Question about HP Compaq Presario SR1503wm PC Desktop
CD play function plays music, then fails priior to completion
Also downloaded Chessmaster 10th edition.
This requires first of 3 CD's to be installed during game play.
It will start a game and then freeze further play.
I tried an insertable CD cleaner to no avAil
  • Jim Scott May 11, 2010
    are the specs on your game below your computors specs ?? that is are say your memory requirements less on the game than what you have on your pc ??
  • 700 Answers
Yeah if your spec doesn't meet the requirements it will hang. Also the most possible cause is fault in downloading or there is error on the file itself.
Hope this help.
Posted on May 09, 2009
I purchased chessmaster 10th edition and installed to computer when i hit the play button for startup it asks to insert disc 1 i would like to know why this is required when the program is installed ...
i am sorry to give u bad news, game CM is game that need disc to run the game because a lot of stuff that still need to run the program left behind in the disc. it was factory setting.
But u can use alternative way by make the disc to image then run it with daemon tool.
first u need program that can make image file like .iso, .nrg, etc. ( i use nero)
make an image file from CD 1 and CD 2 and save it in computer.
second install program that can make image drive to run image disc (i use daemon tool).
make one image drive then mount the image disc to the drive.
now u can play without real disc. (after finished play the game unmount the image disc)
hope this helpful
Feb 15, 2011 | Ubi Soft Computers & Internet
Hi, my chessmaster 10 edition becomes unresponsive when busy playing. The time of the relevant player stops and the task manager shows that it is not responding. After about 3 minutes it sorts itself out...
actual your wrong on all acounts... your chessmaster should run just fine on your version of windows.. it sounds like it glitching because of you computer itself.. now chess doesnt sound like a game that needs alot of graphics to play but the graphics card can be one.. i would suggest checking your core temp (cpu fan) in your bios (look it up buddy on how to's) and the search normal temps.. your computer needs to run at a healthy temp or no matter how good your computer is it will overheat and become useless... but it can also be your processor or your about of ram... try deleteing old files you dont use to make disk space and after that go to start>all programs>accessories>system tools>disk cleanup.. and then after that is done system tool> disdefragment and let that run.... and if that doesnt help tell me and i can give more suggestions if it fails
Dec 10, 2010 | Ubi Soft Chessmaster 10th Edition
Cannot initialize 3D engine
the problem on the Chessmaster 10th Cannot initialize 3D engine is that the game support only 1024x768 on screen resolution. Do that and works fine. Peace for all.
Jan 06, 2010 | Ubi Soft Chessmaster 10th Edition
I WANT TO PLAY CHESS WITHOUT LOOKING WHERE MY CD IS EVERY TIME .
keep it inserted in the drive bay or download a cloning software to copy the cd.
Sep 30, 2009 | Ubi Soft Chessmaster 10th Edition
Lost the first CD
ok here you will find what you need so ckick and then choose a link: http://www.torrentz.com/a98f04c2fe9cc32d82fcf1bc0030c91aa0cff357
Aug 01, 2009 | Ubi Soft Chessmaster 10th Edition
"Failed to attach personality"
When I start Chessmaster, and click on Play-Trining Mode, it says "failed to attach personalities", and I can't play chess
Jul 29, 2009 | Ubi Soft Chessmaster 10th Edition
Inserted cd clicked "install" Installation wizard shows up then "1611 unable to extract file" then "1628 failed to complete installation" Bill Fry frysinfo@shaw.ca Vancouver Canada 8th July 2009 1.15pm...
this is the definition: The component qualifier not present.
This error occurs when a file compressed inside Setup.exe cannot be extracted. Verify that there is sufficient disk space available in the Temp folder (or, if not, in the Windows or WinNT folder), and that Setup can write to those folders.
Jul 08, 2009 | Ubi Soft Chessmaster 10th Edition
No sound for chessmaster 10th edition
You need to go to http://forums.ubi.com/eve/forums/a/tpc/f/760105752/m/5081052236 and download all patches in order.
If that doesnt work you will need to search the program file tree (Ubisoft/Chess/Data/User or something along those lines) for a CMDefault.ini cm.ini or YourName.ini (denoted by a notepad with a yellow gear superimposed) first MAKE A COPY OF THIS FILE AND NAME IT SOMETHING ELSE, then open the origional, and look for a modifer such as
sound=
or
playsound=
Or something like that...
If it is set to 0 or false then all you have to do is set it to 1 or true
THE SAME WAY IT IS WRITTEN
so if you see for example
sound=0
you will put
sound=1
NOT sound= 1 or sound =1 or sound= 11
Same for true / false
You also may see it either way
sound=true
sound= true
Save and try it, if the program crashes or fails to load, you made a mistake, delete the INI file and RENAME the COPY to EXACTLY the title of the ORIGIONAL.
And you'll be back where you started.
Mar 26, 2009 | Ubi Soft Chessmaster 10th Edition
Chessmaster 10th error message
you need a graphics card more than 128 mb to run
Dec 22, 2008 | Ubi Soft Chessmaster 10th Edition
HP Compaq Presario SR1503wm PC Desktop Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
