Question about Pioneer Vsx-522-k A/V Receiver
Osd for vsx-522 won't work
I have a LG tv - 47ln 5400 and want to hook up a Pioneer vsx-522-k receiver to it. I van get the OSd to appear on the TV. Using HDMI cables
  • 14 Answers
SOURCE: Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Posted on Apr 02, 2008
smarthome2
  • 1114 Answers
SOURCE: Can the Pioneer VSX-74TXVi support 1080p video
No. Your receivers HDMI version is 1.1 It was the first, and as always, riddled with compatability issues. Nothing you have should be run thru this receiver via HDMI, use your receiver for digital audio switching via optical or coaxial digital. If you really want all the HDMI info and problems; google hdmi forums. There are hundreds that specifically deal with this issue and all the specifics you could ever ask for. Long of the short of it though, Version 1.1 will not work and can not be updated by firmware. Also, it's not Pioneer's nor any other MFG's receiver's problem it's 80% recording industry trying to protect copyright on video, and 20% poor design by HDMI and not forward thinking. Hope this eases the frustration!
Posted on Nov 22, 2009
  • 6 Answers
SOURCE: I just bought a vsx-1019ah receiver. I connected
Check if your KuroLink is on or off. There are a lot of problems that users have been having with the KuroLink on. Since you have a Pioneer display, KuroLink might help in switching both the receiver and the display on and off together, but my advice to you would be play around with the settings (in your case, especially KuroLink). Also remember, the KuroLink is on by default i.e. if you've never changed this setting, it probably is on.
Hope this solution works, else check out the Official Thread on Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Posted on Dec 07, 2009
  • 6 Answers
SOURCE: I have a motorolla DSR505 sattelite receiver that
The DVI output usually transmits only video (I'm almost 90% sure about this). It would be better if you did not use the DVI to HDMI cable. Receivers and displays can be very picky when it comes to using HDMI. Your Motorola DSR505 has other output options on its rear. I would suggest using the Component out for video (the 3 outputs colored green, blue and red) and either an optical or coaxial for the audio. The Pioneer VSX 1019 AH-K has the required inputs. Of course, you would require new component and coaxial/optical cables to do the job.
Hope this helps. If you're still in a tangle, you can consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
SOURCE: Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Posted on Dec 10, 2009
Tip
How to get OSD on TV for a Pioneer Receiver
OSD for on your TV for a Pioneer Receiver setup menu. (It doesn’t matter what make your TV is).
Connect the MONITOR OUT video jack on the receiver to a video input on your TV. Use a standard RCA video cable to the composite video jack.
Turn your TV on and put your TV onto AV3. Turn your receiver on, then on your remote control push the receiver button (this is not the on/off button, there is another button with receiver written on it) then push the setup button on your remote control. You should get the OSD menu on your TV for the settings for your receiver.
on Jan 03, 2010 | Audio Players & Recorders
Psw111 hook up to vsx-522 subwoofer
Just use one of those jacks. Then turn the frequency select dial all the way up. This will work just as well.
Apr 21, 2013 | Yamaha 5.1-Ch. Surround Sound Home Theater...
How to unlock osd
Hold the MENU button for 5 seconds, the 'OSD LOCKED' will appear, to unlock, hold MENU button for 5 seconds, the 'OSD UNLOCKED' will appear. It may not work on ALL LG LCD panels.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jul 11, 2011 | LG L192WS LCD Monitor
I am not getting the OSD, I used to get this before, not now. Could you please advise why ?
If you could fill in some detail about what your video interface is and something about the TV/Monitor.
The minimum you need is a single RCA cable from Monitor Out to any Video In on the display device.
Jan 11, 2011 | Pioneer VSX-AX5I-S 6.1 Channels Receiver
My osd is locked how do i fix it
Try this:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 04, 2010 | LG Flatron L1919S LCD Monitor
OSD Locked How do I unlock the monitor?
Please post back, otherwise check the owner manual.
Sep 09, 2010 | LG 22" FLATRON LCD Monitor
I used to get OSD on the TV with my receiver, but it has gone and I don't know what setting to do to get it back. It is a Pioneer VSX-917V-s/-K. Thanks
did you happen to change to cable connecting the Reciever to the TV to an HDMI?
please note that the OSD will not appear if you have connected using the HDMI output to your TV.
Use component, S-video or composite connections for system setup.
Dec 30, 2009 | Pioneer VSX-917V-K Receiver
The OSD on my Harman/Kardon 347 does not show up anymore. I am using a Compostie cable and it just stopped working a while ago. I had hooked up an X-Box 360 to my T.V using the 3 RED, GREEN, BLUE component...
Put the receiver in stand by mode (amber light) and hold on the tone button for 8 seconds. This will reset the receiver. After it says reset, let go of the tone button and wait about 30 seconds. Then hit OSD and you should be good to go.
Jul 22, 2008 | Audio Players & Recorders
Arcam AVR 200 OSD
Hi
Think you might have to use composite video out for the OSD menu to appear. Think I heard somewhere S-Video out doesn't work for.
Haven't tried yet on my own, but I will in time :)
Cheers,
Simon
Jan 11, 2008 | Arcam AVR-200 Receiver
Pioneer Vsx-522-k A/V Receiver Logo
153 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
