Question about Connex 3300 240-Channels Base CB Radio
Connex 3400 hp wont recieve - Connex 3300 240-Channels Base CB Radio
3 Suggested Answers
  • 14 Answers
SOURCE: how do you dim display lights on a connex cx 3400
O the front you should have a dim switch its on of 4 up & down switches ? if not check on the back ? was it bought as a new cb or was it 2nd hand as the dimmer switch may of been used for something else
Posted on Mar 09, 2010
anymhz
  • 500 Answers
SOURCE: how to convert a connex
That needs to be done by someone that knows how, theres soldering involved. most cb shops will do it for $free-$10.00... Don't pay any more than that.. there are no parts nor is it hard so they shouldn't charge much.
Posted on Mar 01, 2011
Connex 3400 hp makes static noise when I hit bumps in road.
don't hit any more bumps. The problem could be in several areas. I'm going to say that you may have a loose capacitor inside If I had the radio here I could fix it but because the problem may be so spread it could be a lot of things Are you a truck driver? If you are take it to a CB shop at one of the many truck stops and see if they can fix it for you .
Jan 22, 2016 | Connex CX-3400hp AM/FM 10 Meter Amateur...
When i key my connex 3400 hp up the meter drops to 0
If this isn't the result of an incorrectly set switch (ie: the PA / CB switch set to PA, failure to modulate the carrier in SSB mode, set to CW etc.), it is likely to be an antenna / coax connection issue. Double check connectors at the radio and antenna. Remove and inspect for dirt corrosion, etc. Clean up and reconnect. Make sure fittings are at least hand tight. Check for solidly connected antenna mount to the car body. If the type that engages the lip of / or a body panel, make sure it isn't rusty. If a magnetic type, try placing on the center of the roof (if metal & look for evidence of water entry into the base of the mount) Check the entire length of the coaxial cable. Look for places where it may be damaged from pinching between body panels. Crushed, chafed, and cuts in the outer jacket indicate a problem with the way the coax has been routed. Make repairs / replace as needed with thinner diameter coax if needed or reroute away from pinch points. Lastly, check and adjust your antenna for minimum SWR with a meter. A match of 2.0:1 will be required to prevent damage to the radio while transmitting. A 1.1:1 match is ideal, but under most circumstances. a 1.5:1 to a 1.8:1 match is attainable with a little bit of effort.
I hope this helps & good luck!
Jan 20, 2013 | Connex Multicolored Lights 3400 Hp 3400hp...
Fix my connex 3400 hb sideband button
Hi there, if you are talking about the Connex CX 3400 HP there is no sideband or SSB on this radio. It is only AM and FM 10 meter Ham radio. Many people do modify these radios to include the 11 meter frequencies which is the CB band. Maybe knowing the actual bands and their frequencies will help some too this radio does have 6 different bands ranging from (Band A. 28.015 thru 28.455) (Band B. 28.145 thru 28.585) (Band C. 28.115 thru 28.555) (Band D. 28.085 thru 28.525) (Band E. 28.055 thru 28.495) (Band F. 28.025 thru 28.465.) I hope this will help you. Bob
May 13, 2012 | Connex CX-3400hp AM/FM 10 Meter Amateur...
What is the correct settings for the connex 3400 hp
hows the SWR ?the ground? the antenna itself? on the inside check the final.
Jan 12, 2012 | Connex Radio Communications
How to convert a connex 3400 hp to cb radio band from 10 meter band.
Feb 12, 2011 | Connex 3300 240-Channels Base CB Radio
How do you dim display lights on a connex cx 3400 hp
Mar 09, 2010 | Connex 3300 240-Channels Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
21 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jim Y
Jim Y
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
