Question about GE Water Dispensing & Filtration
To much water in the brine tank - GE Water Dispensing & Filtration
kermit854
  • 38 Answers
SOURCE: GE SmartWater Softener GNSF35ZO1
I am not familiar with your specific model of softener, but generally speaking, adding water to the brine tank is the last step of the regeneration process. This way the water can soak the salt until the next regeneration is called. Then, as you have determined, the valve does reverse direction and draws the brine solution through the resin.
There are other steps involved in regeneration, like back-washing and packing the resin, but you are mostly correct.
Hope this helps,
Kermit
Posted on Aug 22, 2008
louislevel_2
  • 374 Answers
SOURCE: water is not running through the brine tank
hi! there,
the motor trip off due to obstruction of pressure,this was equipted by pressur switch, w/c if the differential pressur of in and out of filter exceeded this will trip off, reset over load protection relay,push lever of relay to reset the overload protection this was located on control panel board,if there is main circuit breaker check also,push up to reset circuit breaker,replace catridge filter at once to flow the water continously,check specification of catridge filter about 0.2 to 0.5 microns or depend on your manual.cheers and have a nice day,don't forget to rate me,thank's
Posted on Apr 12, 2009
  • 569 Answers
SOURCE: Kinetico Water Softening Unit has brine tank drainage problem
This sounds like the resin cylinder is perforated or connections at the top are leaking. The brine tank should only have a little water in the bottom - if it is full of water (maybe even up to the overflow?) then you will need to replace the resin cylinder or fix a leaky connection to it.
Is the water in the brine tank 'rusty'?
Posted on Feb 21, 2010
Testimonial: "Thank you so much. My husband is quite handy but never having dealt with water softener we were looking for some advice. We certainly appreciate it!"
h2oservices
  • 306 Answers
SOURCE: water softner problem, does not refill water to brine tank
There is .25 gpm flow restrictor in the top of the float assembly, It may have sediment in it. Unscrew the cap on float top and check the restrictor. When you hook it back up run the system to refill (last cycle) hold the float stem down until all the air is purged from float assembly and see if that works. Also the float ball (foam) may have slipped top too far and is shutting off prematurely. If this does not work it is in the valve which has small pistons, diaphrams and springs to control the cycles. Each cycle also has a solenoid which makes these components work. You will not find a service manual for the Mark 50 valves. They are obsolete unfortunately and parts are no longer available. This valve was made for nearly 40 years and was the hallmark of the Culligan line.
RJ
Posted on May 14, 2011
h2oservices
  • 306 Answers
SOURCE: It looks that water is leaking from the - Culligan water softner
Look down the tube (where the float assembly is) there should only be about 10-12" of water in there. For water to reach the brine tank over flow the tank would have to be 3/4 of water. Brine tanks can develop leaks over time if they were set on uneven ground or if any rocks or debris are under it. If there is no evidence of water running down the side of the brine tank this is the most likely cause. Also if it has been leaking for some time there will salt buildup around the brine tank. Check the water softener for any leaks also. At times a small leak from the softener will find it's way over to the brine tank and collect around the bottom of it.
RJ
Posted on May 21, 2011
How do I reset salt level
On the left hand side should be button marked salt level, after adding product,on side of brine tank are numbers in yellow telling you the level,push salt level button to the number shown on side of brine tank. Note: do not fill over brine tank, I suggest to fill to level 6 or 7..
Oct 31, 2014 | Kenmore Ultra High-Efficiency Water...
Tip
Water softener salt bridging
One of the most frequent problems with water softening systems is salt bridging in the salt/brine tank. There are several reasons for salt bridging to occur. This generally occurs when pellet type salts or potassium chloride is used to regenerate the water softening system. Pellet type salts contain binding agents that in turn give the salt a very starchy consistency when wet. As water evaporates in the brine tank the pellet salts partially dissolve, bind together and form a "salt bridge" in the tank. Potassium chloride (Kcl) acts in the same way. Excess water in the salt tank, with high salt levels, can also cause salt bridging. Improper softener brining and lack of proper brine refill will cause bridging to occur as well.
What is the best way to alleviate these problems?
1. When using pellet type salts or potassium chloride only keep the salt tank about 1/2 full. This prevents too much compaction of the salts and helps to prevent bridging. When using potassium chloride get the salt tank off the floor on a wooden platform to prevent wicking of moisture from concrete floors.
2. Use a high grade of salt. Most water treatment dealers use either
DuraCube or HardiCube water softener salts produced by Cargill Corp.
Cargill has a link to find dealers in your area.
https://saltapps.cargill.com/cargillsalt/product_locator_new.asp
Solar Salt is another option as the crystal structure is very hard and virtually impossible to bridge. This is also available from many Cargill salt dealers and in stores.
3. Let the salt tank run down to 80-100lbs of salt or potassium a couple times per year to help prevent buildup of dissolved salts in brine tank.
4. Yearly maintenance of the water treatment system helps also. Restrictions in the brining system (injector/eductor assembly) caused by sediment and oxidized iron buildup cause improper brining and too much water in salt tank during refill. Have this assembly cleaned yearly. Have the water tested to see if the water chemistry or usage have changed and adjustments to the system are necessary.
5. Avoid using rock salts to prevent buildup of sediment in brine tank (which causes service problems).
Practice these tips and you will have fewer water softener problems and more consistent quality softened water.
I wish you good water!
H2O Services
on May 17, 2011 | Water Dispensing & Filtration
Softener not filtering water through the salt and not draining water from tank
What model of water softener do you have ? The one you have on here is for a chemical, not a water softener. Usually it is the brine injector or commonly called the nozzle/venture that gets clogged and will not create a vacuum to draw out the brine water. If you can put a picture of your water softener on here. I'd be more than happy to help you out.
Mar 20, 2014 | Seachem Discus Buffer 4 Kilogram Softens...
Why is water standing in brine tank of whirlpool whes30 water softener
Brine tanks are normally always precharged with water ready for next regeneration. It also allows contact time to ensure correct brine solution.
Sep 08, 2013 | Home
Water softener fills up with water
If you are referring to the salt tank filling with water, then the problem is the eductor assembly. This is where the brine is drawn from the salt tank. If it is plugged no brine or very little brine will be drawn during regeneration. You will need to clean the eductor assembly and manually regenerate the softener to regain softened water.
What model softener is it? It would help to bail most of the water out of the salt tank. How much depends on the model.
RJH2O
Jan 26, 2013 | Measuring Tools & Sensors
RJ
Jun 14, 2010 | Culligan Sediment Water Filter
Feb 11, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Water softner problem, does not refill water to brine tank
RJ
Jan 03, 2010 | Culligan Sediment Water Filter Heavy Duty
Brine tank does not fill
If the brine tank is not refilling with water this indicates there is a restriction in the brine refill assembly or the refill piston is bad. Depending on the model this restriction could be either in the top of the float assembly or in the brine refill itself.
RJ
Nov 15, 2009 | Culligan Sediment Water Filter
Hope this helps,
Kermit
Aug 15, 2008 | Kitchen Appliances - Others
Water Dispensing & Filtration Logo
60 people viewed this question
Top GE Water Dispensing & Filtration Experts
Dan Webster
Dan Webster
Donni Steen
Dennis Boxerman
Are you a GE Water Dispensing and Filtration Expert? Answer questions, earn points and help others
