posted by Miss T on Aug 02, 2007
I have an Emerson MW8107WA and the turntable stopped moving/turning. It still heats fine but food cannot rotate. Is there any hope?
Best Solution
posted on Aug 03, 2007
You probably have a defective turntable motor. They are fairly simple to replace and generally runs about $30-$35. You can access the motor by removing the bottom panel from the microwave. There are a couple of wire connectors and a few screws holding it in. You will, of course need to secure the main power and/or unplug the unit first. The spindle that the carousel and plate ride on, just pops off by lifting straight up from the inside of the oven cavity. Let me know if you need any further advice. I hope this helps you.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Emerson MW8107WA 1000 Watts Microwave
Email this problem
Email this problem
Can you Help with these Microwave Ovens problems?
Emerson MW8107WA 1000 Watts Microwave Oven
Comes on but........
The microwave and light comes... Answer This...
water has penetrated inside the...
when I was cleaning the door, I... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
