Need owners manual for yamaha av receiver htr-7065
bbtoast
  • 319 Answers
SOURCE: remote code
This can be a frustrating process! I have had similar problems in the past, but perseverance is key!
Please be sure that you did all of these tricks:
1 Be sure to press and HOLD down the appropriate input button while pressing the AV power button for 3 full seconds.
2 Enter the code. Unfortunately, you may have to try all of the codes listed for your manufacturer. There are 23 for Phillips! There are "only" 8 for RCA, so you might try that compnent first.
It sounds like you are doing the right things, but is it possible that you are accidentally hitting a wrong button during the process? ie; using the TV power button instead of the AV power button? After completion of the task, are you then hitting the proper component button, such as DVD before trying to use the remote to control that device?
I apologize if you have tried all of these things, but I am not sure of your level of expertise! Good Luck!
Posted on Jan 01, 2008
cancerags
  • 36 Answers
SOURCE: Connecting a Yamaha VX7 Subwoofer on my Yamaha HTR 5730 AV Receiver
Hello srqwrk,
You can connect the VX7 to the 5730 using an RCA Y cable like the one shown in the picture below. You get your one connection for the receiver and 2 for the VX7. These are available at any electronics store. Remember that the cable should be long enough to go from the receiver to where subwoofer will be placed.
Hope this helps. Let me know.
cancerags
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
  • 55 Answers
SOURCE: Is it possible to play my ipod nano through my Receiver?
If it doesn't have a jack made for plugging Mp3 players into it like the new car stereo's do than you just have to go buy an FM transmitter that is made for Mp3 players. It will play through one of your low FM frequency's on your receiver. You can generally pick one up for around $20
Posted on Jan 02, 2009
SOURCE: Yamaha HRT 6130 cable questions
You would need 1 component and 1 HDMI cable.
Posted on Mar 21, 2009
How I how do I reset my htr 6060 Yamaha receiver
Willard, Check the attached links,reset receiver.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Yamaha HTR 6060 Owner Manual Resetting The System
Yamaha HTR 6060 MCXSP10 Manual Page 94
Yamaha HTR 6060 Manual Page 104
Yamaha HTR 6060 Manuals Support and Troubleshooting Receivers
Mar 08, 2016 | Yamaha Audio Players & Recorders
Need HTR-6130 Manual.
The manual is available as a pdf file from yamaha directly at http://usa.yamaha.com/products/audio-visual/av-receivers-amps/htr/htr-6130_black__u/?mode=model
Midway down under the "support" tab.
May 29, 2011 | Yamaha HTR-6130 Receiver
My parents gave me a reciever that they used to have... the Yamaha HTR 6030... And i am having trouble hooking up the sound
Here you will be able to find the owners manual:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/htr/htr-6030_black__u/?mode=model
If you provide more details of your trying to do I can assist you further.
May 19, 2011 | Yamaha HTR-6030 Receiver
Well i have a yamaha natural sound av receiver htr-5660 and ive connected 200 watt speakers and my problem is my tweeters are only working and i would to like know step by step to on how to get the...
"200 watt speaker" is meaningless. What brand and model? Be advised that stripping parts from an all-in-one audio package for redeployment with 'standard' audio components doesn't guarantee compatibility or safe function.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-5660-Receivers-manual/id/394ci074/t/2/
The amp has selectable impedance. See page 16.
Mar 15, 2011 | Yamaha HTR-5660 Receiver
I have a yamaha htr-6160 AV receiver. I have hooked up my DVD to it using using component video cables but I can't sound out. Video no problem but no sound.
it is sad your having a sound problem with your Yamaha
to resolve these problem , check the audio out settings of your DVD
player, it might have been set to digital and not analog.
Dec 26, 2010 | Yamaha HTR-6160 Receiver
Yamaha htr 5240 receiver, need fm antenna adapter
this is your manual http://www2.yamaha.co.jp/manual/pdf/av/english/re/HTR-5230.pdf
this is the 300 ohm adapter you need from radio shack and just install some small gauge speaker wire to it. or just splice the one that came with your receiver.
http://www.radioshack.com/product/index.jsp?productId=2062054
Feb 26, 2009 | Yamaha HTR-5230 Receiver
I am looking for the owner's manuel the YAMAHA HTR5660
http://www2.yamaha.co.jp/manual/pdf/av/english/re/HTR-5240.pdf
Jan 05, 2009 | Yamaha HTR-5240 Receiver
What's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Dec 30, 2008 | Yamaha HTR-6130 Receiver
HTR-5930
To get audio from your TV through your AV receiver, please connect stereo audio cables from an available AV input on the rear of your receiver such as D-TV/LD or CBL/Sat. Then refer to your TV owner's manual for more information about audio output to an amplifier. You may have to turn off the internal TV speakers in order to get any output from the TV into the AV receiver.
Feb 17, 2008 | Yamaha HTR-5930 Receiver
Sound cutting out
I'm presuming you are referring to a Yamaha HTR,right???(Night Listening Enhancer (Cinema/Music) and SILENT CINEMA)..see page 32 in this manual at this link,here's the owner's Manual,also available to download for free in .pdf (Adobe) format.......https://www.manualslib.com/manual/197349/Yamaha-Htr-5940-Av.html
May 09, 2017 | Yamaha HTR-5850 Receiver
103 people viewed this question
 Grubhead
Grubhead
