Question about i-mate K-JAM Cellular Phone
Can't connect to my K-jam to my new DLink DIR-655 wifi router
I have a new dlink dir-655 wireless router and my desktop and laptop connect fine but when I attempt to connect my K-jam it just says "connecting" and eventually goes back to "available". my network shows up on the list of available networks almost immediately but it just won't go from :connecting" to "connected". The K-jam specs state that it supports both wifi B & G and my router supports G & N so I thought that it would connect at G speed. Any suggestions?
  • kenheber_lan Mar 21, 2009
    I cant connect my imate kjam on wireless router so I can use internet on it using wi fi. But whenever I tried, it always says check connection settings to connect on internet or work, problem is I dont know how to set configuration in it.
  • james faris May 20, 2009
    If anyone has a solution or a work-around for this problem, I'd sure love to hear about it. I posted this problem over 2 months ago and I still need to find a way to connect my KJAM to my wifi network. Any help would be greatly appreciated. Thanks
Can't connect to my K-jam to my new DLink DIR-655...
Posted on May 20, 2009
There's no CD, so how do I install dlink router dir-655?
1. set u all the possible wiring between modem and the router'
2.switch it on. open the any Browser like Opera, chrome,
4. Type the default gateway address descriptive at the back of your router (generally something) ;in the address bar of your browser and press enter. the popup message will ask for username and password .
6. now the default page of the router will get opened .
7. now run the quick setup and follow the further instructions.
8. each information should be entered properly and Your WiFi router will start working .
If any help related to Dlink Router then You can Contact us at Dlink Tech Support
Dlink Tech Support Number
Feb 13, 2014 | D-Link Wireless Router 3 Antenna Xtreme N...
D-link DIR 655 owner's Manual
Look on router ID plate for REVISION.
Owner Manual Links:
For DIR-655:
For DIR-655 REV. B:
Thanks for choosing FixYa, If you find this helpful please vote and comment.
Oct 11, 2010 | Computers & Internet
Cannot connect via wireless to dlink 655. wired connection works fine. when i disconnect to go wireless the laptop sees the dlink but there is no internet connection. running Vista Home Premium. static...
You must manually configure the wireless settings. Go to Network and Sharing Center > Manage Wireless Networks. Remove all the listed network there. Then click Add > Add Network in Range > Select your signal > Type the security if you have and press connect. That should do it.
Sep 23, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I am unable to connect to the internet with my dlink
Just connect my dlink 615 to a new dell computer on the vista page for the Network and internet the broadband connection is disconnected. What can I do to connect it? When I switch the dlink network back to the old computer everything works fine.
Aug 03, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Dlink dir-655
  • call dlink support to configure the router
  • but if you can powercycle first the modem router and pc
Aug 02, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
May 01, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
i-mate K-JAM Cellular Phone Logo
187 people viewed this question
Top i-mate Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
