Question about Whirlpool GD2SHGX Refrigerator
Crushed ice only.No cubes.
Whirlpool Model GD25BFCHBOO
In pushing cube button for cubes, you only get crushed ice? Thanks.
  • Whirlpool Master
  • 3,361 Answers
Pull the ice bin out about 4 inches and re-insert it in the slot in the rear to reset the crusher arm.
Posted on Mar 11, 2009
My side b side fridgidaire will only make cube ice now not crushed
fridgidaire makes cubed ice but crushes ice. could be push button on door, mechanism that crushes ice, if not mechanically inclined please call refrigeration tech to check out.
Apr 10, 2015 | Frigidaire FRS3R5EMB Side by Side...
Why am I getting crushed ice when I requested cubes
Hello friend, thank you for your post!
I understand that you are receiving crushed ice even when you request cubed ice. It could be an issue within your control panel or solenoid. Since it could be any one of these under lying issues I would recommend having a technician come out to properly diagnose your appliance. Hope this is helpful. -Matt
Sep 12, 2014 | Frigidaire Refrigerators
WHEN I PUSH BUTTON FOR THE CRUSHED ICE IN THE DOOR I GET CRUSHED ICE BUT WHEN I SWITCH THE BUTTON TO CUBED ICE NO ICE COMES OUT BUT THE BUTTON LIGHTS UP WHEN SWITCHING FROM CRUSHED TO CUBE EVERYTHING ELSE...
You will need to check inside the ice tray for anything that may have fallen in. Sometimes the ice itself with stick into clusters and will not dispense. I would take out the tray, empty it, rinse it and re install it. Good luck!
Sep 15, 2011 | Whirlpool Refrigerators
Ice does not dispense from whirlpool refrigerator. Model # ED25PQ If you press with a cup or glass to attempt to get ice whether it's cube or crushed there is no noise or ice being sifted through.
Check the ice cube container to see if it is full of cubes and also that the cubes are nor "bridged" above the dispenser auger. Hope this helps!
May 30, 2011 | Whirlpool Refrigerators
My samsung rfg297aa dispenses crushed ice whether its set on crushed or cubed. why will it no longer dispense cubes?
This answer probably comes too late for you (you posted the question 9 months ago), but I want to record it here for posterity, since I had the same problem, and searching on Google for it brought up your question.
Anyway, I managed to fix this very problem by removing an ice cube that was wedged in the ice dispensing mechanism. The way this unit works is that it pushes the ice cubes through the mechanism, which always rotates the "crushing blades". When you select "cubed" ice, a lever opens up the exit chute wider, which causes the blades to simply push out the ice cubes as they pass through. When you select "crushed" ice, the lever closes the "exit" for the ice cubes to be narrower, so that the ice cubes can't be pushed through by the blades, and instead get crushed by them. I had an ice cube wedged in there that had the same effect of closing the exit to be narrower. Removing it fixed the problem.
You might want to collect all the ice cubes that have accumulated in the ice bucket in a container, empty the ice bucket, clean out the mechanism from any obstructions, and then put the ice cubes back into the ice bucket.
Feb 16, 2011 | Samsung RFG297AA (285 cu ft) Bottom...
MY ICEMAKER IS STUCK IN THE CRUSHED ICE CYCLE WONT PUT OUT THE CUBED ?? EVEN WHEN I PUSH THE BUTTON BACK AND FORTH WONT SWITCH ??
if you have selected cubed on the door and still wont dispense cubed ice likely cause is the cubed ice solinoid( located behind the panel in where the auger motor is located) thats the motor that turns the curly thing in the ice cube resivoir.....!!!
Jun 08, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice crusher stuck on crush mode can't swith back to cube
is it push button or do you manually have to turn dial from crush to cube. I have push button and had this problem once before.(LG side by side) I turned off at power (remove cord from wall) and removed ice tray all together. save some ice for testing. Check to see if crush part was clean. Put ice back in container and put back together and turn back on at power point. See if you can have cubed now.
Dec 14, 2009 | Frigidaire FRS3R4EW 33" 22.6 Cu. Ft....
Only crushed ice comes out of dispenser
your model # is incomplete but here it goes.
1.take your ice container out and run hot water thru it. you want to defrost all of the ice build up inside of it's housing.
2. make sure the long lever under the container moves up & down when you press on it.
3.w/the container removed, you will see a fork like object and next to it amn openning w/a small plastic square part inside. make sure that part moves freely up & down. that solenoid is what gives cubed ice.
let's start there first
Jul 14, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool GD2SHGX Refrigerator Logo
96 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
