Question about Yamaha RX-V595A Receiver
Receiver wont turn on
When i hit the power button the receiver turns on and then automatically turns off (after about 2 seconds) i checked the manual and tried both suggestions: unplug for :30 and switch the impedance either one way or the other. nothing worked any suggestions?
  • 1 more comment
  • tokyo81 Dec 27, 2007
    I have the exact same problem but with the yamaha HTR-5960 if anyone have an idea of what is wrong please help.
  • Anonymous Aug 27, 2008
    I'm having the same problem. Anyone get a solution for this yet?
  • Anonymous Sep 25, 2008
    I have the same problem. I changed the power relay but it still turns OFF after a few ms. I check the impendance selector and it is set to one side. What else could it be?
V2712300 power relay
Posted on Apr 12, 2008
SOURCE:
Yb125 battery wont charge
Instructions
    • 1 Check the main power cord if the receiver fails to turn on. If it is unplugged or loose, securely plug it in to an electrical outlet. If this fails, try plugging the receiver in to another outlet. If the receiver starts, the previous outlet is damaged. Call an electrician to repair it. If this fails, try turning the receiver on with the remote. If this does not turn the receiver on, try turning it on with the power button on the receiver itself. If this works, change the remote's batteries.
    • 2 Leave the receiver in "Standby" mode if it immediately goes into "Standby" when you turn it on. With the receiver still in "Standby," unplug the main power cord. Wait for around 30 seconds, then plug the receiver back in.
    • 3 Check the audio cables if you experience sound issues. If they are loose or disconnected, securely reconnect them. If you still do not have any audio, press the "Input" left or "Input" right buttons on the front panel to select the appropriate input source. You can also set the receiver to automatically detect input signals and select the appropriate input source. To do this, access "Audio Select" from the main menu and select the "Auto" option.
    • 4 Try factory resetting the receiver if you experience persistent audio or video issues. Press the "Standby/On" button on the receiver's front panel. Press and hold the "Tone Control" button, then press "Standby/On" again. Select the "Preset" option, then choose "Reset." Press "Standby/On."
Jan 14, 2013 | Yamaha Motorcycles
I have a ev205 yamaha violin its covering of the bridge is damaged how can i solve this problem the black covering is sliped off from the wooden bridge plzz help me
Instructions
Jan 13, 2013 | Motorcycles
I can't get the receiver button to work on my remote control. I turned it off some how? VSX-1020k
You could try this:
1. Press and hold the R.SETUP, press "4" for three seconds. The LED flashes continuously.
2. Press the number button "1"
Now press the receiver on button. Did it work?
If it doesn't try taking the batteries out of the remote and wait for at least 30 seconds then put them back in and try turning your receiver on again using the remote.
Chris
Aug 21, 2011 | Pioneer VSX1020K Receiver
TEAC AG-V1200 receiver won't auto turn on when
No. It won't automatically turn on when power is present.
Aug 08, 2011 | Teac Audio Players & Recorders
I have an AV-S17 and it's stuck on eco mode. I have tried doing what the form has said for me to do and it doesn't help.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-AV-S17-Receivers-manual/id/1076ag804/t/2/
Page 7:
To cancel the ECO mode
1 Press the ECO button to display ECO MODE while the unit is turned on.
2 Within 4 seconds, press the ENTER button.
3 Within 4 seconds, turn the MULTI JOG to select ECO OFF.
The mode will be automatically set after 4 seconds. It will also be set if the ENTER button is pressed within 4 seconds after step 3.
Mar 29, 2011 | Aiwa AV-S17 Receiver
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Yamaha RX-V595a receiver shuts off 2 seconds after its powered on
The first thing called out is the impedance switch on the back is not fully in one or the other position. Cycle the switch back and forth to make sure it will 'read' each setting, then turn it on.
Also make sure you if you have anything connected to its convenience outlets that they are not drawing more current than is allowed.
Did you buy it used or new?
Mar 09, 2010 | Yamaha RX-V595A Receiver
Gigaware remote for ps3 cant connect
I can not locate a Remote For PS3 By Gigaware now if its a controller Follow these steps
Connect to PS3
1. Turn on your console and plug the receiver into the first port on the console. The RX indicator on the receiver flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. The controller’s POWER indicator lights and the 4 port indicators flash.
3. The controller connects with the receiver automatically after about 3 seconds. If successful, the RX indicator on the receiver lights.
4. Press the PS button to assign a controller number. The corresponding port indicator lights.
Manual Search
If you are unable to automatically connect, try manual adjustment.
1. Repeat steps 1 and 2 under “Connect to PS3.”
2. Press CONNECT on the receiver. The RX indicator flashes.
6
3. Press and hold SELECT and L3 (left analog stick) on the controller simultaneously for at least 3 seconds. When the RX indicator stays lit, release SELECT and L3.
n Notes:
• Repeat “Connect to PS3“ or “Manual Search“ if the connection fails again.
• If you purchase a new receiver for the controller, but have previously been using it with the supplied receiver, you will have to follow connection steps again.
Reassigning a controller number
1. Press and hold the PS button for one second. The functional screen displays. Select “Controller Settings”, then “Reassign the controller.” Press X to confirm.
2. Use the D-pad to select the number that matches the controller’s port.
3. Press X again to confirm. The corresponding port indicator lights up.
7
Connect to PC
1. Plug the recevier into a PC’s USB port. The receiver’s RX indicator flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. If connection is successful, the RX indicator on the receiver lights and the 4 port indicators on the controller turn off.
Test the controller
1. Open the control panel on your PC, and double-click “Game Controllers.” Then click “Properties“ and the testing screen appears.
2. Press the buttons of the controller. After testing, press OK to exit. You are now ready to play games.
Troubleshooting
If the controller stops working at any time, or will not connect to PS3 or PC, follow “Manual Search“ steps on pages 5-6.
Dec 14, 2009 | Video Game Consoles & Games
WS-65869 Turns off automatically after about 2 seconds
I have the same exact problem, did you guys got any help?
Jun 23, 2009 | Mitsubishi WS-55313 55" Rear Projection...
When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at ebcelectronics.com
May 09, 2009 | Denon AVR 2808Ci Receiver
Yamaha RX-V595A Receiver Logo
468 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
