Question about Vizio VX20L 20 in. LCD TV
I need to relocate the audio output jack on a Vizio VX20L
Hi
How is the back cover removed on this model. I've removed all the obvious screws and I can get the bottom to lift away slightly but it won't pop loose. Are there any hidden screws or is there a sequence to follow to get this cover off? Any ideas?
  • Anonymous Mar 22, 2009
    I have the same issue. It seems overly tricky to pop the back cover off.
  • craig_graham Jun 18, 2009
    I removed all the screws and got one corner to lift . Then I CAREFULLY worked a flat bladed screwdriver around the back and the cover came off. Thanks for the encouragement.
    Craig
No it is just a tough cookie to get apart. There are 8 screws in the stand and 4 screws on the case then it should be ready.
Posted on Jun 18, 2009
What should I do in order to get the sound to turn back on my Vizio VX20L TV?
Have you tried the user manual? There may be a setting in the menu indicating whether to use internal speakers or some other device run through say, a cable or HDMI output, or turn off sound for those using a cable input to the TV from say, a cable box, but the sound goes to a separate sound system.
Also check that there is sound coming INTO the unit from your cable box if you have one and use RCA cables. If using HDMI input, there may be a menu item as well, to control whether to use input or not, as some people will have the cable box send the sound to a sound system instead of the TV.
Oct 26, 2014 | Vizio VX20L 20 in. LCD TV
I have an older home stereo system that i would like to connect to my vizio tv. I have a 3.5mm audio to rca plug. Coming out of the headphone jack on the tv, it plays no sound out of the system. Although...
I suspect what you're wanting to do is take the audio output from the TV and run it through your stereo system to leverage the large speakers. Correct?
I suggest using the RCA audio jacks (red and white pair) on the back of the TV. Most TV's still have these. Some are tied to a specific component, and some are general for all sound coming out of the TV. You connect this to the input RCA jacks on your stereo system.
The headphone jack on the TV could also work, but I suspect it may have a low level output. I don't understand how you say your MP3 player plays fine through the headphone jack, as that's an output, not an input. Unless there's some other jack?
Sep 22, 2013 | Vizio 29in Class LED 720p TV - LED TVs
My Vizio VX20L TV is giving a message that there is no RGB signal, then it shuts down. Please help!!! Thanks!
tried to use with other input device and hooked up at the tv then use other component input just to isolate the problem.
Mar 25, 2013 | Vizio Vx20l 20" Lcd Hdtv vx20l - Open Box
My 36 inch dell lcd tv has no sound output
Your Vizio/Dell could have a power supply problem
Feb 28, 2013 | Vizio VX20L 20 in. LCD TV
How to connect a vizio lcd hdtv to my 1976 kenwood KVA 503. My Vizio has no speaker outputs except a digital optical audio. I had it hooked up before and then moved and now I can't get it back...
Obviously the digital optical connector was never connected to the vintage Kenwood.
It sounds like your Vizio is NOT the actual root SOURCE of the TV audio but it's coming from a Cable Box which DOES have various audio outputs. Connect it as you would any other analog audio source (except don't use the PHONO input).
Jun 30, 2011 | Audio Players & Recorders
Vizio L37 no picture or sound, power light comes on after selecting power button
This would be a mainboard issue. Since it effects both video and sound. I would replace the M/B. It's easy to do. You will need to post the model number of you TV so I could post the correct part number.
After you get the a new M/B you woudl flip the TV over and remove all the screws. Pop of the back and remove the screws from the M/B cover. Don't forget to remove the screws around the input jacks. After that it's easy. Just replace the M/B and put it all back together and your surfing again.
Aug 13, 2009 | Vizio Televison & Video
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
Vizio VX20L 20 in. LCD TV Logo
264 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
