric control panel. The switch may not be making contact, try moving the cover to try making the south work, or remove the cover and verify there is a switch, a button switch and operate it by hand with the a.c. on, user caution with rotating parts.
Nov 02, 2015 | Heating & Cooling
My Payne furnace is NOT producing the desired heat anymore. Any ideas?
Hello, it could be shutting down on it's high limit switch due to a dirty air filter, dirty blower wheel, weak blower motor. Usually this would cause the furnace to shut down before it reaches the desired temp.
Dec 30, 2011 | Heating & Cooling
Furnace blower does not turn on
Pat, look for any way to add a few drops of 3-in-1 electric motor oil to the shaft ends. You may find a few small plastic removable plugs where you can drop a few drops into. Get the numbers off the oval shaped capacitor and replace it as soon as possible. Inspect all wires and sand all contacts one at a time to make sure wires go back on original spades. If it continues, you may need to replace the fan relay. Good luck to you!
Feb 25, 2010 | Heating & Cooling
Dryer makes clunking noise when it starts and stops. Also noisy during the drying cycle. It's a Maytag
May need a new blower wheel.
The wheel is mounted to the motor and if it is stripped out it will not move air past the heat element.
Have it checked before the heat element fails.
Jan 16, 2010 | LG DLE2515S Gas Dryer
Did you resolve your dryer / noise?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
Electric Dryer Thumps
that gap in the drum is most likly hitting a roller in the back of dryer so my best guess is replace drum if you feel it's not that change the felt around door thank you for useing fixya rate me
Apr 01, 2009 | Dryers
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
Thumping sound under dash when start or shut down.
I take a shoot here you can try this. try pulling the fuse or fuses that go to your heater blower and heater controls. If it stops check your heater blower it may be going bad, if you find nothing there, leave the blower unplugged and try turning your key on and see if you still hear it. If so I would think that the heater control is mess up and open and close the air blend door or you may have a wire shorted out under the dash some where.
Nov 27, 2008 | 1994 Chevrolet C1500
Payne Heater
The flame will not start, but the blower runs...
Oct 16, 2008 | Heating & Cooling
Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Dec 11, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
200 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
