Question about Pentax K1000 35mm SLR Camera
My camera's view finder will not show anything, it is black.
When I was turning the wind crank to take my next picture I heard a bit of a crunch sound, I don't know that is the best word to describe it though. My shutter button will not go down, and the wind crank won't do anything either....The worst part is this is my school's camera :-(
    Problem Solver:
  • 18 Answers
Your winder gear is toast, get a digital camera and save on film printing cost.
Posted on Mar 12, 2009
  • Chrisnc1
    Chrisnc1 Mar 12, 2009
Hp r507
I don't think anything is wrong with your camera. Just check the Manual.
Your camera has a view finder, to make pictures. Yes the little screen on the top left (Backside) As an extra the camera has live view, that can be switched on and off. because the live view consumes lots of power, it is advised to use the view finder. If you want to switch it on, you can do so in the settings menu. There go to the live view en switch it on.
Feb 13, 2014 | Cameras
When the camera is in take a picture mode, the view finder is black. When viewing pictures pictures previously taken, they are show on the view finder. Why is it black in this mode?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 06, 2010 | Canon PowerShot S2 IS Digital Camera
When I take a picture with the Canon Rebel, it doesn't focus in the view finder, but when I look at the picture after it has been taken, it is clear and in focus. Why can't it looked focused when looking...
Good day,
The problem you might be having is that the view finder is out of focus.
If this is the problem it is an easy fix.
You will see a small wheel next to the view finder (it has a + and a - next to it), look through the view finder and let the camera focus on an object. Now turn the wheel and you will see the image either get worse or start to come in focus. Adjust the wheel until you are satisfied with the clarity.
Please let me know if this was helpful!
Regards
Nov 29, 2010 | Canon EOS Rebel XSi Digital Camera
The view finder or screen are black. The lens moves out when the camera is powered on, I can hear the shutter click when pushed; the telephoto is moving; I have all the settings show on the screen when...
I know it may sound like the shutter is moving, but you're going to have to actually look down the lens barrel to confirm it's actually moving, and not just producing a sound effect from the camera. Also keep in mind Canon's SX IS series cameras are notorious for the following problem (fantastic cameras otherwise).
Oct 31, 2010 | Canon PowerShot S3 IS Digital Camera
My sx10is will not turn on the LCD screen when taking pictures, it will when reviewing them. I think I did something to screw this up, help appreciated>
Close the LCD. Turn the camera off and then on. Look thorough the view finder and press the disp button to cycle through menus until it comes back to picture view. Open the LCD. If it doesn't show picture view, Press the disp button next to the menu button.
Aug 17, 2010 | Canon PowerShot SX10 IS Digital Camera
No picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 13, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
No view though the lens
Dec 26, 2009 | Canon PowerShot S2 IS Digital Camera
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Cant take photos with my Kodak ZD710
check eye settting or its a fungus inside lens black screen is due to virus
Jun 18, 2009 | Kodak ZD710 Digital Camera
Black LCD and Viewfinder
I have the similar problem as above...Canon 5D
When camera is turned on the viewfinder is black. All other functions appear to be working correctly. I can view pictures on the card. I take a picture and it views on the screen and the spec's come up on the botton of the view finder but the viewfinder is 90 black with a bit of blur. Is this the censor or a mirror...?
Is this fixable and at what approximate cost? Would it be cheaper to replace?
Jul 31, 2008 | Canon PowerShot S2 IS Digital Camera
Pentax K1000 35mm SLR Camera Logo
103 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
