Question about Yard Machines Cultivator
Trying to replace primer button on 31cc bolens cultivater
2 Suggested Answers
  • 316 Answers
SOURCE: I have a Yard Machrines by MTD Yard & Garden Cultivator 31cc: Model No.21A-121R900 Ser.No.1A246DG1150 and I need to replace the primer bulb. How do I do that?
hello l, how to change primmer bulb,,remove the two fuel lines making note which line came off where,use needle nose pliers to push the two ears down and pull bulb out,make note on where the long and short stem was at,go to the mower shop and get a new bulb and install,put lines back on, done start engine,,hope this helps,,
Posted on Feb 21, 2012
Replaced fuel lines and primer bulb ON A BOLENS LB 160 25 cc TRIMMER. Primer bulb stays in and wont pop out. it pops out after abouot 3 minutes or if I loosen the primer bulb mounting screws
Check the carburetor internal filter screen for clogging. Also the primer assembly itself maybe bad. If the primer assembly itself is bad a new carburetor is in order.
Feb 09, 2015 | Garden
Repair and replace power module on bolens culivator 31cc engine
How old is it? Does it show a spark when you remove plug an hold against engine while pulling cord? Did you replace plug? It is the most common problem. Remove the stop wire an try to start, if it does or you see spark the switch is bad. I would check put these things before replacing module.
Mar 16, 2014 | Bolens 31cc 2-Cycle Gas Cultivator BL410
I need to know the fuel/oil mix ratio for a bolen bl 100 31cc trimmer.
You should use 3.2 fl oz of 2 cycle oil for every one gallon of unleaded gas or 100 ml per 4 litres of gas.
Apr 28, 2011 | Garden
Fuel line routing yard machine 31cc cultivator 21A - 120R000
unit with primer bulb,,,,,line from gas tank with filter, goes to bottom of carb, from top of tank to suction side of primer bulb, from output of primer to tank return
Apr 29, 2010 | Yard Machines Cultivator
Weedeater carburator setting on bolens 31cc
initial setting is 1and1/4 turns out for walbro carb.
1 turn out zama carb.
May 26, 2009 | Garden
Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
I was able to get information from someone's manual. I can't find mine. Would like a manual.
May 16, 2009 | Mtd Garden
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Yard Machines Cultivator Logo
114 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
