Question about Kenmore Refrigerators
Kemore fridge model 970-438321 owners manual
Model 970-438321
My Kemore side by side water and ice dispenser have no lights or respond to pushing any buttons. It has also stopped making ice. Everything else on the fridge works fine.
Down in the door where it mounts on the hinge is a cable with a quick connection. Is that thang connected and corrosion free? Some models has the cable coming out the top. Imposible to tell without propah model numba. What with all the weird foreign mess on the market today under the Kenmore nameplate.
Aug 11, 2011 | Kenmore Side by Side Refrigerator
My bottom freezer cools ok but my top freezer is warm what could cause this problem ,,kemore ,,model 59662913200
My guess would be that the defrost is sticking on...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 06, 2010 | Kenmore Refrigerators
I have a kenmore elite dishwasher that the smart wash light blinks . it will stop running after a couple of minutes then starts flashing lights. i have to un plug it and wait a few minutes and try it again...
Note the number of times it blinks then reference the number of times it blinks with your owners manual or if you don't have the manual kemore.com should or sears.com. that will tell you the problem. Once you've done that if you need more help tell me what you've found and I can help more. I also install for sears so if you have trouble finding the manual get me the model # and they may have it on file at the store
Jul 31, 2010 | Dishwashers
Our Kemore Elite French Door Fridge is not working. The Freezer is freezing but the fridge is not cooling at all.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 22, 2010 | Kenmore 77552 Bottom Freezer French Door...
Flashes e f code
This is a combination of problems. I have a Kenmore Elite labeled Frigidaire model 253.44513601. If you are reading this you are aware that Kemore/Frigidaire refer's are JUNK.
I have went through TWO Kenomre Elites since 2001. My lateset Fridge (bought January 2007) suffered the "E F" code.
At first I replaced the Evaporator Fan (behind freezer compartment.) This did NOT solve the problem. I then bought a new control board located under the freezer. (take off toe plate, and removes screw, the board slides out and is connected by 3 wire harnesses.)
My fridge is now running, but it has yet to get "cool." This maybe because the User Interface needs to match the control board. Not sure yet, but I will keep posted.
Jun 06, 2009 | Frigidaire Model: PHSC39EHSS
Danby propane frig model DPR2260-2 owner's manual
I have the same refrigerator and am looking for the manual as well. Did you ever find one? If so, where?
Thanks,
Ari
Renata BC
hi_ari@yahoo.com
Oct 06, 2008 | Refrigerators
Kemore side by side fridge 56072791
check your ptc first but if you do have a def. timer on this model it is going to be either at the bottom kickplate area or at the main control area in the freshfood side
Jun 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Sears kenmore side by side won't get cold!
If you ever get rid of this fridge could you let me know. I need an auger motor for that same model of fridge.
Jan 21, 2008 | Refrigerators
Refrigerators Logo
193 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
