Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
HOW TO TAKE THE MAGNITO OFF OF A 306A POULAN CHAINSAW
I NEED TO GET TO THE STARTER ROPE TO REPLACE IT, BUT THE MAGNITO HAS TO COME OFF FRIST
  • samsno12 Mar 11, 2009
    ROWDY 45176
    HAVE YOU EVER TRYED ORDER TREE .COM FOR POULAN? THEY DO HAVE A DIAGRAM OF THE POULAN 306A CHAINSAW. I NEED TO KNOW HOW TO TAKE THE FLY WHEEL OFF TO GET TO THE STARTER ROPE
  • Dejuan Powell
    Dejuan Powell Apr 29, 2018
    It's a pp3516, 35cc Poulan chainsaw
  • 2,176 Answers
I can't find your model number at Poulanpro.com but in all the chainsaws that I have worked on the starter rope comes in the cover which is held on by usually 4 or so screws. I suggest that you go to the site I listed and look at the 42 CC engine (they have a parts manual for it) before removing anything else. Let me know if I can help further.
Posted on Mar 11, 2009
  • David Ford
    David Ford Mar 12, 2009
    I didn't know about that site but I looked and the schematic was not that clear about what is holding the flywheel on. I would have to assume it is a hex nut possibly left hand thread that would need to be removed and take a screwdriver and run it around the edge of the flywheel trying to find the magnetic side. If you can then I have put the screwdriver under that side and taken a hammer and "TAPPED" on the opposite side while applying little pressure on the driver and usually that pops them off. Carefully look before attempting this. I wish I had more but the Poulan site like I said doesn;t list this saw.
What causes the starter assist spring to deform after just first time starting chainsaw on a Poulan Pro pp5929av
The spring is designed to assist the starting. Over pulling or quick "yanks" on the starter rope can deform the spring. Best tactic, pull lightly until the starter pawls engage, then briskly pull the starter rope.
Sep 05, 2017 | Poulan Garden
How do I change out the pull rope on Poulan 42cc chainsaw
I have found that youtube is a great place for chainsaw repair videos.
Check this one and see if it helps. http://www.youtube.com/watch?v=PsJ0sygoVBQ
Oct 20, 2014 | Poulan Garden
How do you replace spring on a poulan chainsaw
A Poulan "P4018WT Gas Saw Type 1" IPL follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
If yours is not a "Type 1" it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If the spring is unwound:
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. The video explains how to tension the spring.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do you replace the starter cord on a poulan chain saw
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need t find an air filter for poulan 306a chain saw
I got 1 hit for your filter, if you haven' already give them a try "Poulan air filter 530023046"
http://www.lawnmowerpros.com/Poulan-Parts-Search.asp
Lou
Sep 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do you put on a new starter rope on a poulan# 306a chainsaw
I'm guessing the pull rope is broken.
First you'll need a C-clamp large enough to clamp the spooler, needle-nosed pliers, a small tipped screw driver and a new length of rope.
The safest way is to remove the rewind assy. cover leaving the spooler in place in its housing, try to remove the old rope with the
needle-nosed pliers and small tipped screw driver.
Next hand spin the spoiler to achieve spring tension (about 5 or 6 revolutions) and using the C-clamp to hold it in place, attempting to lineup the knot recess in the spooler with the ropes exit hole on the cover.
Then you can try to fish the new rope into the hole in the knot recess trying to guide it to the exit hole in the cover (its easier to feed the rope if you singe the end of the rope with a bic lighter and form it to a point) and with a small knot at the other end, pull the rope all the way until you can seat the knot into the knot recess.
Next tie a loop knot onto the other end of the rope, so the end wont be recoiled all the way into the housing. With tension on the rope gently remove the C-clamp and let the rope be drawled in.
If it draws all the way to the loop knot, check to see if the spooler is full if so, (not too full where its binding) pull the rope about a foot and re-clamp the spoiler and install the pull handle.
If it does not draw all the way to the loop knot and the spooler is not full, then you may need to add another revolution to the spring tension in the same fashion as described above.
There are easier ways, but that evolves removal of the spooler and repacking the recoil spring. (not a job for a novice)
Good luck
Aduz
Mar 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan starter rope
to fix starter rope first you must wind spring and place back in housing. just grab spring by middle and wind ,you will have to get it smaller than housing hole. One end should hook to a tab at housing rest of it sets inside itself. once set in housing dont let go, insert rope housing over top & screw in. rope housing should have some return spring to it when pulled. if rope is not tight on return pull simply add one winding to spool. hope it helps!
Feb 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
234 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
